Canon PIXMA MP780 All-In-One InkJet Printer
Problem for Canon PIXMA MP780 All-In-One InkJet Printer
Where does the waste ink go?
By horst7 on Nov 10, 2009
where does the waste ink go?
It's telling me that it's almost full, but i don't know what to do.
Best Solution
posted on Nov 10, 2009
Very Helpful)
Siouxie
Rank: Guru
Rating: 98%, 74 votes
Here is the link for the Canon website for your product. If you click on the support tab you can put in a question to help you resolve problems.
Here is what I found:
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer.
Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible.
Press the <Stop/Reset> button to cancel the error. You will still be able to print for a short period. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. "We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
I have found out how to reset the counter :-
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button.
(DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button FOUR times
5) Press the Power button to turn the printer off.
This should reset the counter.
The replacement kit for the absorber is
Ink absorber kit (QY5-0146) I am still trying to ascertain exactly where the pad is located.
Hope that will help you.
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
" Thanks much for this info. It will help me decide how to proceed. " - horst7
Solution #2
Very Helpful)
greg_margo
Rank: Guru  Computer Hardware  Expert
Rating: 91%, 710 votes
The waste ink absorber is actually a pad/sponge that absorbs left over ink spray. There's really no precise way to measure the amount of ink these pads hold so when the message first appears, "waste ink absorber is almost full" it's just an estimate.
The workaround for the message is as follows:
Reset ip2000 / 3000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal.
Using the above procedure should clear the message and your printer should function normally afterward. Best of luck and thanks for using Fixya!
Greg
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thanks for these very helpful details! " - horst7
Popular Solutions for Canon PIXMA MP780 All-In-One
Questions and Unsolved Problems for Canon PIXMA MP780 All-In-One
Do you recommend Canon PIXMA MP780 All-In-One InkJet Printer?
Answer
Answer
Hi I have just replaced the ink tanks in my Canon PIXMA MP780 and now the print is very dull. What... (More)
Answer
printer screen displays "check printer press "ok", Pressing OK doesn't do anythin.... (More)
Answer
Printer ask for paper and keeps changing settings.
Answer
When I left for vacation my Pixma780 was working great when I came bach the 3eBK is not printing at... (More)
Answer
Hi there! My scanner is only scanning bits and pieces of an 8 1/2 x 11 page or sometimes it scans... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
