1 Chrome Rail (for attachment to Worktop)
4 Self-Tapping Screws (to attach chrome rail)
1 CO2 Cylinder Support Stand
1 CO2 Cylinder (empty)
1 CO2 Regulator (high/low pressure gauges)
1 CO2 Air Line Hose (red)
2 CO2 Air Line Hose Connectors (black)
1 Beer Keg Coupler
1 Beer Tower Unit (complete with faucet, hose and wing nut)
1 Rubber Washer (to be installed inside wing nut)
1 Beer Tower (Quick Connect) Bayonet Attachment (beer tower installation)
4 Machine Screws (to attach bayonet to beer tower)
1 Gasket (beer tower base)
1 Pull Handle (beer tower faucet)
1 Beer Keg Stand (required for 30 liter keg installations only)
1 Protective Plate (refrigerator cabinet floor)
2 Cantilever Wire Shelves (conversion to all refrigerator application)
1 Chill 'n Tap Exterior Cabinet Plug (located on worktop)
1 CO2 Air Line Hose Plug (located exterior rear cabinet)
1 Plastic Drip Tray (2 piece)
1. Remove Worktop: Using a Phillips Screwdriver, remove the
three screws located on the front underside edge of the
worktop and the three screws located at the rear (back)
side of the worktop.
See Fig's. 1 & 2
Remove the worktop from the cabinet and position the
worktop on top of the cabinet so that the front corners
are staggered across the front corners of the cabinet.
2. Installation of Top Rail: Attach the chrome rail to the work
top using four self-tapping screws from the underside of the
worktop through the pre-drilled holes. (attach the front ends
of the rail first)
3. Re-Install Wo r k t o p : Install the front of the worktop onto the
cabinet, then lower the rear side of the worktop over the
backside of the cabinet. Secure using the same screws
removed earlier. (the smaller screws at the front the larger
screws at the rear)
4. Installation of CO2 Cylinder Support: Install the cylinder
support onto the four studs located on the exterior back
wall of the cabinet. (no tools required) Align the holes in
the cylinder support with the studs and push down firmly.
See Fig. 3
5. Installation of CO2 Cylinder: Install your " fully charged"
CO2 cylinder into the support stand. IMPORTANT NOTICE:
ALWAYS EXERCISE EXTREME CAUTION WHEN
HANDLING PRESSURIZED C02 CYLINDERS:
6. Installation of C02 Regulator: Attach the CO2 Regulator to
the C02 cylinder by screwing the regulator nut onto cylinder
valve and tighten (snug) using an adjustable wrench.
7. Installation of C02 Air Line Hose to Regulator: Attach one
end of the (red) air line hose to the hose barb connection
on the CO2 regulator. Secure hose by using one of the two
(self locking) black plastic snap on clamps provided.
(use pliers to snap the clamp tight to assure that there are
no leaks)
See Fig. 5
Fig. 1
Fig. 2
Fig. 3
Fig. 4
Fig. 5
CHI 1. Remove Worktop: Using a Phillips Screwdriver, remove the three screws located on the front underside edge of the worktop and the three screws located at the rear (back) side of the worktop. See Fig's. 1 & 2 Remove the worktop from the cabinet and position the worktop on top of the cabinet so that the front corners are staggered across the front corners of the cabinet. 2. Installation of Top Rail: Attach the chrome rail to the work top using four self-tapping screws from the underside of the worktop through the pre-drilled holes. (attach the front ends of the rail first) 3. Re-Install Wo r k t o p : Install the front of the worktop onto the cabinet, then lower the rear side of the worktop over the backside of the cabinet. Secure using the same screws removed earlier. (the smaller screws at the front the larger screws at the rear) 4. Installation of CO2 Cylinder Support: Install the cylinder support onto the four studs located on the exterior back wall of the cabinet. (no tools required) Align the holes in the cylinder support with the studs and push down firmly. See Fig. 3 5. Installation of CO2 Cylinder: Install your " fully charged" CO2 cylinder into the support stand. IMPORTANT NOTICE: ALWAYS EXERCISE EXTREME CAUTION WHEN HANDLING PRESSURIZED C02 CYLINDERS: 6. Installation of C02 Regulator: Attach the CO2 Regulator to the C02 cylinder by screwing the regulator nut onto cylinder valve and tighten (snug) using an adjustable wrench. 7. Installation of C02 Air Line Hose to Regulator: Attach one end of the (red) air line hose to the hose barb connection on the CO2 regulator. Secure hose by using one of the two (self locking) black plastic snap on clamps provided. (use pliers to snap the clamp tight to assure that there are no leaks) See Fig. 5 Fig. 1 Fig. 2 Fig. 3 Fig. 4 Fig. 5 LL'N TAP ACCESSORIES (included with this unit)
every time i pull lager from pump it froths up very bad i wondered if it had something to do with...
(More)
every time i pull lager from pump it froths up very bad i wondered if it had something to do with the kegs been outside
My kegger has been working fine for years, but has a noise that keeps getting worse. I don't think...
(More)
My kegger has been working fine for years, but has a noise that keeps getting worse. I don't think there is a cooling problem - but wonder if there is there a pump going bad.
My Danby beer tap has been making a humming sound like every 10 minutes. It last only 15 to 20...
(More)
My Danby beer tap has been making a humming sound like every 10 minutes. It last only 15 to 20 seconds. It's coming from the motor compartment. Any help??
