Folded picture TV is a little over one year old and the picture has "folded" over on top of itself. About the top 3-4 inches is upside down. Is this a capacitor that has gone bad or is there a bigger issue? Model #27PT5445/37
  • Anonymous Jun 05, 2008
    HEY FIRST TIME ON THIS SITE, THINK IT'S COOL.
    Anyways, I do have the same problem with my model # 20MT4405 magnavox t.v. Anything to tell a newbie at this fixing stuff?
I had this problem,the solution is to replace the 100mf/50v
cap near the vert ic heatzinc. it worked for me!!!!!
Posted on May 31, 2008
  • 89 Answers
The primary suspect here is a defective capacitor at the horizontal deflection circuit. You can also try flexing the board while the tv is on, and try to observe if the problem would disappear even for a second. just to check for any loose solder that usually occurs in a television. !!!Word of caution, !!! The inside of a live TV has several high voltage points that can easily do harm. If you are not comforatable working with such conditions, I suggest to have the unit serviced by a qualified technician.
Posted on Jan 07, 2008
  • 373 Answers
You have a vertical deflection problem and the parts location of the bad ones are C2465 10mfd at 160v and shorted diode at location D6460 part #9340 549 45115 Call Tritronics at 1-800-638-3328. I think they sell to consumers. Parts must be unsolderd and new soldered back in.
Folded prints when duplexing
i would check the duplex pathway for any debris that is stuck there
Jun 11, 2014 | HP LASERJET ENTERPRISE 500 COLOR M551DN
I HAVE A JVC AV27D302: THE PICTURE IS FOLDED OVER
For how many years this TV with you? Most tv now a days after few years of using vertical IC solder started to dry(dry solder) you can try to re-solder or you may check also two capacitors (100uF/35V) for most JVC model has this symptom with this parts changes its electrical characteristics. If still problem persist replace vertical IC. Hope his helps, Good Luck
Feb 14, 2010 | JVC AV27F476 27" TV
Tv picture is shrinking.
Check for dry electrolitic capacitors near the vertical IC
Jun 23, 2009 | Philips 27PT563S 27" TV
LG F700B Lines at top of screen
HEY BUDY
i have same problem (exactly same!!)
see here i hope it is usefull
http://www.fixya.com/support/t2664392-lg_f700b_raster_problem
if it solve your proble please notify me
Feb 09, 2009 | LG Flatron F700B 17" CRT Monitor
Elongated picture on Sylvania 27" Model # SRT2232S
there is a vertical adjustment on the picture tube it's the yoke as it's called but you can adjust it so much..but it does sound like the tube is on it's way out
Aug 28, 2008 | Sylvania 6427TE 27" TV
Elongated picture
There is a bad capacitor in the vertical circuit. If you feel comfortable working inside a set and can solder, update this and I'll try to get the specifics for you.
Dan
TV Picture Reduced to Line across the Middle
This is called field-collapse. Either
1. The problem lies in the vertical deflection voltage-doubler circuit. The usual fault is a single capacitor of 100uF/35V that has failed. It is normally connected to a rectifier diode right at the vertical IC. Replacing the capacitor usually gets it working perfectly again.
or
2. The vertical drive IC has failed.
If you are finicky around technical work, then a reputable local repair shop in your locality should do it quickly for you and charge only labour.
Jan 13, 2008 | Symphonic ST419E TV
Tv problem
Bad capacitor in vertical output IC circuit + check power supply
Last, replace IC.......................T.
Nov 09, 2007 | Philips 27PT6441 27" TV
Sony 27" picture quality
You probably have a leaky or open electrolytic capacitor in the vertical circuit. This will require troubleshooting by a repair specialist, unless you can obtain a diagram and do a little spy work with an oscilloscope
Nov 05, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Horizontal line in my TV.
"Guest" obviously has no idea what he is talking about. There is no such thing as "frame section" and if the vertical IC, ramp generator or vertical hold circuits were bad, you would have no vertical at all. If you mean that there are thin white lines at the top 3 inches of the picture, and the top of the picture seems folded back on itself, it means that the pump-up capacitor is going bad in the vertical output circuit. This is a very easy thing to correct but should be done by a qualified tech.
Sep 01, 2007 | Televison & Video
Televison & Video Logo
249 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
