Question about Dell Photo 964 All-In-One InkJet Printer
Dell Photo AIO 966
I just got this printer, and it is soooo noisy when it pulls in a sheet of paper to print. Prints quietly, but sounds like a major paper jam when it pulls it in to print. It has done it since day one. I just thought maybe it is supposed to be loud?
Thanks if y'all know anything about this.
    Problem Solver:
  • 9 Answers
Yeah thats just how it is hun
i have 926 its a little noisy but aw well
as long as it prints good
Posted on Jan 07, 2008
My printer has worked with many computers. But my HP Probook 64 won't drive it. Can you help me find a driver for this printer, mfd in 2007? Thank you / John
PDF]Dell Photo All-in-One 966
www.dell.com/downloads/emea/products/printer/966_en.pdf
DellPrint/Copy/Scan/Fax ... minute (ppm) mono and 23ppm colour, Dell's fastest All-in-One inkjet is designed for maximum ... drivers purchased with the AIO 966.
Dell Photo All-in-One Printer 966, v.G16-EN-x64, A02 ' Dell ...
www.dell.com/support/home/us/.../Drivers/DriversDetails?driverId...
DellNov 3, 2011 - This package contains Dell All-In-One Printer 966 drivers for Windows XP 64-bit and Vista 64-bit. Once downloaded and executed the driver ...
966 Personal All-in-One Printer Driver Downloads, Set ... - Dell
www.dell.com/support/Article/us/en/19/266187/EN
DellJump to Printing using a Bluetooth Connection - Once the user guide is open, click the plus <+> sign next to Dell Photo All-In-One Printer 966 User's Guide ...
Dell 966 All in One Color Printer Scanner Fax Copier
Dec 30, 2015 | Dell Photo 966 All In One Print Copy Fax
Dell 966 aio printer....paper jam and I cannot release paper from roller. Is there a way to release roller?
Have you read the Manual on paper removal? It mentions a rear panel that can be removed. That might free up the rollers:
If the paper jam is near the paper input tray:
1. Remove the paper tray.
2. Pull firmly on the paper to remove it.
3. Replace the paper tray.
4. Press the Select button .
5. Resend your print job to print any missing pages.
If the paper jam is not visible:
1. Turn off the printer.
2. Lift the printer unit.
3. Firmly grasp the paper, and gently pull it from the printer.
4. Close the printer unit.
5. Turn on the printer, and print the document again.
If the jam is located in the duplex unit or near the rear access door:
1. If you have a duplex unit, remove it.
2. Open the rear access door.
4. Close the rear access door.
5. Re-install the duplex unit.
6. Press the Select button to continue printing.
If the paper jam occurs near the ADF:
1. Lift the ADF cover located to the left of the ADF input tray.
2. Firmly grasp the paper, and then gently pull it from the printer.
3. Close the ADF cover.
Aug 28, 2013 | Dell 966 All-In-One InkJet Printer
How can i get a installation disk for AIO DELL
You can download the package from Dell:
http://support.dell.com/support/downloads/format.aspx?c=us&l=en&s=gen&SystemID=PRN_ALL_A966&servicetag=&os=WW1&osl=en&deviceid=11887&libid=40&dateid=-1&typeid=-1&formatid=-1&source=-1&catid=&impid=&typecnt=0&vercnt=3&releaseid=R165317
Aug 25, 2011 | Dell Photo AIO Printer 966
Dell AIO 966 printer printer busy signal won't print when docs in queue
Lots of reasons for this but normally down to paper size mismatch, paper out or wrong paper tray. Check the display on the printer.
Jan 30, 2010 | Dell Photo 964 All-In-One InkJet Printer
Dell Photo 966 AIO won't print after trying to download Adobe 9
You need to restore your computer to a date previous to your Adobe 9 install. Click the following:
Start-Programs-Accessories-System Tools-System Restore. Choose an available date prior to the date you installed the problematic software.
Nov 07, 2009 | Dell 966 All-In-One InkJet Printer
Printing problem
uninstall software and reinstall
Jul 06, 2009 | Dell 966 All-In-One InkJet Printer
Dell Photo 966
Since when this problem arised.
Since when the printer not picking up paper from tray or sheet feeder.
Check if the Cover are firmly closed, also look out for any piece of paper jammed the printer.
If it is ok, then check to move the carriage of cartridge/roller and clean it out if you can.
The spring attached to the tray also need to be checked, sometime putting paper, it get stuck.
Let me know if I can assist you further.
Sep 28, 2008 | Dell 924 All-in-One InkJet Printer
Lexmark x1180
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Nov 13, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Black ink won't print,just the color ink prints. It's a Brother MFC-3240C thanks in advance
You must run a clean cycle after installing a new cartridge.
Try running a clean cycle and see if that relieves the problem. I just had the same problem on a MFC 210C and called Brother. That is what they had me do and now it is working fine.
Oct 28, 2007 | Brother MFC 210C All-In-One InkJet Printer
Dell Photo 964 All-In-One InkJet Printer Logo
110 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
