Question about JVC AV-48WP30 48" Rear Projection Television
JVC TV-AV29TS4 FAIL TO COME ON. POWER LITE GETS BRIGHTER WHEN PW. SW. IS PUSHED, BUT NO PW. TURN THE SET ON...ALSO, WHEN SW. IS PUSHED AGAIN TO TRY TO TURN OFF PW. LITE STAYS LITE, YOU MUST UNPLUG SET FOR IT TO GO OUT.
  • troyj Jan 26, 2008
    Screen went black while watching, speakers popped. blue pwr lite pulses at steady rate, but pwr button does nothing.
    Problem Solver:
  • 5 Answers
How old is the TV? Usualy the most common problem with these Projection TV's are the LAMPS. They can last anywhere from 1 yr to 3 yrs. They usualy need to be replaced after 1yr and a half (18 months). Manufacturer's usually warranty them for that period of time. There is an access panel in the rear of the TV. If you open this panel you can see the lamp. Check it and see if it has gone out.
Posted on Jan 08, 2008
6ya staff
SOURCE:
JVC LT 32E488
Unless this JUST started happening AND the TV worked previously, or you recently added a device to your set up, I am guessing that you simply are on the wrong input. For instance, I have a playstation connected to Video 2 and if my TV is set to Video 2 input AND my playstation is NOT on, the screen will be lit, but no picture. Make sure you are on the correct input.
Oct 26, 2013 | Televison & Video
Hey I was cleaning my computer and Unplugged the PW SW and PW LED from the motherboard. When i replugged it in the computer wouldn't turn on. I've tested the Power supply, and it's fine. So at one point...
Switching the connetors should not have damaged the motherboard. Have you tried disconnecting all your drives, removing any extra PCI cards, and removing the memory just to see if you get the necessary beep code? Also, try removing the BIOS battery and putting it back in.
Static shock can cause problems but I have not seen it happen in over 10 years of personnal experience.
Apr 11, 2011 | Gigabyte GA-G31M-ES2L Motherboard
Digital input not working and greyed out on the menu.
Most JVC TV's with HDMI and Digital Input have an optical sensor inside the case to sense if someone is trying to bypass the hardware encryption. My JVC was exposed to sunlight prolonged sunlight and triggered this optical sensor which disabled my HDMI ports. This may be the same situation for you.
JVC HDMI Port Fix
Turn the TV on, and enter the Service Menu. Select 2 for Self Check. Then turn the TV off, and after the fan turns off, unplug the power cord. Reconnect the power cord, turn the TV on, and the HDMI port is re-enabled.
Here's how to get to Service Menu:
Before entering the SERVICE MENU, confirm that the setting
of TV/CATV SW of the REMOTE CONTROL UNIT is at the
"TV" side and the setting of VCR/DVD SW of the REMOTE
CONTROL UNIT is at the "VCR" side. If the switches have not
been properly set, you cannot enter the SERVICE MENU.
1) Press [SLEEP TIMER] key and while the indication of
SLEEP TIMER 0 MIN is being displayed, press
[DISPLAY] key and [VIDEO STATUS] key (Fig.2)
simultaneously.
2) The SERVICE MENU screen of Fig.1 is displayed.
3) Verify what to set in the SERVICE MENU, and set
whatever is necessary (Fig.1).
Refer to the SERVICE ADJUSTMENT for setting.
4) Press the [BACK] key to return the SERVICE MENU.
Dec 12, 2010 | JVC AV-56WP74 56" Rear Projection...
When try to on the power power lite just blinks tv don't turn on
I can help you to solve your tv problem.
Let me know model number of your JVC tv, it would be written on label pasted at rear of tv to find out possible reason of no power up problem.
Thanks.
Dec 04, 2010 | JVC Televison & Video
Power comes on ds lite, green lite comes on, gets brighter, then screen flashes and all goes completely off again.
Sounds like the actual processor in the unit has failed, it should be a free repair from Nintendo. Either way you will need to give them a call, their number is:
1-800-255-3700
Sep 21, 2009 | Nintendo DS Lite Console
Our tv will come and then shuts right off and the power lite will then flash. You can only turn the tv back on when unplug and then plug it back on
These set have common problems with capacitors in the power supply. Likely the set will eventually not turn on at all.
Sep 20, 2009 | JVC AV-32D305 32" TV
Ds lite wont turn on
try hooking it up to the charger, if that dosent work then just buy a new battery, if that still dosent work the i have no idea whats wrong. Hope that helps =)
Jul 05, 2009 | Nintendo DS Lite Console
Samsung hcm4216w won't turn on light blinks then shuts down and tries to restart again
Your problem is TV is not getting enough power so you better buy a stabilizer and make the power to go thro the stabilizer to TV then it will get sufficient power supply everything will be smooth afterwards even the voltage problem.
Oct 17, 2008 | Samsung HCM4215W 42" Rear Projection...
JVC TH-A10 Won't TUrn on...
Unplug the JVC and the subwoofer from that outlet. Then, plug them back to a different outlet (where power is constant and not interupted by any switch.) Hope this helps
Aug 25, 2007 | JVC TH-A10 System
Not Working
its the high voltage regulation,the power supply regulators bad or could even be a bad picture tube. now If you have done electronic repairs in the past then I would advise you to get a service manual and see whats going wrong by monitoring the B+ while the set gets turned on BUT if you dont know what a regulator is I would advise that you call or take thats right take the set to the repair shop and see what the friendly person says. if they have a flat rate thats a good thing. BUT if they have an per hour rate then thats where your gonna have to say to your self >> "myself?? how much did I spend for this tv?? is it worth repairing??" Its all on your guess. Good luck
Apr 27, 2006 | RCA T09084 9 in. TV/VCR Combo
JVC AV-48WP30 48" Rear Projection Television Logo
47 people viewed this question
Top JVC Televison & Video Experts
Todd Hill
Todd Hill
matt martin
matt martin
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
