Question about Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 650 660 680 6XX SD Card PNY 4GB SDHC Works
I was able to use a PNY 4GB SDHC4G4-FS Class 4 card with my Nuvi 650. I picked it up at Best Buy for $35US on sale.
It should work with the 660 and other 6XX series, I'll check with my brother's 680. My 650 has firmware version 4.2.
Even though the PNY package says it's limited to High Capacity devices, it works just fine.
When your Nuvi is connected to the computer, the SD card should show up as an extra drive. You can load it up with MP3s, JPGs, and audio books, or load it up with using a card reader.
Once you turn on the Nuvi with the SD card installed, it treats the SD card memory as part of the main unit memory, it's all contiguous and seamless. You won't see any icons or anything to tell you are accessing the SD card.
Has anyone tried higher capacity cards?
  • 3 more comments
  • zigman50 Mar 25, 2008
    Zigman again. Oops. My mistake. Yes my computer found the sd card through the GPS but last night I loaded a bunch of albums on the sd card and now they are not showing up on the GPS.
  • Anonymous Mar 27, 2008
    when i install the pny sdhc 4GB in to my nuvi 660. then i conect it to my computer, the computer wont pick up my nuvi 660
    any help please....
  • natarajan200 Apr 09, 2009
    I have Sandisk 4GB SHDC card. When I insert into the Nuvi660 slot, I cannot see the card to load and play the MP3 files. Can someone suggest as to how to install it in Nuvi 660? Thanks.
  • Anonymous Mar 24, 2014
    sd card for more memory in the Nuvi 1370t
  • Anonymous Mar 29, 2014
    formated the sd card still wont come up on nuvi 50
Wow! I just went out and bought a PNY SDHC 4gb memory card. Loaded it into my NUVI 680 and hooked it to laptop with USB cable. Saw the 4mb G drive right away. Havent synced music to it yet but cant see any problem. Thank you.
Posted on Mar 25, 2008
My garmin locks up when i try to play mp3s. its getting annoying
Posted on Feb 11, 2008
  • 35 Answers
Just got my A-Data 8GB card today and proceeded to load it up with 7.2GB of MP3s (nearly full capacity).
I timed with my wrist watch the bootup times and there was no difference in the boot times whether the SD card loaded up with MP3's was inserted in the unit or not. What did change is that even one minute after booting up the songs wouldn't show up in the "MP3 Player" window, it just had a blanked out browse button and a generic icon like it has when no music is loaded.
It took a full 90 seconds or so for the MP3 player to actually become responsive and show my selections, but after that it was working normally (from what I can tell).
Best Regards,
Posted on Jan 21, 2008
Nuvi 610 does not recognise sd card
According to the manual, the 610 works with SD cards, which are limited to 2GB in size. It will not work with higher-capacity SDHC cards such as the one you're trying to use.
Feb 21, 2014 | Garmin Nuvi 610 GPS Receiver
Take off write protection on SanDisk SDHC Card 4 GB
SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jul 30, 2013 | Skque 4GB MicroSDHC / MicroSD / Micro SD...
Lexar 4gb sdhc memory card error
Are your computer's card reader and camera compatible with SDHC cards or only with SD cards? While SDHC cards will fit into SD devices, they are electronically incompatible and will not work in devices not designed for SDHC cards.
Jul 15, 2013 | Lexar Memory Card Sdhc 4gb Class 4
I bought a lifetime update from Garmin a few years ago but now my nuvi 270 tells me that I don't have enough memory to install the latest maps and that I must choose only certain regions. I have an 8Gb...
The internal memory of the nuvi is full. Some maps will need to be delete before any new maps can be added. Typically, the map in the nuvi is named GMAPPROM.IMG and a map installed to an SD (or SDHC) memory card is named GMAPSUPP.IMG.
1) Remove the SD card from the memory slot
2) Connect the nuvi to the computer via USB cable.
3) Open the nuvi drive.
4) Locate and delete the GMAPPROM.IMG (or GSUPPROM.IMG) file(s). Optionally copy (instead of deleting) them to your hard drive in case there is a problem wit the new map file(s).
5) Empty the Recycle Bin.
6) Retry the map update of the nuvi.
This method will take some time to perform depending on how many map segments you are sending to the nuvi. Transferring the entire map can take over an hour. A quicker way is to send the maps to the SDHC card directly by inserting the card into a card reader. This eleminates the slow Garmin card reader from the equation and transfers are done in a fraction of the time. No maps will be on the nuvi - they will all be on the memory card instead. To update the SD or SDHC card, do this:
1) Repeat steps 1 thru 5 above. This removes the maps files from the nuvi.
2) Disconnect the nuvi from the computer.
3) Connect a card reader to the computer.
4) Insert the SD or SDHC card into the reader.
5) Locate and delete the GMAPPROM.IMG (or GSUPPROM.IMG) file(s). Optionally copy (instead of deleting) them to your hard drive in case there is a problem wit the new map file(s).
6) Update the map to the SD or SDHC card.
When either method is employed, only one map file set will result. GMAPPROM.IMG or GMAPSUPP.IMG is the name of this file set. You should ensure / change the name to GMAPPROM.IMG. Any subsequent file set added should be named GMAPSUPP.IMG.
I hope this helps & good luck! Please rate my reply - thanks.
Jun 27, 2011 | Garmin nuvi 200W GPS Receiver
Have a new DV700 and bought a PNY SDHC 4 GB card for it. DV says "Card Full" when installed, lock off. Tried to format --- PC saids "windows cannot complete formatting". PC is...
The DV700 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it's electronically incompatible and won't work with this camcorder. You need to use SD cards, 2GB and smaller.
Feb 22, 2011 | VistaQuest DV-700 Digital Camera
I am trying to download the Mexico 2011 map and the download stops because it states I do not have enough space. They advised a 4 GB SD chip which I purchased and installed. The download still stops and it...
When you go to download the map by default it tries to download it to the satnav i.e. not the SD card. When the website recognises the satnav it shows it in a drop box with a drop-down arrow. Click the drop-down arrow and it should give you the option to download the map to your computer. Download it to the hard drive.
After it's downloaded it may begin the install automatically. If not click the START button on your computer and go to GARMIN. In the garmin menu click MAPINSTALL to begin the installation.
When the install program finds your satnav and you get the option to install the map there again click on the drop-down arrow and select the drive letter of the SD card. This will be different to the drive letter for your satnav. The map will then be installed to your SD card.
Before you begin to install to the SD card you should know that it can be very hard to get get the 200W, and other satnavs of the same age, to run the map from SD cards. It will install to it without problem but when you try to operate the satnav then it cannot load the map and will close down again unless you remove the SD card. I recently had this problem with a garmin nuvi 760 and contacted garmin about it. They told me the problem is that 4 Gb SD cards are SDHC which operate differently from SD. They said to get a class 2 SDHC card. (You can identify the class by the small figure on the card. It will be either 2, 4, 6, 8, or 10). Before you install the map format the card. Also use webinstaller to check that you have the latest version of operating software on your satnav.
Format the SD card with "Panasonic SD Formatter" available from
rather than the standard windows format function. Select the fast format option and be sure you have selected the drive letter of your SDHC card as it will format your hard drive just as easily if you select it by accident or your satnav.
To update your software you can download webupdater from
Connect your satnav to the computer and run the program. It will search for any updates to your software.
Class 2 SDHC cards are available on ebay if you can't find one in the shops.
After failing to get mine to work on a class 4 SDHC 4Gb card I followed their instructions and it worked for me. Hope it works for you too.
Oct 27, 2010 | Garmin nuvi 200W GPS Receiver
PNY SD 4gb card dose'nt work....
Do you know if your Archos 605 media player supports schd cards? SD and SDHC is not compatible.
So if your Archos 605 is not sdhc compatible no sdhc car will work.
I hope you find this information helpful.
Sep 20, 2009 | PNY 4GB Secure Digital High Capacity...
I have just bought a Garmin Nuvi 770, updated to the latest software version. Garmin site states 700 series can use 4gb sd card. New Crucial card failed to format (win xp SP3), sent it back and...
Problem solved. I bought a cheap 'integral' usb 2.0 sdhc compatible mobile card reader. Formatted rapidly and files loaded extremely fast.
Sep 23, 2008 | Garmin GPS
I have loaded the PNY SDHC into my Nikon 80 and it works fine. # P SDHC4G4-FS. I can view the pictures taken using the screen on the camera. When I try to download the pictures to my PC it will not...
Some card readers in pcs can't read cards over 2gb due to a flawed driver. Check on the web Not manufacturer! for a better driver. It's not this if you can normally read >2gb sdS
Jun 14, 2017 | Computers & Internet
How do you get SD cards to play ???
Are the songs in MP3 format? Typically you connect the GPS to the PC using the USB interface and using Windows Explorer, drag & drop the MP3 files into the GPS's MP3 subdirectory.
Then on the main screen, select travel tools and then the MP3 player. Select browse and choose a song.
Please let me know if I can be of further assistance to you.
- Jim
Feb 22, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
2,945 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
