Question about Sony KP-57WV600 57" Rear Projection HDTV-Ready Television
HD Picture fades and goes balck
The HD side of the TV fades and flickers after about two hours and eventually goes black....this happens with all HD component inputs and input sources. The picture will return after the tv is turned of for 30-60 minutes but the process repeats itself. The picture also gets a green hue as it deteriorates. Any thoughts?
    Problem Solver:
  • 11 Answers
Go to this site, follow the instructions, and it might fix your problems. I did, and my tv is better than ever!
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
I was having this problem with blue. I was able to fix it, and now my tv works again. For those having trouble removing a different front panel, here is what I found on mine -
I own a KP57WV600. Removing the front panel is a little trickier on this model. You remove the 6-8 screws on each side behind the two speakers. You will access these from the lower rear/sides of the TV. Remove the small 2ft plastic pieces. Now from the front of the machine grab the entire lower piece (speaker covers & power/volume/chanel buttons) from the bottom and pull down and towards yourself. There are 4 slots that this piece fits into. I had to take off the lower back panel to see why it wouldn't come out. Don't pull to far because this lower front piece is connected to wires. I'd say you have about a foot of play. Now you can remove the fiber board panel and access the blue/green/red lower screws. When you adjust these, go a fraction of a milimeter at a time.
Posted on Apr 09, 2008
    Problem Solver:
  • 7 Answers
U and i both need blue crt tube.i also need convergence fix...u probably will as well .just had repairman over and tubes will be hard to find ...unreal tv is only 4 yrs old /03
Posted on Jan 08, 2008
  • rowdyroddy Jan 08, 2008
    found tubes (new ) not refurbed..1-800-241-5005
What is wrong with Sharp Aquos LC-40C32U Picture
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site with the keyword "Line fault"
Jul 01, 2015 | Sharp Televison & Video
How to fix a Sharp Aquos LC-40C32U Picture
TH-42PX75U horizontal lines (flickering black and white)
The controller board for the screen is going bad. check shopjimmy.com for replacement parts. It's not a difficult job to do. Once the back of the TV is removed, you'll see it near the center of the screen.
Feb 21, 2014 | Panasonic VIERA Televison & Video
When tv is turned on picture flickers really
When it goes black can you see a ghost image? It will be a normal tv picture but very faint black and white looking, you may have to get close and look at an angle to even see it. If so that means your backlight system is failing. If you don;t see an image then it is a problem with the power section of the board inside the tv.
Check if it is covered by warrenty and get a quote if it isn't. A 42 inch is new and big enough that it should still be worth repairing but it may cost you anywhere from $100 to $250 depending on the shop to fix.
Apr 12, 2010 | Vizio GV42L 42 in. LCD Television
Just bought a Sony XBR9 and Comcast gave me a Motorola DCT6200 box which has a DVI output to a HDMI input into the TV. When switching from a HD channel to an analog or digital channel, the picture is...
I am having the exact same issue. It started happening within the first few hours of turning on the XBR9 for the first time. I also have a Motorola box from Comcast. This did not happen with the HD TV that was hooked up previously. Did you return the TV?
Jan 07, 2010 | Arris DCT6200 DTV Receiver
TV worksfine for one hour, colors fade in and out, flickers
Color Wheel, Go website Encmpass Parts Distr Look up the part # if they do not have it in stock then go to E-Bay look under Electronic 1-800-638-3328
Oct 07, 2009 | RCA HD50LPW175 50" HDTV
Picture fades to black when it goes to commercial
The sleep timer may be set to fade and a short time span.
Feb 08, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony KP-57WV600 57" Rear Projection HDTV-Ready Television Logo
97 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
