Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture on tv but have sound
Tv worked unpluged it moved it sat in a garage for a few days moved it pluged it back in now the standby light flashes when i try to turn it on the sound works fine but there is no picture at all
  • bubba henry Jan 07, 2008
    blinks the whole time that the tv is powerd up
    blinks continuisly when the tv is powerd up
How many times it flashes?? if its more than 6 times you have a problem. just lick the red wire that goes to the picture tube.if it does not kill you, you are lucky
Posted on Jan 07, 2008
TV went off, standby timer light flashing
Try unpluging from the wall and theplug back in and try turning back on to reset. Sometimes holding the power button in while pluging back in will reset it, every brand is different for the hard reset.
Apr 17, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
TV will not power up. Timer light continues to flash, will not reset.
You could have shook a fuse loose moving it ,,,or blew a fuse,,take the back off and check the fuses,,good luck ,,
Oct 06, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Samsung hc-p4241w - No picture
samsung tv model hc-p4241w good picture no sound
May 22, 2009 | Samsung HC-P4241W 42" Rear Projection...
Samsung LN46B550 no picture only sound 3 days old
hey Adam i have a samsung that has been doing would come on then after a few minutes the picture would go ou but the sound still worked.i found that one of the connectors that plugs into the LCD board had a broken solder joint were it connects to the back lighting .just unplug your lcd connections if its bad you'll know it because it will come out.
Apr 05, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Sony Bravia KDL 46", no picture, standby light blinks 4 times
Since the TV is still receiving power, the problem is going to be with the TV's mainboard.  After you unplugged the TV and plugged it back in, you said the power light went out again, so I assume the standby light wasn't flashing again?  The flashing standby light is indicating an error code so my suggestion is to contact Sony for service options regardless if there is a warranty or not because service is the only solution to this situation.  Don't forget to provide them the error code or 4 flashes repeating.
Mar 25, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Standby/stereo light blinking no picture or sound
My picture would go out after several minutes but I still had sound. I took the rear cover off and blew all the dust off with compresed air.I did this for a few times over several days nothing happened.I also took off the rear circuit board that attaches to the tube with a round pin socket and blew that with compressed air and put it back on. The TV has now worked for two days without the picture going out. It worked!!!!!!!!!!!!!! My TV is 9 years old.
Aug 31, 2008 | Sony KV-36FS100 36" TV
I have a philips tv and a xbox 360. I cannot get the xbox to work with this tv. The xbox is pluged in to the tv and I know the yellow white red cords work because they work when i use the vcr. It was...
I guess when I moved the xbox i hit the swith for the hd and regular tv. It's on the back of the xbox next to the power cord plug in. I could hear sound but i couldnt see the screen. When I swithched it to TV the picture came on.
Jun 01, 2008 | Philips Televison & Video
No picture or sound
On mine the indicator light is indicating that it is in STANDBY mode, which means it is OFF. Press the button again, which will turn off the light and now the tv is ON. Now merely press(possibly multiple times) SOURCE to find the correct source for your Cable/SAT and your good to go.
Apr 29, 2008 | Olevia LT27HVX 27 in. LCD Television
I have the exact same problem! I'm assuming it's time for a new tv.
Oct 21, 2007 | Sony FD Trinitron WEGA KV-32HS500 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
55 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
