Question about E-Machines T5048 (7136) PC Desktop
CPU fan races
Upon launching a new application the cpu fan races for about 30 seconds and then slow down to normal speed
This creates abjectionable noise.
I await any suggested fixes as this appears abnormal and not related to any thermal issues.
reagrds from rogespeed
  • newcrayons Dec 07, 2008
    New out of the box, my fan makes such a constant racket that I'm looking a place to hide the tower so I can talk on the phone or hear tv while it's running. As soon as I can clean up my old Compaq, I'm going back to that!
  • 37 Answers
Thanks bigunit12 - as I suspected, no real concern
expect the noise is a pain.
I do think the HS might be marginal and so I shall replace sometime with a higher capacity model, also maybe increase fan flow capacity and add a case hot air extractor fan.
Just to make sure
Posted on Jan 08, 2008
I've go the same problem on the same model but it's more sporadic in running full speed. It is quite annyoing too
Posted on Mar 09, 2008
It's normal. You probably have some type of cool and quiet technology. When you open a program, the cpu runs harder and hotter for that period. So, your fan speeds up to keep the cpu cool. Without this technology your fan would run full bore at all times.
Posted on Jan 07, 2008
How do I access the BIOS settings for the P5LP-LE motherboard. The startup key says to press F1, but pressing F1 does nothing.
The instructions say:
"Hold down the F1 key during the startup process and enter BIOS setup to re-enter/reset any custom BIOS settings." I would also try hitting the F1 key multiple times from the very turn on of the computer because the key may have to register at some point after turning on.
Try clearing the CMOS settings as explained on this page, it should clear out any passwords and will set the BIOS settings back to factory settings.
HP and Compaq Desktop PCs Motherboard Specifications P5LP LE Lithium
As for "The CPU fan runs normally on boot, but as soon as the Windows flash screen comes up, the CPU fan slows way down."
This is quite normal. On start-up the temperature of the CPU is not being read, when the flash screen comes up just happens to be the same time that the computer recognizes that the CPU is cold and doesn't need to be cooled.
On the "Then the installation program starts running and the CPU Fan speed starts fluctuating wildly from slow to extremely fast."
This could be normal as when files are read from a DVD the CPU doesn't work hard, but when it unpacks the files or does calculations it does work hard. Or it could be that the thermal paste between the CPU and the heat sink is not correct. Either dry , not making contact, or even too much. If the heat is not being transferred that would also explain the shut-down.
Nov 11, 2016 | Computers & Internet
Why will my fan not run during use but i hear it when the computer powers up?
Fans, mainly the CPU fan, have a speed control which slows the fan down. This is usually controlled by the BIOS. The speed is based on temperature of the CPU. If it's cool with little load the CPU fan will run very slowly and you won't be able to hear it. On startup all fans ramp up to 100% until the BIOS takes over and slows the fan down.
Jul 27, 2014 | Dell Inspiron 531s Desktop Computer
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
My computer fan afb0712hhd. when i turn it on the fan runs fast for a few seconds, then runs slow and the cycle continues. can you tell what is wrong?
Your fan is following the heat pattern of the CPU. As your computer does more stuff, like runs more applications, it has to work harder to make everything go. This creates heat that needs to be cooled by the fan. The fan usually has 2 settings, low, and high. When the CPU reaches a certain temperature the fan will switch into high gear to help cool it down.
Mar 29, 2011 | Computers & Internet
When i turn on my dell dim 8400 the fan races very fast i have to power down and start back up sometimes it takes 2 or three times then starts to work but after awhile it freezes up or if i wiggle the...
Normally, when the fan gets loud and races, it means that the CPU is getting too hot. The normal fault is that the case and ventilation block on the CPU is full of dust.
Disconnect the tower and take it outside or somewhere where a bit of a mess isn't a problem. Open the tower and look inside. Is it full of dust?
Using a dry soft bristle paint brush, CAREFULLY liberate any dust and fluff, if you have a hoover, brush to the hoover to remove dust.
The CPU is under a big metal blob with a fan on the top, Underneath the fan there are a load of ventilation duct in a metal block. See if you can clean them out, compressed air in a can is a good way. In conjunction with the brush.
Check all the vents and fans are clear of dust, including the PSU.
Once done, try it again, does it still race / lockup / close down.
If so, then you may need to renew the heat dispersal grease which is placed between the CPU and the Heat sink (Vented metal block under the fan).
The best place to find how to do that is look on Youtube for CPU changing / fitting / upgrading.
Mar 26, 2011 | Dell Dimension 8400 PC Desktop
My Toshiba P35-S611 shuts down without warning a short time (2 min-45 min) after it boots up. The battery isn't hot but the heat dissipation fins in the back are very hot.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
May 09, 2010 | Toshiba Satellite P35-S611 Notebook
Zalman VF2000 LED fan starts then stops right after boot
Sounds like a defective fan, something having to do with the thermal probe, it causes the fan to speed up when cpu gets hot and to slow down when the cpu is cool. I suggest returning it for another one
Feb 10, 2010 | Computers & Internet
Fan races slows down races again
the fan is supposed to speed up when the processor gets too hot, then slow down after it has cooled a bit. if it is running more than normal, maybe you should take the cover off the pc and clean the dust out of the cpu heatsink.
Dec 27, 2009 | Gateway (8006549) Heatsink With Fan
Cooling fan intermittantly speeds up.
This is normal
Your fan speeds up and slows down in response to temperature inside the computer. More so the CPU.
I would suggest getting a can of compressed air made for computers
take it outside, take of the side and blow all the gunk out of there, Really go to town around the fan (you might want to wear eye protection)
Aug 25, 2009 | HP Computers & Internet
CPU fan races
turn up the task manager to monitor the cpu load. use ctrl shift esc to bring it up. now open up an application. see as the cpu meter goes from low to full green (high).. then check if the fan also speeds up. i guess you have a cmos setup on the motherboard that monitors cpu load and speeds up the fan.
as for the usb -speaker, please explain further..
May 20, 2008 | Car Audio & Video
E-Machines T5048 (7136) PC Desktop Logo
297 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
