Acer Aspire  5050-3242  PC Notebook
Problem for Acer Aspire 5050-3242 (LX.AG30J.012) PC Notebook
Acer Aspire 5050 I bought a new battery . My
By mometm on Nov 10, 2009
Acer Aspire 5050 I bought a new battery . My laptop works fine on Ac power but when I installed the battery it shuts off immediately
Comments:
Nov 10, 2009
- Yes that is correct.
Nov 10, 2009
- I am doing that at the moment. Will see if that helps
Nov 10, 2009
- I am trying that at the moment
Nov 11, 2009
- Yes I tried this but with no luck . Same thing is happening
Nov 11, 2009
- Hi JCHunter Sorry for confusion. 1. Yes tried charging battery for 6hrs. 2. No it will not work with either old or new battery installed 3 With battery inserted battery light flickers for a moment then nothing 4 Yes green charge light is on when switched on 5 It is also a fairly new universal AC adaptor
Nov 14, 2009
- Hi JC Hunter Yes the battery kept losing charge shortly after new adaptor . Could try a new plug as you get a variety of sizes with universal adaptor. Son in law took it to look at. Tkanks for all your help
Clarification Request
Posted by JCHunter on Nov 10, 2009
Have you tried just plugging it in and charging the battery for 4-6 hrs. first?
Posted by kriegen69 on Nov 10, 2009
hmm cant be sure but it sounds like a short on the motherboard so you are running it with ac power with no battery and as soon as you put the battery in it the unit shuts off and will not power on??
Solution #1
posted on Nov 11, 2009
Not Rated)
JCHunter
Rank: Guru
Rating: 89%, 31 votes
I apologize that I am having a hard time following the thread as to what you have tried and so forth. I will assume the following:
1. You have an old battery that does not hold a charge but the laptop does run with this battery installed, from AC or from AC w/no battery installed.
2. You have installed the new battery (with the laptop off) and it does not run from the battery or when plugged in.
3. You have tried charging the new battery 4-6 hours.
4. You are using the original charger or one that is fully rated for the laptop - I think this needs a 90W.
New question: does the charge light come on?
If the above are all true then there are 2 possible problems:
1. Bad (shorted) battery - this is possible, although unlikely, fro a new battery.
2. Power connection on the motherboard is faulty. The center pin may be loose, thus not giving full power to the system to charge the battery and run the laptop at the same time. This should be "overcome" by charging the battery w/system off. OR, the connector is like a headphone jack in that when you plug in, the primary connection is opened but on this series of laptop I have seen this fail.
Try powering up with the battery in and adapter plugged into the laptop but not to the wall.
Let me know what you discover. Reply w/my name so I know which thread to read.
Jon
Comments:
Nov 14, 2009
- Sorry I haven't gotten back to you sooner but it was hectic - like everybody needs their computer for the weekend! First thought is which came first - the new universal adapter or the new battery. Was the old battery just not holding much charge or did it stop working about when you got the charger. This is my best guess at the moment: the universal charger plug is loose in the laptop jack - that is, the outside diameter is not large enough to open the normally closed connection between th battery line to the motherboard so the battery and pwr supply are "shorting" each other out. The plug needs to fit snugly both on the center pin AND the outer ring. It is like a headphone jack - when you plug in the headphones, it turns off the speakers. If you can find a true ACER supply and that works then that is the problem. Also I find the Kensington universal supplies have pretty good fitting plugs and the Chinese ones - not so good. Maybe you can take it to a shop and they would have an Acer supply to try. Otherwise - I'll be scratching my head some more! Let me know. JC
Was this helpful?
Yes
No
Popular Solutions for Acer Aspire 5050-3242 PC
Questions and Unsolved Problems for Acer Aspire 5050-3242 PC
Do you recommend Acer Aspire 5050-3242 (LX.AG30J.012) PC Notebook?
Answer
Answer
System Information gives notice time to time reinstal Acer edata security management. But Indo not... (More)
Answer
cannot open window files, seems to be locked. message edata security system error reinstall the... (More)
Answer
will not contect to wireless internet when contacted via mains, only when on battery only
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Acer Aspire 5050-3242 PC...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
