Foxconn Motherboard
Problem for Foxconn (755A01-6ELRS) (K8S755A6ELRS) Motherboard
Connect power swithc and led cables
By gefa53 on Nov 10, 2009
connect power swithc and led cables to foxconn n15235
Solution #1
posted on Nov 10, 2009
Not Rated)
map9966
Rank: Guru  Computer Components  Expert
Rating: 89%, 1971 votes
Still have your Foxconn manual? Turn to page 19. See figure FP1.
Download manual from Foxconn, click on the link provided;
http://www.foxconnchannel.com/en-us/product/Motherboards/detail_overview.aspx?ID=en-gb0000154
System cases vary when it comes to wire colors. The most common wire colors for positive are, solid blue, light blue, solid red, solid green, light green. Negative wire colors. Each led, IDE-LED, Reset, PWR-LED and PWRBTN should share a negative colored wire. Common is the solid color white but this can vary from case to case.
Mike
Was this helpful?
Yes
No
Popular Solutions for Foxconn Motherboard
Questions and Unsolved Problems for Foxconn Motherboard
Do you recommend Foxconn (755A01-6ELRS) (K8S755A6ELRS) Motherboard?
Answer
Answer
Hi, the driver for the device is installed and up-todate but Windows Vista outputs an error that the... (More)
Answer
i need help with Connect the hdd led and pwr led and pwr s/w to my motherboard mpga478b is the... (More)
Answer
I have the same problem you described, the wires for the front panel MIC and headphones do not match... (More)
Answer
system specs AMD(tm) 64x2 dual core processer 4400+ 2 30ghz, 1. 00gb of ram ,physical address... (More)
Describe your Motherboards problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
