Question about Creative Labs Zen V MP3 Player
Docked prooblem my zen v plus is just a day old. i disconnected it from the USB from the computer and it frooze show a usb sign and docked.... now it went off totally... i can not even put it back on? pls what should i do?
  • ella nero Jan 07, 2008
    i am sorry , this is totally ineffective 4 me..or probably i didnt understand it properly...thankz alots but can i hav ur cell phone number so i can give u a call... i need 2 call someone about it.
    Novelist:
  • 167 Answers
Plug it in and start charging it. Once it has a decent charge if you ever have that problem again... (see below)
Using the instructions below try Reset, first, if that doesn't fix it try the Cleanup method, if that doesn't work... (if you have a backup of all your music on your computer), try the format option
This is from Creative's website:
Zen V Plus and Zen V
  1. Detach your player from the PC if it is connected, and turn off the player.
If the player stops responding, you can reset the player. To reset the player, gently
insert a thin object into the Reset hole located below the power switch.
2. Press and hold the Play button while powering on your player.
3. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All) Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Posted on Jan 07, 2008
  • Steve Stonebraker
    Steve Stonebraker Jan 08, 2008
    Try charging it, since your player is brand new it is under warranty, contact creative.com/support and they can replace/fix it for free
Stuck on docket but not attached to usb
I had the same problem with zen V stuck in docked without usb - and the reset-button worked like a charm!
May 20, 2009 | Creative Labs ZEN V Plus MP3 Player
CREATIVE ZEN - NOT CHARGING
Go into your lab top and click on remove hardware safety.Find your zen the click remove..Next do not unplug it,shut off your zen then you should see instantly on the zen its charging...
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Mar 31, 2009 | Creative Labs Zen V MP3 Player
My zen charges but doesn't dock
Try the Creative System Information program. It will scan for your Zen.
Jan 01, 2009 | Creative Labs ZEN V Plus MP3 Player
Creative zen will not dock
Did you recently install another application to your computer? Like an anti-virus maybe? Try this. Go to Control Panel > Device Manager. Look for your Zen under Portable Devices. If you see an exclamation mark on your Zen, double click on it. Another dialog should pop up. Go to the Driver tab and click Uninstall. Then disconnect your Zen from your computer and reconnect it again. This solved the problem for me.
Oct 20, 2008 | Audio Players & Recorders
Creative Zen: M Not Docking with computer!
I had the same problem. This worked for me on a Zen that is 2 years old: Go into the Control Panel on the start menu and select System. Then select Hardware and then Device Manager. You will see a list of all the devices on your pc. Now you should see your Zen about half way down the list. Highlight it and then at the top in the menu item Action select Uninstall. Windows will then uninstall your hardware. Unplug your Zen from the USB port, if you haven't already done so, and then plug it back in. Windows should then reinstall your device and you should be good to go.
Oct 14, 2008 | Creative Labs ZEN Vision:M Digital Media...
CREATIVE ZEN V-PLUS. COULD NOT TURN ON AND IS NOT CHARGING
Try using the reset botton while connected to the computer via usb cable , it worked for me.
Jul 24, 2008 | Creative Labs ZEN V Plus MP3 Player
Wont detect Zev V plus
ok... i found a fix...
insert zen v plus install cd
exit out of autorun for cd
go to control panel
click on system
click on the hardware tab
click on device manager
click on portable devices
right click on your USB device with the yellow warning sign
go to properties
when it tells you that the drivers arent installed... go to the browse button and select your zen v plus install disk
hit ok and it will find the drivers that way...
Apr 04, 2008 | Creative Labs ZEN V Plus MP3 Player
Charging
if you use the usb cord connected to the computer it will charge( over night), i recommend an ac charger it's a lot faster!
Feb 12, 2008 | Creative Labs ZEN V Plus MP3 Player
ZEN NOT DOCKING TO COMPUTER
if you are using a fromt usb port- switch to the back usb. The front ports don't always give the zen enough power. Also- look in Device Manager and see if there is a zen listed there- and if it is does it have a yellow exclamation mark? It may not be the zen that is having problems but your computer.
Oct 28, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Zen V Plus stops reading
· Make sure you have media player 11
· If you can, the best test is to try your player with another PC, to see if you still have the problem. This localises whether the problem is with the PC (most likely the USB) or the player. See the link below (search on "connection problems") for a lot more troubleshooting on this.
· Download recovery tool off creative's website.
Aug 15, 2007 | Creative Labs ZEN V Plus MP3 Player
Creative Labs Zen V MP3 Player Logo
54 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
