Question about HP (215487B21) AIT-2 Tape Drive
SDLT 320 Tape drive issue
Hi, We have a SDLT320 Tape Drive that we backed up a SAN Databse connected to Solaris Box,  The backup took 8 hours, which was ok,  However, the restore is really slow (800kbps) which is about 8 times slower than anticipated, the logs does not show any issues with regards to corrupt date of anything, it is just really slow, Would love to know what your thoughts are on this and if there is a solution for this slow transfer speed
Regards
Christo Crafford Project manager
6ya staff
SOURCE:
Tape-Techie
  • 74 Answers
SOURCE: Tape Drive Block Size
Bit of an odd one but i agree that block size could cause an issue.
Try this link for the HP tech manual for this drive.
http://www.tag.com/tech%20support/System%20Resources/Drivers%20&%20Utilities/Drivers/Current/7.2/HP%20DAT%20Storage%20Works/guides/unix.pdf
It may help with your issue and does detail block size changes on some systems.
Posted on Aug 24, 2009
SirEbrum
  • 57 Answers
SOURCE: Using SDLT cleaning Tape
When the drives Clean LED comes on, install a "Universal" LTO Cleaning tape, as these drives do not need routine cleaning. Only ever clean a LTO drive when it's requested, as the cleaning media itself is more abrasive than a standard tape.
Posted on Jan 06, 2010
SOURCE: hi, Guru
Tape getting struck in media library may not be because of the backup application. Move the media out manually. While filling in the media slots make sure you leave a couple of slots free to avoid the srtuck scenerios..
Please come back and rate my solution if it turns to be helpful for you.
Thnx :)
Posted on Mar 23, 2010
r4k4
SOURCE: How do I physically remove stuck tape from
If the mechanism is physically damage, then I think disassemble the drive unit is so make sense.
Posted on Feb 02, 2011
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: tape stuck in HP SDLT320
Lots of good pix of the guts here...
http://support.thesmithlife.com/DLT/
Various intructions.
http://support.thesmithlife.com/DLT/DLTDrive-StuckTape.html
http://www.dectrader.com/docs/set2/ucr_na-CYB201412_002.pdf-1.pdf
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=lpg50246
http://www.ehow.com/how_7861932_remove-stuck-dlt-tape.html
Posted on Jul 14, 2011
Testimonial: "Thank you very much for your assistance. it was very helpful!!"
HP StorageWorks 1/8 Tape Autoloader SDLT 320 - tape library - Super DLT - SCSI Displayed Error! Code: A0 When you try to import or export are displayed error code 90
The library picker arm cannot move to the home position. There could be something blocking it. Try the Reset option from the Configuration menu. This is detailed in the library user guide.
Jan 11, 2011 | Quantum ValueLoader SDLT 320 Super DLT...
How do I physically remove stuck tape from valueloader SDLT 320
Jul 09, 2010 | Quantum ValueLoader SDLT 320 Super DLT...
How to allocate media with ntbackup
  1. Valueloader should have "SEQ" on front screen.
  2. Insert media into Valueloader
NTBackup will NOT see individual tapes, but treat the SDLT320 drive as a stand alone with one big tape, and the Valueloader will automatically change tape, in sequence, until the backup is done.
This is the major difference between a "Autoloader" (Sequential Mode) and a "Library" (Random Mode).
In Sequential Mode the robot (or Medium Changer) is hidden from the OS, thus only providing a tape drive. The autoloader is smart enough to see incoming data and will move Tape1 into the drive. As the media fills, the autoloader will swap media on it's own. By the time the backup is complete, whether it be one or all 8 pieces of media, Windows has no clue that it's data crossed multiple pieces of media.
In Random mode, the library is dumb and will do nothing on its own. It's told by software (i.e. Backup Exec, CommVault, etc.) when to move a tape into the drive and which tape to move!
The advantage of using Random Mode is that software runs the show and media is effeciently managed. Restores are much quicker as the exact tape a file is recorded on can be directly loaded and extracted, vs. (worst case in Seq. mode) having to go through each tape, in sequence, before getting to the file that could be on that last tape (think hours!).
Sep 27, 2009 | Quantum ValueLoader SDLT 320 Super DLT...
I have a Quantum SDLT 320 drive in a Dell 2800 server that has the yellow attention light stuck on. It is performing backups successfully in Veritas and giving no errors from Veritas or anywhere else. Can...
Sounds like it may be the cleaning light (far right)
You need to use a cleaning tape in the drive (they do expire after either 20 or 40 uses so use a brand new one to be sure)
That should clear the light. If it comes back on after another backup then try using the cleaning tape again and then a brand new tape for the backup.
If the light comes on again then the drive will need to go for repair as the head is knackered.
Try www.tape-drive-repair.com for this as they are pretty good price wise and also offer a 1 years warranty on their drives and repairs
Aug 13, 2009 | Quantum ValueLoader SDLT 320 Super DLT...
I get an error code A4 and 8A on the value loader LTO library.
I opened the library, removed all slots and put them back in with proper alignment. It's working now..
Nov 13, 2008 | Quantum ValueLoader SDLT 320 Super DLT...
Quantum ATL SuperLoader
If you cannot physically load a tape into the drive it is a hardware problem and the drive requires service. It is not a software problem.
Of course, the library could already have the maximum tapes it can hold. If this is the case then eject a tape from the library to make room for the tape you want to add.
I hope this helps.
Apr 17, 2008 | Quantum ValueLoader SDLT 320 Super DLT...
My Drive will not eject the tape
Turn off the tape drive. (Switch in the back of the unit. Wait 2 minutes and then turn unit back on. Tape drive should issue a write data command and then rewind the tape. After rewind completes the tape should eject. If it does not eject after rrewind completes than try holding the eject button for 5 seconds to attempt a "force eject"
Note: Do not repeatedly press the eject button as this can cause damage to the tape and the tape drive.
Dec 07, 2007 | Quantum SDLT 320 External LVD...
Stops during boot
First of all the DS20 is an Alpha box not a VAX. The problem here is usually an adress conflict. These tape drives are usually device 500. Try placing the drive onto a different controller card. That should resolve the problem.
Dan
Oct 22, 2007 | Quantum SDLT 320 External LVD...
Open Questions:
HP (215487B21) AIT-2 Tape Drive Logo
62 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
