Question about Disney Mix Max Digital Media Player
Mix max every time i transfer music to my mix max and i try to use it it says free 4mb of space to build music library it never did this before it actually just started today and ive had it for monthes now if any one has any feedback on how i can fix this it would be appreciated thank you so much..
  • bprize
    bprize Jan 07, 2008
    I'm having the same problem with my nieces players. Are there any solutions for this?
  • ReginaLuna Jan 07, 2008
    mine too!!! someone help us please?? just curious by the way, what kind is your mix max?
After getting the 4MB Playlist error, I decided to play around a little bit with my 8 year old niece's Mix Max. I think I found a few tips that will help others. First off, go into my computer and right click on the drive letter that corresponds with the Mix Max. It will probably be something like E: or F: Format it for FAT32...quick format worked for me. Next, make sure you have the most current firmware. Its downloadable from
http://www.siukoon.com/~williamchan/PD6020/MixMax_RecoveryTool_v1_0_2_fw_v1_4_000_20070512.exe
Install that, and run the program from your start menu. Make sure your Mix Max is turned off and hold the + sign as you plug it into the USB cable. It will guide you through a reset. Once you complete this, you should be able to process a sync through Windows Media Player 10 or 11. Hope this helps! I've also noticed that some songs will fail during the sync. If you remove those, it seems to help with the error as well. Might just be a coincidence.
Posted on Jan 07, 2008
6ya staff
SOURCE:
What's free 4mb of space mean?
if your device tells you that it is a 512Mb that is the total space on the device, if it is telling you 4mb of space it means there is only 4 more mega bytes available for you to store music, information, etc. some songs take up to 9 or 10 Mb so just do your math. and that is the number of songs you can load to your device.
if it works for you, don't forget to rate me
thx
Jun 02, 2010 | Disney Mix Max Digital Media Player
DISNEY MIX MAX
thank you sooo much for all of your help i did get it fixed and now my daughter can listen and watch again
thanks again
Jul 02, 2008 | Disney Mix Max Digital Media Player
Free 4mb of space error , now NO SONGS
Try formatting both the internal memory and the SD card. It's possible that the SD card isn't formatted correctly for the Mix Max to read it. Depending on the size of the card you may need to format it in FAT32 instead of FAT.
Apr 11, 2008 | Disney Mix Max Digital Media Player
Error free 4mb of space to build music library and disney mix max won't play any songs?
The memory may be corrupt and it can't read the music files correctly. Open your My Computer icon and plug the player into your computer. You should see a new removable disk called Mix Max appear. Right click on the disk and choose Format from the pop up menu. At the Format window make sure that the File System is set to FAT32 and click Start. At the next window click OK to proceed. You'll then need to add the songs back to your player but it should correct the problem. When adding the songs to the player again make sure that you leave at least 4 megabytes of space available so it can create the library file.
Mar 10, 2008 | Disney Mix Max Digital Media Player
Can't do anything without message
It has to make a library file of the contents on the player. It uses that file to display the titles and artists when scrolling through the menus and what not. You'll have to format your player in order to clear it up. This will erase everything and then you can put your songs and stuff back on it. Just make sure that when you do you leave at least 4 megs of space for it to make that library file. Here's a link to the manufacturers instructions on how to format the player.
http://digiblue.com/customer-service/faqs/disney/mixmax/06.html
Mar 06, 2008 | Disney Mix Max Digital Media Player
Mixmax froze
How can i delete space
hmmm, Try connecting to your computer,or open "My Computer"
and see if it recognizes the Disney Mix Max, if it does,
Double click the Disney Icon, and right click on something you want to delete, and click delete, or press "delete" on your keyboard. Be Careful not to delete things you want to keep though....
Jan 09, 2008 | Disney Mix Max Digital Media Player
Reading a card
Jan 01, 2008 | Disney Mix Max Digital Media Player
Driving me nuts
Dec 26, 2007 | Disney Mix Max Digital Media Player
Disney Mix Max Digital Media Player Logo
564 people viewed this question
Top Disney Audio Players & Recorders Experts
Ekse
Trevor Turner
Are you a Disney Audio Player and Recorder Expert? Answer questions, earn points and help others
