Question about Trendware TEW-432BRP Wireless Router (TEW432BRP)
TEW-432BRP set-up I have AOL broadband service ( DSL) connection.I wish to install wireless router so I can use PS3 gaming system in diffrent room.The computer will hooked up by wire coonnection.When I follow proper wire connecting I receive AOL error message "connection lost".I'm lost PLEASE help!!
4 Suggested Answers
  • 135 Answers
SOURCE: Trendnet TEW-432BRP
What exactly is the problem? Are you using Cable or DSL internet? Did you connect the cable from the modem to the WAN port on the router and the computer to the LAN or 1 port on the router?
Posted on Jan 07, 2008
SOURCE: trendnet router
i found out that since i have an older version of winxp 2000, i need to get a network adapter, to get this router going.
Posted on Mar 25, 2008
  • 209 Answers
SOURCE: Problem using Wa1003A and Tew 432 brp to share my internet
lan wires are the same. lan wires used to connect your computer to your modem can also be used to connect your Wa1003A adsl router and TEW 432 brp.
you just got some things mixed up.
1. you should set your Wa1003A adsl router to bridge mode. At this point, it will just be "pass through" device and will not be the one who will ask for IP adds from your ISP.
2. configure your TEW 432 brp with your pppoe username and password. Your TEW 432 brp will now ask the network for the IP address to that it can connect to your ISP.
3. leave your lan wires the same.
Posted on Apr 26, 2009
SOURCE: Trendnet TEW-432BRP wireless router doesn't connect to internet
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. Dont use the setup cd, sometimes it works, sometimes its not. here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url: or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url: and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
if you have any querry pls feel free to get in touch.. good luck
Posted on Aug 17, 2009
0 characters
1 Points
I dont have installation driver
Router does not require driver to be used, all you have to do is to install the hardware and configure it.
1. You have to know your hardware version, so you can download your materials.
There are 5 version of your TEW-432BRP.
2. Click the link below, If you already know the version.
(TEW-432BRP D1.2R/D1.3R)
(TEW-432BRP D1.OR/D1.1R)
(TEW-432BRP C1.xR)
(TEW-432BRP Bx.x)
(TEW-432BRP A1)
3. Download User Guide and Easy Go CD Files.
4. User Guide will help you to configure your router from start to end.
If problem persist just post and give a brief explanation on the problem.
Hopefully this helps
Thank you for posting.
Jul 09, 2011 | Trendware TEW-432BRP Wireless Router...
I cannot find my pin number on my trendnet tew-432brp router
! In your browser write in If theres an option for Configuration Pages, click on that. If it asks you for a username and password they're most likely to be
Look for a system information setting. In that information there should be something about a WEP or a WPA key. It should tell you the key there.
Jan 07, 2011 | Trendware TRENDnet TEW-432BRP Cable/DSL...
The NAT Type on my TRENDnet TEW 432BRP router is set to type 3. How do I change the NAT Type to open?
Step 1 : Connect - Router - Computer ( Wired )
Step 2 : Open Router setup by typing on the address bar of internet explorer
Step 3 : Click Login
Step 4 : On the Left Click Access
Step 5 : Choose DMZ
Step 6 : Click Enable ... And Assign the IP Address of the Xbox /PS3/Wii in it
Step 7 : Click Apply
Step 8 : Unplug the Power cord from the router and turn Off XBOX /PS3/Wii
Step 9 : Plug the power cord back to the router and wait till the lights are Solid
Step 10 : turn On the Xbox/PS3/Wii
Step 11 : Test the Connection
Step 12 : If Still the Same ..
Step 13 : On the Left under Access Click Firewall Rules
Step 14 : Disable it and Apply
Step 15 : Do Steps 8 through 9
Step 16 : Test the Connection
let me know if this works
Jan 05, 2011 | Trendware TEW-432BRP Wireless Router...
Wish to setup hp k550dtn printer with ethernet support to a wireless trendnet router..432BRP. Two laptops will share this printer
You can use a print server to connect your printer to your computers over the ethernet/wifi connection, All printers will be using a network printer..
You can Attach the printer onto 1 of your computers, set the properties to share the printer, and then set up a new printer on the other computers (network printer)
Make sure all the computers on your home network are on the same WORKGROUP
Jul 17, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
How to connect tew-432 brp to MT800 modem for a wireless connection
you can connect your Ethernet cable from tew-432brp to MT800.
if serial ethernet cable not work you can check with cross cable of ehetrnet also.
Mar 30, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
How do I connect the router to my laptop
if its wireless hook up cable/dsl to it and restart it so it will get the ip address then connect to it with a wired computer and setup the wireless settings such as a password and etc if you don't know anything about set it up as unsecured or else you probly wont be able to figure it out read any manuals that came with it if your wanting a secured wireless router
Jun 05, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
How to solve it???
your trendnet is just a router and it should work with any ISP whether if it's cable or dsl. you just need to connect it to the broadband modem provided by your ISP and configure with the correct settings.
with cable conncetion you just simply connect the ethernet(LAN) port of the modem to the internet(WAN) port of the router. then perform a power cycle by turning all the devices off. after that, turn on the modem first and wait for the lights to lit up before powering on the router and the computers. if this will not work you need to access the router's page and perform a mac address clone.
for dsl connection, you need to get the username and password of your internet account from your ISP then set your router to PPPoE or PPPoA.
you need to also check that your modem and your router has different ip addresses to make them connect to each other properly.
hope this'll help you but if you still have the same problem, just give me the exact model of your modem and who is your ISP
Aug 01, 2008 | Trendware TEW-432BRP Wireless Router...
TEW-432BRP getting diconnected.
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, try to call supportrix and use supportcall as your promo code for 1 free technical support.
May 30, 2008 | Trendware TEW-432BRP Wireless Router...
Wireless router dissconnects
Upgrade the firmwire you will find-it on
Mar 14, 2008 | Trendware TRENDnet TEW-432BRP Cable/DSL...
Trendnet TEW-432BRP
Jan 07, 2008 | Trendware TEW-432BRP Wireless Router...
Trendware TEW-432BRP Wireless Router (TEW432BRP) Logo
144 people viewed this question
Top Trendware Routers Experts
 C. Dante
C. Dante
Brian Sullivan
Brian Sullivan
alex metro
alex metro
Are you a Trendware Router Expert? Answer questions, earn points and help others
