I have a model LAT9704 washer. When running the Regular Fabrics or Permanent Press the cycle the machine stops after the wash cycle. It will only run the rinse and spin cycles if the dial is turned to delicates and then pulled.
I have an older top load model. I can't find a model number, sorry. basic superload capacity, 8...
(More)
I have an older top load model. I can't find a model number, sorry. basic superload capacity, 8 cycles. Problem: Started a load. drum filled and then the machine shut down. Totally unresponsive to cycle chnages, on/off. Similar to a blown fuse only the outlet still works. Thoughts?
Bosch model #WFMC4301UC/03 front load, over a year old. Water appears after cycle in additive...
(More)
Bosch model #WFMC4301UC/03 front load, over a year old. Water appears after cycle in additive containers and sits. We have not been using bleach or additives. No way to drain out. Interior does not seem to dry out well, mold is forming on rubber ring around door.
