Bad News... you may have to Restore from iTunes.
Here is some info from the users manual:
Passcode Lock
By default, iPhone doesn’t require you to enter a passcode to unlock it.
Set a passcode: Choose General > Passcode Lock and enter a 4-digit passcode, then enter the passcode again to verify it. iPhone then requires you to enter the passcode to unlock it or to display the passcode lock settings.
Turn passcode lock off: Choose General > Passcode Lock, enter your passcode, and tap Turn Passcode Off, then enter your passcode again.
Change the passcode: Choose General > Passcode Lock, enter your passcode, and tap Change Passcode. Enter your passcode again, then enter and reenter your new passcode.
If you forget your passcode, you must restore the iPhone software. See “Updating and Restoring iPhone Software” on page 204.
Set how long before your passcode is required: Choose General > Passcode Lock and enter your passcode. Tap Require Passcode, then select how long iPhone can be idle before you need to enter a passcode to unlock it.
1 Solution for ''i record songs on my iphone and they transmit onto my itunes but when i put the...
(More)
1 Solution for ''i record songs on my iphone and they transmit onto my itunes but when i put the songs on my blackberry curve 8900 they don t play
my iphone will start to sync with itunes but stop after about 15 sec. i tried rebooting my computer...
(More)
my iphone will start to sync with itunes but stop after about 15 sec. i tried rebooting my computer and my phone.
i turned off and then turned it on, (iPhone 3G 8G) and it doesn't start. it's been blocked with a...
(More)
i turned off and then turned it on, (iPhone 3G 8G) and it doesn't start. it's been blocked with a black screen and an apple for 2 hours now..what should i do!?
