Question about Samsung NV10 Digital Camera
Camera won't charge
Went to plug my camera in to charge it up as going away and want it for my trip, however on plugging it in, i got a red then orange then green light, then the led went blank. I took this to mean it wasn't charging. Can you offer any advice?
Cheers
  • eileen00 Apr 12, 2008
    I have the same problem and I tried to do everything, but it still does not work.. Any suggestions?
  • Anonymous Apr 27, 2008
    I use samsung NV20 digi cam. Last time when I charged the cam there was a blue light glowing while charging. But yesterday when I was their was no light found and I could`nt know whether it is charging or not. The cam stopped opening/
I have the same camera with the same problem, i usually have to take the memory card out and the battery, put the battery back in but leave the memory out, it usually starts to charge after that small ritual. good luck
Posted on Apr 15, 2008
  • 70 Answers
  1. some time ur supply voltage may low.
  2. cable may internally cut, check by using multimeter
  3. check charger output voltage
  4. check contact, it may coroded
Posted on Jan 16, 2008
There is a red exclamation point on the camera screen that won't go away. What is the problem?
Just got one of these cameras from a charity shop and after only a short use same problem.
Try connecting camera to PC as an external drive and delete (all) files..... This, too, may not work, in which case reformat the whole drive representing the camera - quick format will probably do.
Once you take a photo the directory path: DCIM/100IMAGE will be recreated.
I'd recommend reformatting quite regularly - after each time you download the photos off the camera.
Apr 04, 2013 | Lego Digital Camera.
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
Won't turn on
Your computer isn't recognizing the camera and you may need to install some software in order for it to do so.
Another thing? Are you trying to charge it? In my experience, Jazz cameras will only charge with an adapter that is usually included with the camera. Hope this helps.
Jan 19, 2012 | Jazz DV-179 Digital Camera
I just got the flip ultra hd for christmas and was charging it then my computer screen went all weird and couldn't read the screen and all my icons on my computer were all big. i tried this three times and...
FLipSHARE software isn't compatible with Vista Aero and some other visual settings, SO, when you plug in your Fllip camera, the FlipShare software changes your desktop settings to go with their camera. They should go back to how you had visuals set before the camera was plugged in once you remove the camcorder. No green light shows when charged, a Red light shows up and glows during charge and when the red light goes out it is fully charged.
Dec 26, 2010 | Pure Digital Flip Video Ultra Camcorder
Panasonic vx37
My old Panasonic Palmcorder IQ shows a red light in both switch positions-camera and VCR. Maybe yours has red for camera and green for VCR so you could tell them apart. I found that the Panasonic battery that came with the camera was the cheapest kind with the least charging time. I bought other batteries, they were good for a while, but now, many years later, they won' t hold a charge. Since I am only recording inside of my house, I have resorted to using the AC wall socket for power. I have to take the battery out of the camera. I found a power plug-in hole (like ones on cell phones) in the battery compartment. I also found one of these holes on my battery charger. My camera came with a double ended power plug. I plug one end into my camera and the other end into the battery charger. I plug the charger power cord into the wall outlet, and I have power to my older camera. Maybe you can find this double ended power cord at a store or on line.
Did you know that there are 2 kinds of batteries? Some have memories and others do not rely on a memory. The ones with memories have to be fully discharged or they will only charge a little, and keep charging less and less each time they are charged. The ones without the memory can be charged fully without being discharged fully. Check into battery information on line to get more information. Maybe you can get the non-memory kind.
May 18, 2009 | Panasonic NV-VX37 Mini DV Digital...
Jazz DV 179 Camcorder
I believe that the camera will not charge directly from the computer - testing this theory myself... however I went to Radio Shack tonight and they have them there for 30 bucks (a bit outragious if you as me)
Jul 24, 2008 | Jazz DV-179 Digital Camera
Charging battery
I have a canon camera but it's not the same model. Mine doesn't charge while plugged into the computer.
May 15, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Finepix f10 problem
Plug came off the wall? What do you mean by this, the plug to what exactly the charger? How is the charger camera battery set up? Where is the red light on the charger? More detail please
May 10, 2007 | Fuji FinePix F10 Digital Camera
Samsung NV10 Digital Camera Logo
140 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
