Question about Flat Panel Televisions
Wharfedale lcd 26inch tv keeps shutting off
Our wharfdale (hdcld26 i think is the model) keeps turning itself off,it is not overheating ,it can take 10-20 min to be able to turn on but only after you have killed the power,and then turns straight back off again,in the end we give up,any ideas would be of great help! it has only just started doing this.
SOURCE: TV turned itself off, won't turn back on
I had the same issue with my 42HP95 after about two and a half years. Same symptom, red flashing power light, reset doesn't work and most of all, the last day of the Ryder Cup starts in 3 hours. Any other time (with exception of SuperBowl Sunday). I frantically searched the web for like symptoms and came across someone that posted the fix was to bypass the Seine Module but I had no clue what that was! So what do you do? Tear off the back of the TV and look for something that says Seine on it... Right! After that failed and 500 screws later, I decided to look for a Service Manual online. Nothing like RTFM (Google it!). I paid my $11.99 for a download Service-Manual.Net and found what appeared to be the Seine Module (SEIN). Through a little trial and error, here is what I came up with. The pic below shows the location of the said Module in the red rectangle.
78c6772.jpg I ultimately found that if I unplugged the connector from the module (in red circle) and put it in the cable management loop (other red circle), the TV would power on and has been working ever since.
According to the post I read (grains of salt) the SEINE Module is only needed if you are using coaxial type (rabbit ear) antenna. I personally don't know but it works for me. Granted, this is my experience and may not work for you but for $12, I am a happy camper. BTW, what a Ryder Cup!!! USA USA USA!!!
Posted on Sep 22, 2008
SOURCE: Wharfedale TV power problems
got a 32 inch wharfedale tv from argos also and it seems to boot up and then shut down and just loops, if i keep unplugging it i can sometimes get it on but with a high pitch wailing, only 15 months old, gutted!
Posted on Oct 07, 2008
SOURCE: Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Posted on Oct 21, 2008
  • 556 Answers
SOURCE: keeps turning itself off with a red light next to
have you changed the lamp in this set. If you look by the red light it probably says lamp
Posted on Aug 07, 2009
  • 11896 Answers
SOURCE: 26 inch protron lcd will turnoff in 40 min byitself
Could be overheating or the power supply capacitors are crapping out which is commom especially in newer tv's
Posted on Sep 11, 2009
  • 8457 Answers
Power board it dead,take the tv aparts.Check for Capacitors parts for puff up or burst open.Know how to solders?replaced these capacitors in the power board.Or replaced the whole power board.Tries,
Posted on Jan 19, 2010
0 characters
1 Points
When using the LCD TLP711U projector for a short time it turns itself off and will no start even after pressing the on button. After waiting a while, turning off power am able to turn it on. This keeps...
It sounds like you have an overheating issue, Look through the vent slots and see if you can see a build up of dust. If you can then you will need to open the projector to clean it properly. You could try blowing it out with a compressor but be sure to use one with a water trap to stop moisture getting into the projector. You can buy cans of compressed air from electronics stores if a compressor is not available. Some models of toshiba also have issues with the temperature sensors, They are attached to the metal heatsink and the plugs that attach them to the circuit board can loosen which makes the projector think it has overheated.
Hope this helps
Oct 25, 2010 | Toshiba LCD20 20.1 in. LCD TV
the problem occurs in ur main board...check all tge resistor in board...the faulty resistor will; allow high voltage to the main board and affect it
Oct 31, 2008 | Flat Panel Televisions
T.V keeps shutting itself off
it may be due to overheating, ensure proper ventilation, clean the ventilation grill, may be the psu is not functioning properly and being over heated, if the tv starts normally after few mins then its the case of overheating.
Jul 29, 2010 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
I need an instruction manual for a wharfdale tv model number 10HDAF
try here
Free Wharfedale owners manuals, user guides & how to instructions ...
Wharfedale manuals. Wharfedale user manuals. Wharfedale owners manuals. Wharfedale how-to instructions. Wharfedale
Nov 24, 2009 | Flat Panel Televisions
Sep 11, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
Keeps turning itself off. Reckon its an overheating issue.
LCD TV turning itself off is not necessarily overheating.
Often, because of a faulty component, capacitors can accumulate electrostatic charge until an error is detected, or a fault condition can last for a while, until a problem is detected, and the protection circuit will force the TV to shutdown.
The only temp sensor that can shut down because of overheating is placed on the main board, and TV shutdown after a while is often not caused by overheating on LCDs.
Parts that often cause shutdown after a time are Power Supply Unit, Inverter, and main controller board. Parts must be tested to find the fault. The technician can follow the diagrams detailed on service manual to find the fault.
Jul 04, 2009 | Flat Panel Televisions
Jun 16, 2008 | Flat Panel Televisions
Tuning a Funai 31B-250 VCR to a Wharfedale L22T11W-A LCD TV
i have a wharfdale L22T11W-A LCD TV. have got sound but no picture, any ideas?
Dec 22, 2007 | Flat Panel Televisions
Tv switches itself off then back on again
It seems that the back light is malfunctioning or needs to be replaced the fact that it turns off after a few seconds indicates that is getting over heated. All LCDs, Plasmas and Projection TVs come with a shut off switch witch will turn of the monitor when a spike on the temperature is detected this is to protect the system from overheating. Now before you think about send it for repair; is it well ventilated? Does air circulates around it? Good luck!
Aug 27, 2007 | Samsung LN-S4051D 40 in. LCD Television
This tv has inbuilt freeview, how do i use a dvd recorder to record off it?
The Wharfdale Machine that has Freeview has an F on the end ie vdrhd400f. It may be yours is an analogue version. Always possible that you can use the TV as an output via a scart to record what you are watchin
Jul 14, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Flat Panel Televisions Logo
549 people viewed this question
Top Flat Panel Televisions Experts
Are you a Flat Panel Television Expert? Answer questions, earn points and help others
