Chain Saws
Problem for Chain Saws
Generic problem for all Chain Saws
I have a stihl ts350 demosaw I'm not get...
By philcauthen on Nov 10, 2009
I have a stihl ts350 demo saw I'm not getting any fire replaced spark plug no help,took off flywhell thought maybe the points where bad. It's a sealed system with 2 wires with no disconect.
Comments:
Nov 10, 2009
- no spark
Nov 11, 2009
- no spark
Clarification Request
Posted by rwvanlue on Nov 10, 2009
TS350 has an electronic ignition system. When you say 'no fire', do you meen there is no spark at the plug, or do you meen you pull the rope with no results from the engine trying to start.
Best Solution
posted on Nov 11, 2009
Very Helpful)
Dolfoff
Rank: Guru
Rating: 95%, 68 votes
Follow the two wires and look for scuffs broken or worn insulation. Sometimes easy to find by turning off the garage lights and pulling the rope (arcs can be seen easier this way). The wires use common ground to kill the spark through the switch. These wires are known to wear through the insulation after years of use and they inadvertantly ground out the ignition coils. Repair the wires with heat-shrink tubing or electrical tape as needed. Or replace the wires entirely if they are in very poor condition.
Hope this is helpful,
Dolf-
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" thanks for the help " - philcauthen
Popular Solutions for Chain Saws
Questions and Unsolved Problems for Chain Saws
Answer
flymo 2200 chain oil leak when machine is running
Answer
master control lever not working properly.
Answer
I need a handle bracket for my Remington 8' Electrict Telescoping Pole Saw
Answer
how to install a new tension screw on a husqavarna 365
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Chain Saws Experts
Top Garden & Power Tool Repair
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
