Question about Hamilton Beach 40729 Espresso Machine
Hamilton Beach Espresso Machine not working
We have a Hamilton beach espresso machine that has a steamer that stopped working. We don't know if it's plugged or has just stopped working.
  • texastrees May 14, 2009
    I have the same problem!
  • 4 Answers
I have the same issue -- machine is NOT clogged. I've torn the think apart, and looking at the way it is designed I am thinking that the pressure relief valve (at least that is what it appears to be) is malfunctioning.
The steamer will work briefly, but runs out of steam almost immediately. If your machine is having a similar problem, I suggest that you open it up and look at how it works (there are two screws on the top under the door for the scoop. You've got to drill out the cover caps to get to the screws underneath -- at least that is how I got them out...they covers are really long plastic plugs and trying to get them out with a thin screwdriver did not work -- but using a drill bit pulled them right out).
I don't know where to find a replacement valve -- sorry.
Posted on Mar 13, 2010
    Problem Solver:
  • 18 Answers
When you turn on the steam switch, does the steam light turn on, then eventually turn off when it comes up to temp?
If so, your wand may be plugged with a dried plug. I have resolved this by pouring boiling water into my steaming pitcher and soaking the wand for several minutes, then fire up the machine and heat for steam, then blast it out.
Might take a few tries. You may also need to run a thin wire, like a guitar string, up the wand to help free up the plug.
Posted on Jun 11, 2009
If it's plugged right at the end of the nozzle, a push-pin can clear it. The real solution is that when you finish steaming the milk you need to flush it out while cleaning the machine: wipe the nozzle first, then open the valve long enough to blow out any milk that got into the end of the nozzle.
Posted on Jan 22, 2010
2 Suggested Answers
  • 4 Answers
SOURCE: How to open a Hamilton Beach 40729 Espresso machine
Easy to open. It is servicable if you have enough ingenuity and can find some generic parts to fit, but certainly not designed with servicability in mind -- the thing was obviously build as a "throw away". There is plenty of space in there for generic parts, but keep safety in mind since you are dealing with electrical parts that get hot and operate under pressure!
First, you need to remove the little plug caps that cover the two screws under the door for the scoop / emergency tamper (sorry, but IMHO a more substantial tamper is a requirement!). I found that the only sane way to remove these caps is with a drill. Carefully drill into the caps. The drill bit will catch, and you can pull the plug right out.
Next you need to deal with the odd screws. They are triangle, so even if you are a serious electronics guy like myself you are probably not going to have that screw bit. No problem though, use a very small flathead screwdriver that fits as closely in one side of the triangle as possible. It will easily remove the screw (and reinsert when you are done)
Once the screws are out, gently pry the top off as indicated by john. The plastic top should have two catches in the front near the edges, and two catches on the sides about mid-way back.
Posted on Mar 15, 2010
My Hamilton Beach just stopped working
Have you tried cleaning it? Try runing equal parts vinegar and water through your coffee maker. Then flush it by running to cycles of water through it afterward.
Nov 05, 2017 | Hamilton Beach Coffee Makers & Espresso...
My Hamilton Beach 67800 just stopped working
Great - so just what did you check?!?!?!?!?!?!!??!!?!?
Apr 27, 2017 | Hamilton Beach Coffee Makers & Espresso...
I need an instruction manual.
First try the Use and Care Guide search on the Hamilton Beach site: Hamilton Beach Good Thinking. If that does not work becaust the model is too old then do a Google search for Hamilton Beach (your model number) owner's manual (or use and care guide).
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Mar 23, 2016 | Hamilton Beach Coffee Makers & Espresso...
I am curious to know if this cooker can be used in India
You will need an adapter for the plug so that 110 volts and also is a plug converter
Dec 13, 2009 | Hamilton Beach 37532 20-Cup Rice Cooker
Need to replace the plastic lid. Anyone know
Call Hamilton Beach customer service. They usually will send the part free, you just pay shipping ($5.00 or less). 1-800-851-8900. I love hamilton beach. They love their customers and stand behind their products. 1-800-851-8900. Also check out hamilton beach.com and look up your product. most regular parts can be ordered on line thru hamilton beach. Good luck to ya.......katherine
Apr 26, 2009 | Hamilton Beach BrewStation 47214 Coffee...
Lost instructions
Do a websearch for Hamilton Beach User Guide 840112600, and you will find a website with a pdf copy to download.
Mar 16, 2009 | Hamilton Beach 40729 Espresso Machine
My Hamilton Beach 40729 will not brew! The motor hums and I can get water to pump through the steamer. Please help!
This unit does not use the pump to generate steam, so if the pump is bad (motor works but the pump it drives does not transfer water) you will get steam but no water through the head to the portafilter.
The unit is not user serviceable and at $68 to buy a new one, it is for the most part, disposable.
The pumps on this unit do not like to be run dry as they rely on water as a lubricant. Without water in the reservoir, the pump may fail in a short running time.
Feb 21, 2009 | Hamilton Beach 40714 Espresso Machine
No steam!
Ran into the same problem on mine just after using the steam, so it definetely wasn't clogged... hope this helps.
Just try running the expresso maker through a full cycle and then try the steam again. Not sure if the machine air locked or something, but the expresso cycle appeared to get the water flowing again and then it had no trouble producing steam.
Hope it works.
Jan 11, 2008 | Hamilton Beach 40729 Espresso Machine
Hamilton Beach 40729 Espresso Machine Logo
900 people viewed this question
Top Hamilton Beach Coffee Makers & Espresso Machines Experts
Marvin
Marvin
jason
80stech
Are you a Hamilton Beach Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
