my camera will not turn off /on. lens is stuck in out position.changed batteries cleaned contacts, nothing!Been told these r known for this. this is my 3rd easy share
This is a common problem for the Z1285 but no more so than with most digital camera's.
Most of the time the problem is that sand , dirt and grit gets lodged in the camera lens barrel thus keeping it from extending properly but could also be caused by a drop or a hard knock on the camera.
Firstly , the odds are not with you on a DIY fix so don't be disappointed when the following steps do not work.Nevertheless , some people have fixed their camera's using the following steps.
Use these at own risk as it may further damage the camera.
Try connecting your ac adapter or usb cable. Try holding the shutter button while switching on the camera.
These 2 options provide your camera with more power available to the extension mechanism which could overcome some of the particles that are lodged in there if there are any.
Try using compressed air (best is a clean air can bought at a electronics store) and blow between the lens and the casing. This should help dislodge some of the particles.
Look at the lens , and if some of the lens 'circles' are misaligned or not concentric then try wiggling it (while holding camera lens down) so that some of the particles can escape. Also try moving the lens away from the side with the biggest gap (also upside down)
Try gently pushing or pulling the lens when it tries to extend but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
As a last resort if you decide to replace the camera try hitting the camera near the lens with increasing force with the palm of your hand. Between each hit , try using it again.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise works. Good luck and don't hesitate to contact me if you need further assistance or information.
Regards Stephan
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Kodak EASYSHARE Z1285 Digital
I turn on my Camera and the screen pops up but i cant touch any buttons or I cant take a picture?...
(More)
I turn on my Camera and the screen pops up but i cant touch any buttons or I cant take a picture? Please help me please!
kodak easy share z1285. the batteries dont last past 10 pictures. it used to take 100+. i am...
(More)
kodak easy share z1285. the batteries dont last past 10 pictures. it used to take 100+. i am still using the same type of batteries now as i was using when it worked fine. ive had the camera since april and by july it was taking a downward spiral fast. please help. its never been dropped or got wet. ive looked online and everyone who has this camera wishes they never bought it. its the same for everyone. i just want to know can it be fixed or do i toss it in the trash. thanks josh
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
