Question about Panasonic DMR-EZ47V DVD Recorder/VCR
DVD Tray will not open
The DVD tray seems frozen. I have tried turning the power off and pressing the reset button, but nothing seems to work. Also, there is a DVD in the tray that had played fine, but now that the tray is stuck, the display also says "no disc" after trying to read it.
  • potter05 Jan 07, 2008
    DVD door will not open on Panasonic DMR-EZ47V.  Tried turning it off and holding down the Open/Close button as suggested on blog.  Tried everything in the operation manual to no avail.
I purchased this unit back in Mid November to make DVD's of my kids old VHS tapes. To date I have probably have made 400 DVD's. Sunday we came home from being gone all day and the unit was locked up. I tried the reset button, unplugged the unit etc to no avail. I unplugged the unit all Sunday night and looked at it again on Monday morning. I was ready to take the unit back to Best Buy and the unit ejected the DVD and has worked for 2 days (Recorded another dozen DVD's). Tonight while reading the paper a message came on my monitor that there was a problem with the disk and instructed me to push the "enter" button which shut the unit off and was suppose to recover the disc. The recorder is now locked up again. A number of 000000's flashes accross the display and the unit constantly cycles off/on. So it is trying to recover but is obviously not being successful. I am going to try the same thing tonight. I am not sure if I have a bad set of blank DVD's. They are Sony -DVD R, same ones I have been using all along. I do remember having this "Error" message when I first started this project and I had to unplug the unit to resolve but it didn't lock up and I haven't had any issues until Sunday. Seems like something in the software is screwed up. It is frustrating that there doesn't seem to be a manual way to eject the disk??!!
Posted on Jan 16, 2008
  • Mike Ding Jan 16, 2008
    I forgot to mention that the code on the display is U61
2 Suggested Answers
  • 3 Answers
SOURCE: disc is stuck in the tray - samsung dvd R130
Without knowing more of your specific situation, it sounds like the disc is physically stuck and is blocking the motor mechanisms from ejecting. There should be 1-2 screws on each side & one at the rear of the player to remove the outer casing. When you open it, any obstructions should be obvious. The screws should be easy to figure out with an arrow pointing to them stamped into the medal, kindof looks like: =>
Posted on Mar 14, 2009
WILL NOT EJECT DISC
What is the model number of your DVD player? You may try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
FOR SONY PLAYER's
This issue may occur if the disc is damaged or if the disc was not inserted properly into the Blu-ray Disc® player. Follow the steps below to open the disc tray and eject the disc.
  1. Turn off the Blu-ray Disc player.
  2. Disconnect the power cord (mains lead) or AC adapter.
  3. Allow the disc player to remain without power for 30 seconds.
  4. While pressing the OPEN/CLOSE button located on the front of the disc player, reconnect the power cord.
    IMPORTANT: For some Blu-ray Disc Home Theater models it is necessary to press and hold the OPEN/CLOSE andPLAY buttons simultaneously, then reconnect the power cord.
    NOTE: This step may require the assistance of a second person.
  5. After reconnecting the power cord, when the tray opens, release the OPEN/CLOSE button.
  6. Remove the disc.
  7. If necessary, disconnect and then reconnect the power cord to recover the player.
Aug 24, 2015 | Televison & Video
If press eject button,it's showing LOCKED.what can i do?
Jan 21, 2015 | home Audio Players & Recorders
Dvd tray on MDR537H will not open
"...DVD tray won't open until it's set up - clock set and channels scanned..."
Nov 22, 2013 | Magnavox Mdr537h Blk Dvd Hdd Recorder With...
Panasonic DMR-EZ48V stopped working properly. It seems to have frozen up, but resetting it doesn't get it working again. When I reset by pushing the power button for 10 seconds, it flashes HELLO 15...
My unit is doing exactly the same thing. I've tried reloading the firmware, but it never appears to enter the First Time Setup. To load the CD I had to remove the cover, (disconnect the power) and manually eject the DVD tray. With the cover off, look on the side of the DVD. There is a square hole, directly above the screw that attaches the DVD to the chassis. Insert a stiff rod and push. The DVD tray will open. This is how I loaded the firmware CD. This all started after I rescanned the tuner and then did a manual channel edit. While trying to edit the channels, the unit stopped tuning and ended up in its current state.
Jan 23, 2011 | Panasonic DMR-EZ48 DVD Recorder
I have a HP Pavilion a1140n. The computer froze and was turned off by holding down the power button, but it would not boot up. No light appears on the power button, and when it is pushed, the DVD drive...
hmmm strange first thing id try is resetting the bios it seems it has been effected . remove case remove battery leave off for 3 minutes and replace try then again, while u have the battery out hold the power button on , oh and make sure the power is plugged out, and yeap hold power button for 3 secounds just to drain last of power from power supply. hope this helps
Nov 29, 2009 | HP Pavilion a1140n (PX774AA) PC Desktop
DVD tray won't open
Try to reinitialize the DVD functions, in the manual:
http://books.jvcservice.com/booklist.asp?Model=DR-MV1SU
Page 84
Turn the player OFF,
Press and hold the power button, While holding it, press the Stop button for 2 seconds or more.
Once its reset, see if it will eject.
Dec 27, 2008 | JVC DR-MV1SU DVD Recorder/VCR
Toshiba sd-4205 5-dvd carousel changer declares mecha error during startup, will not eject tray.
This may not work for everyone, but.....
I had the same problem with the Toshiba SD-3205. After unplugging, trying button combos, etc, nothing worked. I could here a slight whine inside the machine, and then again...."MECHA ERROR".
I turned the unit on its side to see if there was a manual tray button on the bottom. Nothing. Then just to try it, I turned the machine off and on again while on its side.
It started up, I heard a clatter, and then the display changed to "INSERT DISC". I placed it the right way up again and pressed "OPEN TRAY" and it worked!
My theroy: There was one DVD in the carousel, and I think last time the tray shut, it got wedged somehow and prevented the carousel from rotating. Turning the machine on its side and pressing "OPEN" is what dislodged the disk.
Jul 09, 2008 | Televison & Video
Dvd tray will not open
In order to open the disc tray.apply one of the following solutions;
--- Turn off the DVD player. Unplug the power cord from the AC outlet for 30 seconds.
Plug the power cord back into the AC outlet. Try to open the disc tray.
--- If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
--- If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons ,
- If the disc tray still does not open simultaneously press the RETURN + ENTER+ POWER buttons.
If the problem is still unresolved, a service may be required.
good luck...
Apr 06, 2008 | Sony DVP-NS400D DVD Player
Jvc xv-thc3 tray is frozen
The changer mechanism needs to be manually reset. Maybe due to a broken gear.
Oct 28, 2007 | Audio Players & Recorders
Dvd player stuck in 'demo repeat mode'
press and hold the power button for about 5 seconds to reset the player
Aug 13, 2007 | LG DN798
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
491 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
