Home | Compaq | Presario 700 (470024-192) PC Notebook | How you transfer dat...
Compaq Presario 700  PC Notebook
Problem for Compaq Presario 700 (470024-192) PC Notebook
How you transfer data from laptop to
By jabraham76 on Nov 10, 2009
How you transfer data from laptop to desktop? Is there any utility available?
Solution #1
posted on Nov 10, 2009
Not Rated)
pradeep1985
Rank: Wiz  Computer Hardware  Expert
Rating: 80%, 50 votes
Depending on what you have available these are some of the options:
1. If you have a home network setup, you can just transfer the files from the desktop to the laptop through Network Places/Neighborhood.
2. If both laptop and desktop have ethernet/network ports available, you can use a crossover cable and create a simple network to transfer files between the two machines.
3. You can buy a USB Enclosure drive and mount the desktop's hard drive to use it as an external hard drive. Make sure to get one that mentions 3.5" drives at least - those are for hard drive sizes. They also have those USB to IDE adapters that you can buy instead. These will have no cases for them. You just plug in the hard drive and connect the other end to the laptop's available USB port (preferably USB 2.0 for higher speed).
Was this helpful?
Yes
No
Solution #2
Not Rated)
rylee_smith
Rank: Guru  Computer Hardware  Expert
Rating: 87%, 955 votes
Hi
Thanks for using FixYa. You can connect the Laptop with your Desktop using USB cable or Memory Stick and transfer the data. You can also write the data on a CD and then transfer it to desktop.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Was this helpful?
Yes
No
Popular Solutions for Compaq Presario 700 PC
Questions and Unsolved Problems for Compaq Presario 700 PC
Do you recommend Compaq Presario 700 (470024-192) PC Notebook?
Answer
Answer
Need driver for HP Compaq Presario C773TU for windows Vista or Win7
Answer
hinges cover crack , lcd ok... hinge brackets broken
Answer
I have lost audio on my laptop, I have tried to reinstall drivers, done system recovery 3 times and... (More)
Answer
i wanna reset to factory settings on my compaq presario 700
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Compaq Presario 700 PC...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
