Refrigerators
Problem for Refrigerators
Generic problem for all Refrigerators
I have a Estate bran fridge and it keeps
By loafy24 on Nov 10, 2009
I have a Estate bran fridge and it keeps defrosting every two days it's a new fridge what could be the problem
Solution #1
posted on Nov 10, 2009
Not Rated)
localwonder
Rank: Guru  Refrigerators  Expert
Rating: 92%, 3128 votes
HI. This will occur if your defrost module is malfunctioning. There are two types of defrost controllers. The first will be an adaptive control board. This will be located in the control housing, just above the heat shield, in the upper right had side. Older models will have a standard defrost timer mechanism. When these devices are malfunctioning, You will notice erratic defrosting cycles. I recommend to inspect the module, to confirm that it is set correctly, and is operating.
If equipped,The defrost timer is usually found behind the front grill "toe kick" of the refrigerator. It may also be found behind a cover plate inside the refrigerator or freezer, in the temperature control console, or behind the refrigerator near the compressor. It will have an adjustable dial. make sure it is set to a proper defrost interval.
NOTE_ If your unit is equipped with an adaptive defrost control board, and the defrost cycle is erratic, this will require you to replace the board. this type of defrost control module is not repairable.
Was this helpful?
Yes
No
Popular Solutions for Refrigerators
Questions and Unsolved Problems for Refrigerators
Answer
Whirlpool model ET1CHEXVB or model W2RXEMMWB. Anyone have comments on either of these... (More)
Answer
Need a new refrigerator after only 8+ years from Kennmore -- have not been happy with this brand on... (More)
Answer
I have a sibe-by-side GE refrigerator Model Number GSHL6PHXBELS and the icemaker has stopped... (More)
Answer
freezer door stuck closed, not iced, stuck on one side only. Seems to be a problem with the track.
Answer
compressor trips the overheating/overload switch before it will run
Describe your Refrigerators problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
in Newport, KY
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
