1295 simply indicates that you were in "get you home" mode. 1515 has to do with throttle position sensor fault. Since it was intermittant I'd check for chafed or broken wiring and loose connections
Cost of replacing the front wheel barrens
I'd check corroded wiring on your fuel pump and/or replacing your fuel pump. The sensors can go bad causing the problems you mentioned.
