Kenmore Elite 45986 Front Load Washer
Problem for Kenmore Elite 45986 Front Load Washer
Sears kenmore elite 110.27062606 washer will power
By neal_perkins on Nov 11, 2009
sears kenmore elite 110.27062606 washer will power up can select cycle but will not do anything no codes showing will not lock door just sits there with time showing . Have to unplug to shut it off
Comments:
Nov 11, 2009
- This is a top load model not a front load. Would same apply??
Nov 12, 2009
- OK, good solution as I have had that happen to other machines. However I didi the diagnostics as you suggested and it seemed to clear it. I then unplugged it and replugged it in and started a normal load, the machine was still full of water from last wash it ran and I noticed that the drain pump was not running, took back of and noticed the pump was humming and not running. Took hose off pump and found a steel rod (4" long) from a hair clasp in the pump jamming it. Removed it put hose back on and resumed the cycle , it drained and started filling and now works ok. Just wanted to pass that along as to what I found. And thanks for your help.
Nov 12, 2009
- thanks
Best Solution
posted on Nov 11, 2009
Very Helpful)
charlymonty
Rank: Wiz
Rating: 82%, 204 votes
its the problem of door lock its not getting engaged.the inner latch assembly gears are got cracked or worn out.the door lock assembly needs replacement.its not starting because, till when the door is not closed the washer will not start functioning.and at present the door is not getting locked so the main control board in the washing machine is detecting the door is unlocked so its not starting to function.in some cases the display on the washer shows up with codes but some times no codes comes up.still open the door and check out if some thing is blocking the door to get properly closed.as when the door gets closed you will hear a click if you listen it carefully, if no click sound then its problem in door lock assembly.
the door lock part which you require is a part manufactured by whirlpool company.
so click this link directly to get the required parts
http://www.appliancepartspros.com/part_details.aspx?part_id=3128712&pn_=8181700
also click this link directly
http://www.appliancepartspros.com/part_details.aspx?part_id=3128714&pn_=8181651
if you are not familiar with doing this you can get it done by local washing machine repair technician familiar with this model of machine.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Solution #2
Not Rated)
taran_2005
Rank: Guru
Rating: 88%, 974 votes
Did you try the magnet on the lid lock assembly? Also hold a small piece of metal that is attracted to a magnet on the front/bottom /center of the lid itself to see if you can feel the presence of a magnetic field in the lid.
I just wanted you to try the magnet on the base (lid lock assembly) and a piece of metal on the lid (lid lock striker/catch) but that is OK.The following is the machine control diagnostic routine. Please unplug the machine for 1 minute, then plug it back in. Select ANY button except the start, power or stop buttons, then press and hold it for 3 seconds, release it for 3 seconds, press it for 3 seconds, release it for 3 seconds, press for 3 seconds.
Unfortunately , the most likely failure based on the results as you have described them is the user interface module.The part can be purchased from ANY part supplier using that number though. Now, to make things even more fun, This machine has had problems with both the UI board AND the combination central controller (CCU) motor controller (MCU) board.The manufacturer doesn't even give us techs a way to differentiate a failure of the UI from the CCU/MCU WHEN the system does not respond AT ALL to any user input. We usually have BOTH on hand and the manual basically says "replace one and if that doesnt work, replace the other" Yell
Now, based on MY experience, I have found that the problem is MORE likely to be the UI board in this case , only because there IS power to the UI, since you actually have lights, and this power comes from the CCU/MCU board BUT this fact alone is not enough to make a definitive diagnosis. If you have not seen any errors then that usually means that the lid lock system is ok, because if the boards are working, the controller knows that it sent a lock signal to the lid lock, or that the lid should be closed to progress the cycle but the circuit did not respond favorably, so an error is triggered and displayed on the display, usually "lid" will show on the display in this situation. With NO errors seen, power normal to UI module but NO response from UI module, the CCU/MCU board can be suspected which is where the errors with ALL other parts on the machine are sent, but then of course they are displayed on the UI. This is why we can only narrow the problem down to TWO possibilities in this case, not one.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Popular Solutions for Kenmore Elite 45986 Front Load
Questions and Unsolved Problems for Kenmore Elite 45986 Front Load
Do you recommend Kenmore Elite 45986 Front Load Washer?
Answer
Answer
I have a quietpak 9 front load washer. It won't spin and the clothes stay soaked. F6 flashes on the... (More)
Answer
The machine will go through the whole cycle, and then throws an error code during the final spin.... (More)
Answer
My washer stops mid cycle and doesn't drain the water. The display flashes: F H over and over. How... (More)
Answer
Why won't the agitator of my Kenmore Washing Machine Elite spin?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Kenmore Elite 45986 Front Load...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14910
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
