Question about Canon PIXMA iP1500 InkJet Photo Printer
Not printing correctly
I replaced the ink tank and it prints but it prints weird half words ... i'm not sure how to explain it but it's printing something but not the documents i need and it's not even legible, more like black smudges
  • 233 Answers
You need to run the clean print head from the software utility or from the printer menu. you may need to run it a few times until the test pages looks good
this is common on ink jet printers, the nozzles may get clogged
Posted on Jan 07, 2008
After replacing cyan, magenta and yellow toners with genuine Canon toners, my Canon MFC 8180c does only use yellow color to print while trying to print or copy color stuff.
You will need to do an ink reset because from what you have explained the machine has only recognised one of the coloured inks and the black.
1. Switch on the machine and set it up for removal of all the ink cartridges . Then fully remove each of them (including the black) and then replace them back in the correct slots. Make sure they are fully home when you fit them. The machine now thinks you have removed used cartridges and replaced them with new ones.
2. Then close the printer and follow the instructions on the display window on the printer to indicate to the machine that you have replaced each ink tank with a new one.. It will ask in order if you have replaced each of the ink tanks from black onwards and the answer has to be yes. Make sure you hit the correct buttons when responding because if you do not the printer will not recognise the presence of that particular ink cartridge (and will not use it) which I believe is part of the problem you have now.. Check your user manual to make sure you are pressing the all the correct keys for your model machine.
Hope this helps some.
Dec 30, 2015 | Canon Office Equipment & Supplies
Shows code U165
This section explains the way to confirm the ink status and the procedure to replace ink tanks. When ink runs out or other errors occur, an error message is displayed on the LCD to inform you of the error. See "An Error Message Is Displayed on the LCD".
When printing from your computer, error messages appear on your computer screen as well.
NOTE
Be sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder.
The machine will not print if an ink tank is installed in the incorrect position.
With the LCD of this MachineMake sure that the machine is turned on, then press the COPY, FAX, SCAN, or MEMORY CARD button. The current ink level will be displayed on the LCD for a few seconds.
g0011480_tcm14-605381.png(A) Confirm whether any symbols are displayed here.
g0011482_tcm14-605375.pngColor or black ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.g0011483_tcm14-605376.pngColor or black ink may have run out. See"An Error Message Is Displayed on the LCD".
REFERENCE
The ink status information is also displayed on the screen that appears during printing.
An error message may be displayed on the LCD during printing.
g0011494_tcm14-605377.pngMachine detected ink out condition. See "An Error Message Is Displayed on the LCD" and take appropriate action.
(B) Empty ink tank.With the Ink LampsYou can confirm the status of each ink tank by the ink lamps. Open the Scanning Unit (Printer Cover) of the machine to confirm how the ink lamps light or flash.
  • Ink lamp is on
The ink tank is correctly set and there is enough ink remaining to print.
  • Ink lamp is flashing
Flashing slowly (at around 3-second intervals)
Ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.
Flashing quickly (at around 1-second intervals)
The ink tank is inserted in the wrong position or it is empty. Ensure that the ink tank is in the correct position as directed by the label on the Print Head Holder. If the position is correct and its lamp flashes, it is empty. Replace it with a new one.
  • Ink lamp is off
The ink tank is not set properly or the function for detecting the remaining ink level is disabled.
If the ink tank is not set properly, press the g0009324_tcm14-605384.png mark on the ink tank until the tank clicks into place. If it does not click into place, make sure that the orange protective cap has been removed from the bottom of the ink tank.
If the function for detecting the remaining ink level is disabled, replace the ink tank with anew one. See "Replacing Ink Tanks".
If the lamps are still off after reinserting the ink tanks, there has been an error and the
machine cannot print. Check the error message displayed on the LCD. See "An Error
Getting the Clear Ink Status InformationClear ink is used only when printing on plain paper.
When Plain paper (Cassette) is selected for Media type and printing begins when clear ink (PGI-9Clear) is low, a message will be displayed in the LCD.
g0011497_tcm14-605385.png(A) Confirm whether a symbol is displayed here.
g0011502_tcm14-605378.pngThe clear ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.g0011503_tcm14-605379.pngThe clear ink tank is empty. See ""The clear ink tank is empty. Replacing the ink tank is recommended." U045" and take appropriate action.
NOTE
  • The ink status information is also displayed on the screen that appears during printing.
  • Clear ink is used only when printing on plain paper. Therefore, it is possible to print on photo paper, or any type of paper other than plain paper, loaded in the Rear Tray, even if clear ink has run out.
The following error message will be displayed on the LCD when the clear ink has run out during printing on plain paper.
g0011506_tcm14-605380.pngRefer to "Replacing Ink Tanks"If you continue printing under the clear ink out condition, see ""The clear Ink has run out. Replace the ink tank." U165/U166" and take appropriate action.When the clear ink hasrun out, printing on plain paper from the Cassette is not possible. The fax, which is received under the clear ink out condition, will be stored in memory.
NOTE
It is possible to print on photo paper, or any media type other than plain paper, loaded in the Rear Tray, even if clear ink has run out.
Oct 01, 2011 | Canon PIXMA MX340 Wireless Office...
Getting error U043 "The following ink tank cannot be recognized. I have the correct tank. Pixma 520 ...tank # 5 PGBK
The little chips on the front of the cartridge create a trouble for people trying to refill the cartridge, as of right now, there is no way to easily reset the chips. If you refill them, they still register as empty, and therefore don't work.
If the following tips doesn’t help, you can try to install the original new ink cartridge following the instructions in the user manual. This can solve the problem.
Note :
Be sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder. The machine will not print if an ink tank is installed in the incorrect position.
For information on the compatible ink tanks, refer to the back cover of the Quick Start Guide.
Tips before Replacing Ink Tanks : Important:
- To maintain optimal printing quality, we recommend the use of specified Canon brand ink tanks.
Refilling ink is not recommended.
- Once you remove an ink tank, replace it immediately. Do not leave the machine with ink tanks removed.
- Replace empty tanks with new ones. Inserting partially used ink tanks may cause the nozzles to clog. Furthermore, with such tanks, the machine will not be able to inform you when to replace the tanks properly.
- Once an ink tank has been installed, do not remove it from the machine and leave it out in the open. This will cause the ink tank to dry out, and the machine may not operate properly when it is reinstalled. To maintain optimal printing quality, use an ink tank within six months of first use.
- Color ink may be consumed even when printing a black-and-white document or when black-and-white printing is specified.
Color ink is also consumed in Print Head Cleaning and Print Head Deep Cleaning, which may be necessary to maintain the machine's performance. When an ink tank is out of ink, replace it immediately with a new one.
After replacing ink tank;
Turn off the machine, and unplug the power cord of the machine from the power supply. After five minutes or more, plug the power cord of the machine back in, and then turn on the machine.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
Mar 25, 2010 | Canon PIXMA MP520 InkJet Printer
My cx 3200 is not printing correctly. It prints
I had that same problem, when I used Generic INK.
Replace the cartridges with Genuine Epson Ink,
and then ran fine.
Weird eh?
Good Luck.
Nov 04, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Cannon MP830 Printer cartridge jam
So you cant get the ink tanks in place properly?
Have you tried this method to ensure they're properly seated? Is the printer on or off when you try to seat the tanks?
Refer to the following steps to verify the ink tanks are seated correctly:
  1. Confirm that the printer is powered on and press the Open button. (The paper output tray will open.)
  2. Lift the scanning unit (printer cover) completely. (The print head will move to the replacement position.)
  3. Open the inner cover.
    CAUTION:
    a. Do not try to manually move or stop the Print Head Holder.
    b. Do not touch any metal parts.
  4. Press down on the ink tank until a click is heard, thereby making sure the ink tank is seated properly.
    Note:
    Make sure that the ink tank is inserted in the slot that corresponds to the ink tank's color.
  5. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    Note:
    Ink Tank Lamp
    You can check the status of each ink tank according to the way its lamp flashes.
    • - On: The printer is ready to print.
    • - Slow flashing (at about three second interval): Ink is low. Prepare a new ink tank.
    • - Fast flashing (at about one second interval): Ink tank is empty, or the printer is not ready due to an error.
    • - Off: An error has occurred and the printer is not ready to print.
  6. Close the inner cover and the scanning unit (printer cover).
    Note:
    1. When closing the scanning unit (printer cover), be careful not to jam your finger.
    2. When starting printing next time, the print head cleaning launches automatically.
Apr 04, 2009 | Office Equipment & Supplies
A big PGBK ink cartridge problem
Call - 1-800-828-4040
Verify they are installed correctly.
Remove the print head or ink tanks properly following the procedure below.
1. Confirm that the printer is powered on and open the top cover. The print head moves to the replacement position.
Note: When the top cover is opened more than ten minutes, the print head moves to the right side. If this occurs, close the top cover, and open it again.
2. Open the paper output tray and pull down the inner cover.
3. Remove the ink tanks by pressing the tab of each tank.
Note: Handle the ink tanks with care so that your clothes and surrounding area do not get soiled. When replacing multiple ink tanks, make sure to replace one by one.
ip4200_ink_remove.gif4. When removing the print head, raise the print head lock lever first.
raisephlocklever.gif To reinstall the Print Head and Ink Tanks
1. Place the print head in the holder and lower the print head lock lever carefully until you hear a click.
putinphnlockit.gif2. Insert ink tanks into the print head.
Press the mark 'PUSH' on the ink tank firmly until you hear a click.
3. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
<1> The ink tanks are installed properly.
<2> The ink tanks are not installed properly.
Note: <Ink Tank Lamp> You can check the status of each ink tank according to the way its lamp flashes.
4. Put back the inner cover and close the top cover.
Note: When starting printing next time, the print head cleaning launches automatically.
During the print head cleaning, the Power lamp flashes green. Do not do other operations until the flashes stops.
James Mac
Sep 10, 2008 | Canon PIXMA IP5200 InkJet Photo Printer
I have tried to print using my black ink cartridge and it will only print what is my email address.
Issue: Tinted printing / Colors are not exact
Solution: Resolving ink tank and cartridge issues BJC-6000
Printer attempts to print but no ink is on the paper Printer attempts to print but no ink is on the paper If the print quality is poor or no ink is appearing on the page, it may be because of the following problems:
  • The ink in the BJ tanks has run out.
  • The print head nozzles may be clogged
  • The protective cap or tape may have been reattached to the BJ cartridge
  • The BJ cartridge may need to be replaced
  • You may be using the wrong side of the media.
To check the level of ink in the BJ tanks
Open the printer's front cover and visually check the level of the ink in all the BJ tanks. If a BJ tank is low or has run out of ink, replace it. Failure to do so may shorten the life of your BJ Cartridge
To check the status of the print head by printing a Nozzle Check Pattern
  1. The Nozzle Check Pattern confirms whether the inks are being correctly ejected from the print head nozzles and whether the print head is correctly aligned.
  2. On your printer, press and hold the Resume button until you hear 2 beeps.
  3. When you release the button, the Nozzle Check Pattern will be printed. You can also print the Nozzle Check Pattern by clicking on the Test Print button in the Maintenance tab of the printer properties dialog box.
  4. After the Nozzle Check Pattern is printed, check the results. Look at the Nozzle Check Pattern for each BJ Ink tank. If any colors are missing or if any horizontal lines are broken or missing, perform the print head cleaning procedure.
To perform the print head cleaning procedure
  1. On your printer, press and hold the Resume button until you hear 1 beep.
  2. When you release the button, all print heads for all colors will be cleaned.
  3. You can also clean the print heads by clicking the left Print Head Cleaning button in the Maintenance tab of the printer properties dialog box.
  4. When the print head cleaning begins, the POWER light starts flashing. This will continue for about 30 seconds. Wait for the light to stop flashing before you resume normal operation.
  5. Perform the Nozzle Check Pattern test again.
  6. If the results are satisfactory, resume normal printing. If the results are not satisfactory, you may need to execute a print head deep cleaning.
To execute a print head deep cleaning
  1. Make sure paper is loaded in the sheet feeder and the printer is turned on.
  2. Display the printer properties dialog box and click the Maintenance tab.
  3. Click the right print head Cleaning button.
  4. When the print head cleaning begins, the POWER light starts flashing. Wait for the light to stop flashing before you resume normal operation.
  6. If the Nozzle Check Pattern is still unsatisfactory, you may need to execute a print head alignment.
To execute a print head alignment
In Windows, display the Maintenance tab of the printer properties dialog box.
  1. Click the right Test Print button.
  2. Follow the instructions on the screens to perform an automatic print head alignment.
  3. A confirmation screen will ask you if you want to perform automatic print head alignment. Read the screen and click OK. Another screen warns you not to start any other operation until the alignment is complete. Again, click OK.
  4. The BJ Printer Status Monitor displays the Printer Status. The driver will align the print heads then will print an alignment pattern.
  6. If the Nozzle Check Pattern is still unsatisfactory, you may need to replace the BJ cartridge.
To replace a BJ Tank in a BJ Cartridge
Leave the BJ cartridge in the printer when replacing a BJ tank. Make sure the printer's power is on. Make sure you insert the BJ tank in the correct slot.
  1. Open the front cover.
  2. The power light blinks while the cartridge holder is positioned to the center of the printer.
  3. Remove the empty BJ tank by pressing in on the release tab and then lifting the BJ tank up and out of its slot.
  4. Dispose of the tank properly, taking care to avoid spilling ink on your hands, floor, furniture, or clothing.
  5. Remove the new BJ tank from its package and pull the orange tape up and against the perforations to open the package film. Be careful not to remove the label from the tank. You will need it to match the tank to the correct slot in the BJ cartridge.
  6. Twist the orange protective cap to remove it. Do not attempt to reattach the protective cap; instead, discard it along with the protective tape.
  7. Insert the BJ tank by holding it at a slight angle, aligning it with the correct slot. Press down gently on the top of the tank until it locks into place.
  8. Lock the ink tank in place by pressing down on the circle mark on the top of the tank.
    Close the printer cover.
  9. The printer will automatically start cleaning the print heads. When the print heads are clean, the POWER light will stay on, indicating that the printer is ready for operation.
  10. Perform another test print to make sure the new ink tanks are performing correctly.
To remove the protective cap and tape from the BJ cartridge
  1. Open the printer's front cover.
  2. Unlock the BJ cartridge by raising the cartridge lock lever. Make sure you raise it all the way up.
  3. Remove the BJ cartridge by holding it by the circles on the left and right sides.
  4. Make sure that the orange protective cap has been removed.
  5. Make sure that the protective tape has also been removed.
  6. Replace the BJ cartridge and move the blue cartridge lock lever until it locks in place.
To check the media
Make sure that you are printing to the correct side of the media that you are using, and that the Media Type setting in the printer driver properties correctly reflects the type of paper you are using.
Be sure to read any instructions that come with your Canon specialty paper. These instructions provide important information regarding how to achieve the highest print quality with these papers.
May 30, 2008 | Canon BJC 6000 InkJet Printer
Ink cartridge problem
Solution: Snap in ink tanks properly MP500
Ink Tank Seated Properly Refer to the following steps to verify the ink tanks are seated correctly:
    CAUTION:
    Note:
    Note:
    Ink Tank Lamp
    Note:
Mar 30, 2008 | Canon Pixma MP500 All-In-One InkJet...
I have a cannon mp830 wont print
Solution: Insert one of each color ink tank MP830
New Page 1 More Than One of the Same Ink Tank is Installed When installing or replacing an ink tank, only one of the following ink tanks should be installed. If the ink tank is not installed correctly, an error message will display. mp500_inktankorder.gif
    Note: When the scanning unit (printer cover) is opened more than ten minutes, the print head moves to the right side. If this occurs, close the scanning unit (printer cover), and open it again.
  4. Press on the tab to release the ink tank, then remove it from its slot. If you are replacing multiple ink tanks, make sure to replace one by one.
  5. Insert the ink tanks into the print head. Note: Press the mark "PUSH" on the ink tank firmly until you hear a click.
  6. Ensure that all the ink tanks are installed properly and the ink tank lamps light red.
    <7> The ink tanks are installed properly.
    <8> The ink tanks are not installed properly.
    Note: Ink Tank LampYou can check the status of each ink tank according to the way its lamp flashes.
  7. Close the inner cover and the scanning unit (printer cover). Note:
    • When closing the scanning unit (printer cover), be careful not to jam your finger.
    • When starting printing next time, the print head cleaning launches automatically.
Jan 18, 2008 | Canon IMAGERUNNER 6570 Copier
Canon BJC 3000
  • The print head nozzles may be clogged.
  • The protective cap or tape may have been reattached to the BJ cartridge.
  • The BJ cartridge may need to be replaced.
Check the status of the print heads by printing a Nozzle Check Pattern
  1. On your printer, press and hold the Resume button until the printer light flashes two times.
  2. When you release the button, the Nozzle Check Pattern will be printed.
  3. After the Nozzle Check Pattern is printed, check the results.
  4. Look at the Nozzle Check Pattern for each BJ cartridge. If any colors are missing or if any horizontal lines are broken or missing, perform the print head cleaning procedure.
  5. In the alignment head pattern, if the lines are not perfectly overlapped, align the print heads.
  1. On your printer, press and hold the Resume button until the printer light flashes one time.
  2. When you release the button, the print head will be cleaned.
    You can also clean the print head by clicking the left Print Head Cleaning button in the Maintenance tab of the printer properties dialog box.
  3. When the print head cleaning begins, the POWER light starts flashing. This will continue for about 30 seconds. Wait for the light to stop flashing before you resume normal operation.
  4. Perform the Nozzle Check Pattern test again.
  5. If the results are satisfactory, resume normal printing.
  6. If the results are not satisfactory, you may need to execute a print head deep cleaning.
  3. Click the right Print Head Cleaning button.
  1. In Windows, display the Maintenance tab of the printer properties dialog box.
  2. Click the right Test Print button.
  3. Follow the instructions on the screens to perform an automatic print head alignment.
  4. A confirmation screen will ask you if you want to perform automatic print head alignment. Read the screen and click OK.
  5. Another screen warns you not to start any other operation until the alignment is complete. Again, click OK.
  6. The BJ Printer Status Monitor displays the Printer Status. The driver will align the print heads then will print an alignment pattern.
  7. Perform the Nozzle Check Pattern test again.
  6. Be careful not to remove the label from the tank. You will need it to match the tank to the correct slot in the BJ cartridge.
  7. Twist the orange protective cap to remove it.
  8. Do not attempt to reattach the protective cap; instead, discard it along with the protective tape.
  9. Insert the BJ tank by holding it at a slight angle, aligning it with the correct slot. Press down gently on the top of the tank until it locks into place.
  10. Lock the ink tank in place by pressing down on the circle mark on the top of the tank.
  11. Close the printer cover.
  12. The printer will automatically start cleaning the print heads. When the print heads are clean, the POWER light will stay on, indicating that the printer is ready for operation.
  13. Perform another test print to make sure the new ink tanks are performing correctly.
To check the media:
  • Make sure that you are printing to the correct side of the media that you are using.
  • Be sure to read any instructions that come with your Canon specialty paper. These instructions provide important information regarding how to achieve the highest print quality with these papers.
Dec 17, 2007 | Canon BJC 3000 InkJet Printer
Canon PIXMA iP1500 InkJet Photo Printer Logo
90 people viewed this question
old marine
old marine
