Question about HP L1702 17" LCD Monitor
Monitor randomly shuts down
Our HP L 1702 for no apparent reason turns its self off.
It will not turn back on with keyboard or mouse activity but with the on/off button on the monitor.
This could happen ofter one minute of one hour.
  • 9 more comments
  • sodablast Feb 02, 2008
    green light comes, and then goes right back off. Screen never comes on.
  • Anonymous Mar 04, 2008
    DISPLAY GOES OFF SUDDENLY BUT THE LED LIGHT REMAINS GREEN ONLY WAY TO BRING BACK THE DISPLAY IS SWITCH OFF AND POWER IT ON AGAIN THE LCD MONITOR BUT AGAIN GOES OFF FRQUENTLY JUST STAYS FEW SECONDS AND GOES OFF
  • lenrdb57 Mar 06, 2008
    Monitor goes black after as few seconds or few minutes, the image is still visible.
  • Anonymous Aug 30, 2008
    our monitor shuts off or turns to sleep frequently. It only works for maximum of 5 seconds. The power is still on as there is a green light on the monitor
  • Anonymous Sep 29, 2008
    The problem is that the monitor will go to sleep and neither mouse nor keyboard activity will wake it. I have tried to unplug the monitor and plug it back in. I tried to take the video signal away then plug it back in and nothing helps. I used monitor and it works so the video card is fine. by any chance is there a sleep setting within the computer or monitor that is causing this issue?
  • Anonymous Oct 01, 2008
    wow!! i bought a 17' hp 1702 and it worked fine for a good 7 months then it acted up! it keeps shuting off after about 5 mins then after i turn it on and off a few times the time keeps getting shorter and shorter. i know its still on the led light is still green i need some help!!
  • ben_re0 Nov 04, 2008
    same problem...
    i've replaced the 4 cap's (1000uf, 16v) but still turns on for 1 second and then the screen turns black while the power led is green/
  • lino252 Dec 01, 2008
    hello, in my HP 1702 i have two boards connected by wire, the power board 715L1236-3-QDI is defective. I replaced 2 caps 1000uF16V, 4 caps 470uF16V, and the ZD904 7,5V zener diode, as seen on forums, but the monitor always shuts down after 1 second. When i switch him on, after 1 second the brightness boost on and monitor switch himself off. LED stays green. I resoldered the board. Sometime, it is often when i assembly the monitor together, it works much longer. Anyone have idea?
    sorry for my poor english
  • se2000 May 11, 2010
    What components did you check? What components do you suspect?
  • Anonymous Mar 24, 2014
    Monitor goes dark.
  • Anonymous Mar 25, 2014
    It happens during still picture, no mouse movement or anything. After cca 1 sec everything returns to normal and after that works fine fo 1 or 5 hours. No pattern.
I replace the two capacitor 220uf 50v for 220 65v and it worked around a hour.but for some reason when you low down the brightness to 33% and contrast 6o it stay little be longer of time.please somebody can tell what I can do for fix this problem thanks.
Posted on Apr 02, 2008
Did somebody try the above solution which i gave there are two 220mfd 50volt capacitor try replace both first to check with zener if all zener are ok next step to check is only these two capacitors
regards
AR Digital
Posted on Mar 24, 2008
Please check all the zener diodes in the board you might find short or leaky also there could be a capacitor value 220mfd 50volt try to replace that also
Posted on Mar 22, 2008
Pls somebody spot out the defective component in the invertor board
Posted on Mar 07, 2008
  • 38 Answers
This is either power supply (not usually), backlight drawing to much current, or most likely an invertor board component failure. Built in overcurrent protection on many of these boards will provide a shutdown signal. Weak transistors will crash when they get hot. Hp monitors are notorious for inverter problems. The time between blackouts will decrease until it no longer will light at all. Repair or replace the invertor.
Posted on Jan 15, 2008
Hp touchsmart 300
From the User Guide at... http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=4174137&
The wireless keyboard and mouse are pre-synchronized, for your convenience, to work with your
HP TouchSmart PC. The keyboard and mouse should work immediately after you pull the battery tabs to
activate the preinstalled batteries, and then turn on the mouse (A).
You may need to manually synchronize the wireless keyboard or mouse if they are not functioning.
To synchronize them:
Make sure the keyboard and mouse are next to the HP TouchSmart PC, within 30 cm (1 foot) and
away from interference from other devices.
Keyboard: Press the Connect button on the bottom of the keyboard (B) for five seconds. The blue
activity LED on the wireless receiver illuminates when the synchronization command has been received
and turns off when synchronization is complete.
Mouse: Press the Connect button on the bottom of the mouse (C) for five seconds. The blue activity
LED on the wireless receiver illuminates when the synchronization command has been received and
If this does not work, remove and then re-insert the wireless keyboard and mouse receiver from the back of
the computer and then synchronize the keyboard and mouse again.
Fr
Jun 30, 2014 | Computers & Internet
Keyboard and mouse not working and monitor going to sleep
HP Pavilion Slimline S3400f Desktop.
dont worry ALL PC end up like this,, all do.. sooner or later..
NO OS stated, XP"? never post without OS stated, or answer get 10x more harder, See? make it easy for the helper and get more help.....
no Monitor stated. (maker, CRT, LCD what?)
The monitor is not fibbing to you BTW, the PC did go dead or to sleep. seems its monitor monitor of some kind with DVI.
if the monitor works on other PCs then the monitor is not bad.
i Bet it works (old ones 2002, have a hidden deep internal sleep mode. and is not yours IM sure now) DVI IS THE ONLY CLUE THERE.
So PC is dead. this PC came with only VISTA new,
is it still VISTA?????????
HP has support on it still
here (carbon dated by me 2008, IIRC)
https://support.hp.com/us-en/drivers/selfservice/hp-pavilion-slimline-s3400-desktop-pc-series/3688715/model/3688723
this year,? get all those files and books there backed up
when HP support ends after 10 year rule, (be savvy?)
what keyboard USB or wireless keyboard mouse
use wired USB keyboards if wireless the battery is dead. easy no?
now in VISTA, go to Control panel, click power
turn off all sleep modes and all hibernate modes
the turn off screen savers, if turned on , disktop . RC right click
in display settings or personalize, turn off , need login to come out of sleep or screen saver.
try a real keyboard, that has USB cable yet? be first thing to do.
always keep a real keyboard, handy,,,
batteries fail. in all wireless devices like this (inside them)
luck you desktops have lies DIM fails. there are many.
http://www.pcdied.com/sleep-or-dim.html
one other way , and common is PC overheated.
all do that.
ever one not cleaned out every year,.
#1 all time cause of overheat and PC shuts down.
http://www.pcdied.com/overheated.html
Aug 11, 2017 | HP Pavilion Slimline S3400f Pc PC Desktop
HP XW6200 randomly crashes with no apparent reason.
It can be the ram sockets. When it's new material, I'll advise you to go back where you bought your material so they can check under warranty.
Jul 08, 2012 | HP xw6200 PC Desktop
My HP Pavillion A220N desktop turns on but will not give me access to the monitor, mouse or keyboard
Simple replace the video card and be done with it. The video went out and froze up that is why you had to do the shut down the card right then. If you get another card that should solve the matter. That is all I would suggest to you at this time any loose parts remove them and located anything that is missing or should be there.
John
Apr 24, 2012 | HP Computers & Internet
Shuts down
This is a typical symptom of a failing power supply. Replace your power supply and see if the problem still persists.
Please notify me should you need any further assistance.
Best wishes,
Graemevm
Jan 06, 2012 | Intel DP55KG Motherboard
Computer turns off by itself
Depending on if you get any error messages at all.. Then do the following. If you get an error message, Post it back here for more specific directions on how to fix this issue.
First, remove all devices attached to the computer except the keyboard, mouse, and monitor.
Then.. Shut the computer down, start it, and press f8 to enter safe mode..
Does the computer randomly shut down in safe mode? If not then your issue is software, and can be fixed without replacing anything.
Aug 17, 2010 | Dell Dimension 4550 PC Desktop
HP Pavillion won't bring monitor back from sleep mode
hi...if u can read " no input signal" from ur screen, this means that ur monitor is ok..
Look if u have power buttons on ur keyboard.. try to wake it from there.. some pc may have shortcut keys to bring back the pc... look @ ur pc docs on the internet for more info...
However if it's a hardware issue, it may be that ur RAM memory needs to be cleaned
Feb 01, 2010 | HP Computers & Internet
Keyboard/mouse not working
You need to restore to a previous date before you installed the wireless mouse / keyboard.
If that dont work then your only solution is to format and reinstall since it might be you could have damaged a few vxd files window's needs to use those devices
(THIS IS ASSUMING THE MOUSE AND KEYBOARD WERE CONNECTED PROPPERLY) AND THEN THE SYSTEM WAS TURNED ON
if that wasnt done
shut down compuer
2.) plug mouse into green ps2 port and keyboard into the blue one
3.) turn on computer
Jan 03, 2008 | Computers & Internet
HP L1702 17" LCD Monitor Logo
928 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
