Question about IBM E54 (Pearl, White) 15 in.CRT Conventional Monitor
Blank screen please help me                                         First,the computer warned me to adjust the setting of the monitor.after that,my monitor wont display after theres a flickering.At the time of flickering, there is also unusual sound.How can  I fixed it ?
    Problem Solver:
  • 5 Answers
You can get the unit repaired by emailing rhartze@key-services.com , he will call you if you provide your telephone number.
Posted on Jan 08, 2008
I have set the screen resoloution to high for my monitor and now get a message saying "screen resoloution to high set to 1680 x 900" but cant reset it as all i get is the message and a blank...
First try shutting system down, unplug tower for 1 minute and restart. Give it time to come up and if that doesn't work, shut it down again and try to start in "safe mode" do you get any screen at all? If you can start in safe mode try going to "control panel'", "device manager" then "personaliztion", and adjust your resolution. If you can't adjust your resolution in safe mode do a "system restore" back to when monitor worked.
Apr 04, 2011 | Computers & Internet
Picture is too large for screen
Adjust the display settings on the computer by right clicking anywhere on the desk top except on any of the icons - a blank area. Select properties then select display settings - adjust to the desired or correct resolution.
Dec 17, 2010 | Dell E173FP 17" LCD Monitor
I am testing my system with the diagnostic program, and now I am stuck with the message "The current timing is not supported by the monitor display. Please change your input timing to 1920x1080@60 Hz...
Right click on a blank area of the destop screen and select properties from the menu that pops up, adjust your monitor settings and refresh rate to that suggested and see if it helps. dont worry if you press something wrong and cant see properly, just dont press anything and the settings will revert back after 15 seconds.
John
Dec 02, 2010 | Dell Inspiron 530s Desktop Computer...
The image leaves about 2.5 inches not used on each side of the monitor.
The bands are caused by the monitor displaying a picture that is not the correct resolution. This model has a native resolution of 1920 x 1080 according to LG - see http://www.pcworld.com/reviews/product/124873/review/w2353vpf.html#specs When you have your video card set to a different resolution that this the monitor tries to adjust the display to best fit the screen. The native or default resolution is 16:9 or wide-screen and if you have the video card displaying at 4:3 then you will have the blank bars displayed. Go to display properties and change your resolution to one that is 16:9 ratio and the bars should fill out.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Aug 29, 2010 | LG W2353V-PF 23' LCD Monitor
DELL E153FPf doesn't show the image
OSD Warning Messages A warning message may appear on the screen indicating that the monitor is out of sync range.
Cannot Display This Video Mode
This means that the monitor cannot synchronize with the signal that it is receiving from the computer. Either the signal is too high or too low for the monitor to use. See Specifications for the Horizontal and Vertical frequency ranges addressable by this monitor. Recommended mode is 1024x768 @ 60Hz.
Occasionally, no warning message appears, but the screen is blank. This could also indicate that the monitor is not synchronizing with the computer or the monitor is in a power save mode.
Jan 18, 2010 | Dell E153FPf 15" TFT LCD Flat Panel...
Warning "not optimum settings"
Press F8 as the computer boots up and the Windows Advance Options Menu will be displayed. Then select Safe Mode to boot up the computer.
When Windows finishes booting up, then open Control Panel - select Display - Settings, then change the screen resolution to a lower setting.
Apply and shut down and reboot computer.
Dec 19, 2009 | Samsung SyncMaster 912N 19" Flat Panel LCD...
The text is too tall and not wide enough. How do i adjust the monitor?
If you are using Xp right click on a blank spot on the desk top select properties,in the display properties you will see settings.There is a option to adjust the screen size,move the bar to the left will increase the size.Under vVsta you will right click on a blank spot on your desktop select personalize,select display settings there you can adjust the bar to the left to adjust your display.Remember to apply the changes before you exit.
Good luck
Sep 14, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Cannot stop monitor adjustment box from comming up every minute or two ,very annoying,please help.
A few suggestions.
1. check all cords- plugged in to computer, plugged into monitor- no bent pins etc..
2. Virus scan
3. Restore computer to a time before this problem ocurred.
4. A warning - Selecting incorrect monitor settings may damage some monitors. For information on the settings your monitor supports, see your monitor documentation.
I suggest that you adjust your monitor settings. you can right click on your desk top, go to properties, select settings, and advanced. I suggest that you make small minor adjustments.
Mar 27, 2009 | Acer Aspire™ T180 PC Desktop
Monitor screen went blank after changing resolution
Try unplugging the monitor and then restart, and then go back to default settings.
Jan 30, 2009 | Samsung 793S 17" CRT Monitor
How do I get the widescreen monitor to show unstretched images?
i had the same problem with my new widescreen monitor... turns out the best setting (at least, for my specific monitor) was 1440 by 900 pixels. at this setting the desktop still stretches itself to fill the entire screen, but everything else is completely unstretched. (to adjust the screen resolution, right click anywhere on the desktop, then go to properties, then settings.)
Nov 07, 2007 | Gateway FPD2275W LCD Monitor
IBM E54 (Pearl, White) 15 in.CRT Conventional Monitor Logo
63 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
