Toshiba dlp My toshiba dlp rear projection tv 46hm48 had a mark on the lower left hand corner. My wife thought it was a smudge and tried to clean it. The spot grew and now there is a large spot on the bottom of the screen with a shadow around it.
  • TMuir13 Jan 07, 2008
    Is it possible that the screen could have "peeled"? I opened up the front and can see an almost jagged "shadow" that is discolored on the inside of the screen.
  • 373 Answers
Sound like you light engine is going bad. A major problem to fix! Especially if you are sure it is a dlp
Posted on Jan 07, 2008
Blue spots on Sony WEGA KDF60XS955
Thats caused by a bad optical block. The cost of that repair will almost always be greater than replacing the TV.Thats a very common issue with alot of Sony DLP models which suffered that optical block issue with the blobs of color usually blue or green
Dec 10, 2012 | Sony Grand WEGA KF50WE610 50" Rear...
Toshiba 46HM95 Screen?
can you feel if the surface is rough has it been cleaned with an abrasive cloth like a scouring cloth used for dishes as this will scratch the surface of the screen try getting a good polish spray on but dont spray to much on and use a soft cloth ideally a proper duster cloth see if they polish out if not the the screen surface has been scratched this can be polished out but you will need to get a pro to do this as doing it your self could ruin the telly permanenty as this is a delicate job to do hopefully you should polish these marks off but if not i would get somebody out to look at the telly to get the scratches polished out of the screen this should not cost to much but will save the frustration of watching a smuged screen the only thing you can do yourself is try polishing the screen properly in case she cleaned it and the cleaning product is still on screen if not you will need to get the screen profesionally polished goto a tv repair shop and these should tell you who to call hope this is some help to you but their isnt much you can do yourself
Nov 18, 2007 | Toshiba 46HM95 46" HDTV
My grandson spilled some water which got into my mitsibishi tv and created a black spot in the lower left hand corner. How can i fix this?
Take it apart and clean the dried water spots off. Its hard to say if it will work but that's the first thing I would try.
Jul 30, 2011 | Mitsubishi WD-62525 62" Rear Projection...
The lower left hand corner of the screen is turning blue
catually is problum is related with blue lcd & blue polizer but first you clean the optical unit if the problum gon then ok other wise must chang blue lcd & blue polorize with uv filter plese contect to your nearst sony service centre
Feb 05, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Spots on Hitachi 53SBX01BA
green tube has problem maybe bugs if your lucky and lens has to be removed. If your a novice at tv repair call a service center
Apr 29, 2009 | Hitachi 53SBX59B 53" Rear Projection...
TOSHIBA 50H72 50IN. REAR PROJECTION TV BLUE COVERGANCE PROBLEM
you have a convergence ampliphier ic failing that will need to be changed and then adjusted
average repair cost for this are 280.00 to 320.00
Jan 20, 2009 | Toshiba 50H72 50" Rear Projection...
Hazy yellow spot in the left lower corner of the screen
It could be a cob web inside the tv or something laying on one of the guns, like a dead bug. If it's a cob web, you should be able to move the tv a little side to side and see it change from the moving air current. I would remove the back and vacuum off the lenses of the guns and look for cob webs. It's safe to touch and clean the lenses, just don't touch any electronics.If this doesn't fix it, it's probably fluid starting to cloud up in the guns or IC chip problems.
Jan 08, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Yellowish spot on the lower left hand corner of tv screen
Good Day, There is a device that can be used to correct your concerns. Symptoms can be correct by EE PROM CORRECTION TOOL:
LSUQ0100. Instructions included. Try calling 1-800-458-6053. It's under $100.00 and takes about 1 hour from start to finish. Good Luck, big IRISH.
Jul 07, 2008 | Panasonic PT-52LCX65 44" HDTV
Smudge marks???
If they are grease marks you can use a warm water a soft cloth like a t-shirt and little dish washing liquid. Gentley wipe the area only stroking down or up--- NEVER SIDE TO SIDE---. Have a dry cloth ready if you drip water down the screen. Now if those are scuff marks, your done, they cannot be removed. They are like the old record albums with the grooves, once the grooves get distorted that's it. Good luck.
May 07, 2008 | Toshiba 46H84 46" Rear Projection...
Televison & Video Logo
238 people viewed this question
Top Televison & Video Experts
