Broken drive rubber band
The rubber band from the motor to move the CD bay out/in has perished and now slips. How do yo get a replacement
    Genius:
  • 1,226 Answers
Buy a rubber band at the market
Posted on Jan 07, 2008
  • Emelio Navaja
    Emelio Navaja Jan 07, 2008
    Or maybe you should inquire the nearest repair center for a replace of that rubber band.
I have an Aiwa NSX-R20 and the cd changer won't move so I cannot load 3 discs and if I close the unit it opens again.Please help
Mine did the same, look underneath the tray when open, you'll see a rubber drive belt which has probably perished. You may have to remove the cd carousel, one screw in the middle, for access. Replaced mine with an elastic band and am back in business.
Sep 06, 2017 | Aiwa Audio Players & Recorders
The "rubber band" for moving
This is the belt that drives the loading mechanism and if the size is taken to a store you can buy accordingly. Now the belt is normally run over the pulley of the motor and the drive pulley and is not difficult to be threaded.
May 12, 2011 | Audio Players & Recorders
The cd tray will not open.
The drive motor or rubber band has gone bad. Unless you can get it to eject by lightly prying or tapping the top of the unit you will need to disassemble it and either replace the worn out rubber band that moves the tray or the drive motor that moves the plastic gears that operate the rubber band.
Mar 08, 2011 | Bose (321GS) System
Had rubber band fitted, instead of metal band, when new. Rubber watch band is perished and broken. I need a new metal band, Please. The model watch is :- Sector 700 2653700015
ebay is your friend, look there and you should find one.
Please dont forget to vote this answer was helpful.
Many thanks
Mar 04, 2011 | Sector 700 2653700025 Watch
Cd tray will not open. Is there a quick fix for this I can do myself?
If when ejecting the disc tray you can hear motor noise from inside but the tray doesn't open up...
1. Unplug the unit from the A.C. outlet
2. Remove top cover
3. Look for rubber drive belt that causes load/unloading tray to move in and out.
4. Replace with new rubber belt..not a rubber band but a rubber belt.
Nov 08, 2010 | American Audio CDI-100 Personal CD Player
Unable to open cd tray on Philips DVDR7300H message reads :bolcked"
I just had the same problem. I opened up my player (hex key, allen wrench), removed the disc drive, the magnetic cover (regular crosshead screws) and the slide tray. The rubber band that connects to the motor to push the tray out was broken. I replaced the rubber band, put it back together and it worked perfectly. Hope that helps.
Oct 23, 2010 | Philips Televison & Video
The CD tray wont open on my xbox 360
Do not attempt this fix ur self if your not familar with the dvd drive parts . The problem is the band on the dvd drive motor under the disc tray is slipping . To fix this use a rubber band. Step 1 Remove your dvd drive unscrew all 4 screws , 2 remove green board carefully . 3 unscrew any screw under the disc tray and remove this disc tray , step 4 get a rubber band a small rubber band and replace the band thats slipping put your dvd drive back together and ur good to go . If you do NOT want to do this your self you can go to Solomodsdotcom and they will fix the dvd drive for you . Google search to to replace rubber band on 360 dvd drive . You tube has videos on how to but i wouldnt recommend doing it your self if your not familiar with the parts .
Aug 07, 2010 | Microsoft Xbox 360 Console
My car cd player won't play cd just keeps flashing load?
THERE MAY BE A RUBBER BAND TYPE DRIVE BELT THAT IS BROKEN OR SLIPPING. YOU WOULD HAVE TO DISMANTEL THE CD UNIT TO CHECK THIS OUT. RUBBER BAND TYPE DRIVE BELTS ARE ALSO USED ON MOST VIDEO CAMERAS , IF YOURS HAS STOPPED WORKING TAKE IT APART AND REPLACE IT TO RESTORE THE CAMERA TO WORKING CONDITION.
Mar 13, 2010 | 2005 Toyota Highlander
CD-RW/DVD-ROM (Combo) button to open/close has broken. Right click on "my computer>optical drive>eject causes noise but panel does not open. Purchased replacement, but wrong size. Cannot find...
Hi
Issue is most likely a broken cable? between the motor and a gear that transfers the movement of the motor to the tray.
So you would have to take the cd drive apart and possibly replace the rubber band? like cable.
Dec 21, 2009 | Gateway 300 X PC Desktop
Looks like thin black rubber band broken...I found it after manually opening the door to the stuck drive tray...is this easily replaced?
Fairly easy to do if have the tools to get the case off and have a band the right size. However for the sake of few £/$ you might as just buy a new drive.
Dec 13, 2009 | Optorite (dd0203 blk) DVD±RW Burner
677 people viewed this question
 Grubhead
Grubhead
