Question about Kenmore 43142 Front Load Washer
Kenmore HE2 frontload washing machine
Unit is less than 2 years old but out of warrenty. Every light on front panel is flashing and door is locked. It will not rinse, spin or even wash. I am in no way mechanically inclined and would just like to, for the moment, get the clothes out so they can be dried and worn. It appears as the barrel doesn't turn.
  • 3109 Jun 17, 2008
    the lights flash and stops washing mid cycle. also very loud when spinning or wash cycle. maybe bearings?
  • helbent55 Jul 15, 2008
    tried turning the machine off.
Unplug the washer, take off the bottom kick plate there should be a pump on the right hand side. with sort of a plug that screw in looks sort of like a pvc pipe. Get a bucket, and place it under the opening, unscrew the opening. there is propably something stuck in there. mine likes to eat socks. empty it out and screw it back in. plug the machine back in and start it up it should work fine. I now put all of my socks is a mesh bag, and check pockets!!!!!!!!!!!!!!!!!
Posted on Aug 13, 2008
    Master:
  • 619 Answers
MOTOR HAMMING REPLACE STARTING CAPACITOR / TEST FIRST BEFORE YOU REPLACE / CHECK ALSO STARTING SWITCH.
Posted on Jan 09, 2008
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
The machine is locked and can't open with clothes washed inside,. Add garment light is on and the time is flashing'
Whirlpool-made Front Loading such as the Kenmore Elite washing machines use a door lock and switch assembly having a tab that can be pulled manually for emergency opening of the door. This tab can be accessed with the removal of the lower front access panel. Disconnect power to the washer and drain the water from the tub before accessing it. The link below contains the detailed instructions on manual unlocking of the door.
Manual Unlocking of Whirlpool Duet and Kenmore Elite Front Load Washing Machines
Aug 26, 2011 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 washer stopped in teh middle of the washing, no power and can not open the door. Please help me in opening and fix it?
All frontload HE washers have a rip cord you can use to manually open the door but try to clean out your pump filter first. Your tech sheet is also there behind the service panel. Simply going by the diagnostics and cleaning out the filter could save you a bunch od money. Here is a nice video which shows how. H.E. PUMP FILTER CLEANUP
Dec 13, 2010 | Kenmore HE2 Plus Front Load Washer
The washing cycle stops at the final spin. The
If this machine is a Kenmore 417 Sourse (WCI) built washer with a font load,check tech sheet.I had the same problem on a Frigidaire frontload and it was the door latch/lock assembly.These machines can be tricky sometimes.Use tech sheet and make sure lock assembly ohms out ok.
Mar 04, 2010 | Kenmore HE2 Plus Front Load Washer
HE2 front loadable washer doesn't move fm wash to rinse to drain
Sounds like the door lock. It will not advance to spin if it thinks the door is open. There is a instruction sheet inside the unit behind the lower panel. That will give the error codes for the flashing lights.
Sep 04, 2009 | Kenmore Elite 45986 Front Load Washer
HE5 frontload washer error f11
F11 error code indicates a communication problem. The communication between the Central control board and the Motor control board cannot be sent correctly.
Potential causes:
1. Loose connections between the motor control board and the machine control board, or at
motor
2. Machine control board failure
3. Motor control board failure
4. Motor failure
5. Door lock failure
If this answers your problem, please rate my answer.
Thanks,
David
May 27, 2009 | Kenmore Elite 45986 Front Load Washer
No lights on panel, door won't open
This is for the Whirlpool/Kenmore HE2 Plus:
1 Unplug/Disconnect the washer
2 Remove the lower kick panel
3 Reach up along the inside of the front & locate the bottom of the door switch/lock unit.
4 Located on the bottom of the door switch/lock unit is a tear-drop shaped tab.
5 Gently pull the tab down about quarter inch or until a click is heard. Gently open door.
Apr 11, 2009 | Kenmore Washing Machines
Kenmore frontload washer won't unlock
To manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the front lower kick panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about quarter inch or until a click is heard.
6. The door may now be opened
Or pull out your dispenser tray, along the rear edge you will find a cord, pull this like above. Depends on your model.
Apr 01, 2009 | Washing Machines
Frontload washing machine makes noise during spin cycle
call sears 1 800 4myhome they can walk you thru some troubleshooting. First thing pull back the rubber ring between door and barrel to see if anything like pens etc feel into the gap underneath. If not call for troubleshooting. Get a plan with sears then wait 30 days and call in the problem. Fix will cost less.
Mar 22, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore 43142 Front Load Washer Logo
350 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
