Question about Sony Playstation 3 (PS3) Console
Audio Issues No audio through my optical output on the PS3 when playing a game. It worked for awhile but not anymore. Works fine for CD, DVD, and BlueRay and while in the menu. Once the game loads, no sound.
  • Anonymous Jan 14, 2008
    The uncharted demo is the only game that will not work, other downloaded media works fine along with all other games that i own.
Check your "Audio settings" in your PS3,you can make changes.I noticed in mine that it pick it up once I connected it,but then I had to go to the settings and set it up.
Posted on Jan 07, 2008
I have no sound through my surround sound when playing ps3
The optical audio out from the TV only works for the TV's tuner, probably. Hook-up optical from Cable/SAT and from PS3 boxes to DVD/Receiver.
Apr 20, 2010 | Pioneer PDP-LX508A 50 in. Plasma TV
Setting audio to optical makes hdmi video not work
Here is the solution - in the audio settings you have to select optical out or it will still use HDMI. Regards, Joe
Feb 13, 2010 | Sony PlayStation 3 Slim Black Console
My marantz DV 9500 doesnt output digital signal for audio cd anymore but outputs audio for dvd,sacd,dvd audio. Does it need servicing
Make sure your playing componet like CD player have a digital output socket. Connect this to a digital port on the amp witk a single RCA or Optical cable if output available on CD. Make sure the digital assingment in amp is set for cd function and corresponding input(example cd plyer connected on dig 4 input on amp, press menu, setup, assignment, go to cd player, make sure setting on dig 4 or change input to dig 4, go to next component to memorise setting.and exit, see manual to assist you) if still no sound take dvd cable for instance that is working and put that in dig 4 port. if that works check in cd player that settings spdif/raw/pcm is correct one for yor digital output if still no sound soun pc board faulty.
Aug 11, 2009 | Marantz DV-9500 DVD Player
No audio
stupid answer but did u check the audio settings in the main menu from the ps3? i reset my ps3 on accident n the audio changed to component but picture stayed on HDMI
Jul 13, 2009 | Sony Playstation 3 (PS3) Console
Simultaneous Optical & HDMI Audio on PS3
I'm almost positive it cannot stream the sound through two outputs by design. However if your TV has a digital optical output you can run it to the TV via HDMI and from the TV to the receiver go with the optical. It shouldn't bother the quality at all being HDMI is also a digital interface, you're just passing it through your TV.
Jan 04, 2009 | Sony Playstation 3 (PS3) Console
you might want to try changing the settings settings just go to sound settings>audio output settings and choose the type of cable you're using sfter that select automatic and press X. if that doesnt solve the problem may be you accidentally chage the BD/DVD audio output format. is locate in BD/DVD Settings change both BD/DVD audio output format (HDMI) and BD Audio Output Format (optical Digital) to linear PCM or viseversa try both to see wich one works.
p.s. it can also be a problem with your sound/ hometheater system.
Apr 25, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Is Yamaha HTR-640 a receiver? Try HDMI from PS3 to receiver or Sony HDTV. If HDMI from PS3 to receiver the you need and HDMI from receiver to out Sony HDTV. You could connect everything to receiver and HDMI out to HDTV. You can not have an HDMI cable AND an optical cable coming out of the PS3, only one or the other.
Dec 30, 2007 | Yamaha HTR-6130 Receiver
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
Audio problem when connecting to a PS3
It seems the Denon and PS3 don't play nice together on DTS. If you take off the DTS setting, then the PS3 will use DD and you'll get surround for games and movies.
Nov 04, 2007 | Denon AVR-1803 Receiver
Optical sound problem
i have the same problem with the RZ-4900AV, it manifests itself when any video application runs through either the optical or coaxial input. in my case it's definitely not the optical cable itself, which works fine on another receiver. optical or coaxial input of audio CD's is fine, but a DVD video on the same DVD player gives the high pitched whine. the same with the PS2 on the optical input, audio CD in the PS2 no problem, PS2 game or DVD video gives the whine... i think, unfortunately, it's a crap receiver... and i solved the problem by buying a RZ-6900AV, which works perfectly in exactly the same environment.
Sep 10, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
