Question about Uniden Cordless Phone
GE 5.8GHz Caller ID Cordless Phone 25922
Should the phone be placed back on the charger base after each call, or should I not and let the phone battery die down until it needs a recharge?
Sometimes if you let the phone charge run down it will cut off in the middle of a call
Posted on Jan 11, 2008
Phone died. recharged the battery now it doesn't work
You may need a new battery depending on the type of phone. If it's an iPhone hold the on/off button and home button at the same time until you see the apple icon. Sown times it could be your charger as well. Short in the cord. Best of luck
May 10, 2016 | Cell Phones
I have a pair that takes batteries an a charger base charger how does this work
They are often fitted with rechargable AAA cells. These can be charged by putting the phone on the charger base. Obviously the base must be plugged into power. You could alternatively take the rechargable cells out and charge them in a standard charger. The radios will also work with non-rechargable batteries but don't try and charge them or use the charging base.
Oct 29, 2013 | Radio Communications
I have a Uniden D1680 cordelss phone system. Often times when talking for two minutes or so--it disconnects--this happens alot. Any suggestions???
UNIDEN is notorius for this. It could be losing connection to the base - are you moving around while on the phone? or it could be the battery is not holding a sufficient charge. You can move the base unit to see if that helps - maybe something is interfering with the signal. You can try taking the battery out of the phone and putting it back in. If that doesn't work then try swapping the phones and putting them in each others charger. If that doesn't work then try letting the battery die by leaving the phone off the charger for 24 hours and then recharging for 24 hours. Good Luck!
Jun 10, 2012 | Uniden Cordless Phone
The base unit for my Philips VOIP3212S is not charging the phone I need to buy a replacement base unit. I put ordinary batteries in the phone and the base unit no longer works
Wilson - The phone was not made to use regular (AAA) batteries. Unless you install AAA NIMH rechargeables it will not work. Regular AAA batteries cannot be charged by the base unit.
In case you meant AAA NIMH batteries as "ordinary batteries" then your charger may be the problem, but I wouldn't assume that until I've taken a pencil eraser and vigorously cleaned the base contacts and tried the base again (with the right batteries.)
Good Luck, Mikeywaf
Mar 07, 2011 | Philips VOIP3212S/05 IP Wireless Phone
My phone is display out of range
  1. hi..
  2. When you pick up your GE cordless phone and press a button, the phone should beep as a confirmation that a button has been pressed. If the telephone handset does not beep, or if it does not respond to any buttons, the battery may be in need of a recharge. Verify that the cordless phone base unit is plugged in to an electrical source, then place the handset into the charging cradle. If no lights illuminate on the phone, or if charging fails to correct the issue, clean the metal charging contacts on the cordless handset and place the phone back on the charger. If it still fails to respond or to charge, the unit may need to be serviced or replaced.
  3. If the cordless phone charges up and appears to be ready for use but dies after only short periods of use, the internal rechargeable batteries may need to be replaced. Replacement batteries are widely available at electronics and discount retail stores. Note your phone's exact model number, as this number will be necessary when purchasing a replacement battery.
Jan 03, 2011 | Uniden Cordless Phone
It won't charge the rechargeable batteries anymore
I have the same problem , the only logical reason i could think of is that the charger connecting to the base station has malfunctioned .
Aug 30, 2008 | Philips VOIP8411B/37 IP Phone
Samsung SGH-A701 Wont charge when on the charger
Similar problem, battery ran out but cant get recharge it, sometimes the screen flashes if it take the battery out and put it back in, but then black?
Should I try an new battery or a new phone?
Jul 15, 2008 | Samsung SYNC SGH-A707 Cellular Phone
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
GE 5.8 ghz cordless model 25922
as with all devices which return to base for charging, the life of the re-chargeable batteries is shortened if it is constantly trickle-charged, so as with a moble phone, it is good to sometimes let it run down completely and re-charge as the battery charge will last longer, batteries are like muscles, they need excercise.
Jan 09, 2008 | Uniden Cordless Phone
Uniden Cordless Phone Logo
96 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
