Question about Sewing Machines
Illusive manuals Have a Sears Kenmore sewing machhine, model no. 148-11010. can't find an instruction or maintenance manual for it. Can you help?
  • jj203 Jan 08, 2008
    I have a sears kenmore sewing machine model 148.14220, and I also cannot find the manual anywhere online. I'd definitely appreciate some advice as to where to find it.
    thanks.
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
SOURCE: Kenmore sewing machine manual for model # 148 12080. (older)
i have a older kenmore sewing machine model #148.19370
Posted on Sep 17, 2008
louislevel_2
  • 374 Answers
SOURCE: need manual for Kenmore sewing machine, model 148-600.
hi! there, since there no model you can relay on this basic set up an old mechanical sewing machine,set your upper thread as shown65a8465.jpgfollow the red loop thread from sppol to needle,then lift needle cover plate take bobbins and follow bobbins thread directionec848a5.jpgthreads inside bobbin clockwise rotation when you pull outthe insert bobbin to shuttle race casas shown
hold bobbin like this 33ea7ef.jpginsert
this to shutttle race case as shown ignore arrow
ebd49c7.jpgthen
after inseting bobbins closed needle plate cover
manually rorate hand wheel to hook up lower thread bobbin by upper thread bobbin if two thread appear on plate needle adjust tension dial to # 3 to 4 and stich dial to # 12 this for straight stich try sew manually first to observe thread under bobbins if free rotate and no accumulation of thread loop you sew w/ foot pedal or push buttin..happy sewing and have a nice day thanks
Posted on Mar 31, 2009
SOURCE: Manual for Kenmore sewing machine, model 385.12812690
So far I've only been able to find this page. It's $8.00 to download. Considerably cheaper than a new machine!
http://www.sewconsult.com/kenmore_instruction_manual_385_oce_type1.htm
Hope it helps.
Posted on Apr 02, 2009
SOURCE: 1964 sears suburban 725 riding tractor model # 917.60634 manual. Sears Kenmore vintage sewing machine manual model# 148.12071.
go to www.sears.pammar.net for a few bucks he will send you the manual in a pdf. format
newbeginning1983@yahoo.com
Posted on Apr 04, 2009
Manual/Instructions for a Kenmore 12 model 385-81512. Hello, I was given this sewing machine by a close friend without the manual and I absolutely cannot find any information on it. Please help!! Thank...
You may try contacting Sears. They have manuals for the 81510 and 81514, so one of those may be close enough to your machine. Usually, the only difference between models may be the number of decorative stitches, a couple extra options, or even the number of accessories, etc.
Kenmore 385 sewing machine manuals
Sep 17, 2017 | Kenmore Sewing Machines
Looking for a users manual for a Sears Kenmore sewing machine model 158.120, not a parts manual.
I would first try Google and ask for service manual for your model. A close model match may do the trick as usually very little variation in same model series. Also, if you locate a Sears service center nearby, they may be able to help you find or instruct you in what you need . Good hunting
Jan 03, 2017 | Kenmore Sewing Machines
I NEED THE OWNER MANUAL FOR MODEL # 15818034.
Sears Parts Direct has a portion of the Service manual for the Kenmore 15818034 here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Sewing-Machine-Parts/user-manuals/manual-downloads/Model-15818034/0582/1200000?modelNumber=15818034&diagramPageId=&documentId= . However, the owner's manual for the Kenmore 158.1803 should help you since it is from the same line of sewing machines. This manual is available from SewUsa here: http://www.sewusa.com/Sewing_Machine_Manuals/Kenmore_Manuals/1803_Instruction_Manual.htm . It's also available from Sewing Parts Online here: http://www.sewingpartsonline.com/instruction-manual-kenmore-158-18030.aspx .
I hope this helps.
Feb 03, 2016 | Kenmore Sewing Machines
Need manual: Kenmore sewing machine 158.9
Those books are long since out of print. Try contacting sewing machine stores who stock old instruction books. Many shops do this. Or try eBay.
http://shop.ebay.com/i.html?_nkw=instruction+book+kenmore+sewing&_sacat=0&_trksid=p3286.m270.l1313&_odkw=instruction+book+sears+kenmore+sewing&_osacat=0
Jan 24, 2010 | Sewing Machines
E1, E2 error messages after needle breaks. Cleaned everything as good as possible, still getting message. I have a Kenmore Model 385.19233
Theirs a problem with the fuse on those machines. The e1 indicates that a fuse has been blown. check out the link for more details.
http://www.sewingmachineryrepair.com/forums/index.php?topic=79.0
Aug 31, 2009 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
132 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
