Lexmark X6170 All-In-One InkJet Printer
Problem for Lexmark X6170 All-In-One InkJet Printer
Cartridge Error 50C consult user guide. I
By Viv.Rob.2511 on Nov 10, 2009
Cartridge Error 50C consult user guide. I followed the instruction, worked for a while and still having same problem. Now refuse to print
Solution #1
posted on Nov 10, 2009
Somewhat Helpful)
57 varieties
Rank: Guru  Computer Hardware  Expert
Rating: 88%, 549 votes
Error messages; Error: "Cartridge Error 50C"; Cartridge error; Black cartridge missing; Color cartridge missing Solution Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
Was this helpful?
Yes
No
Popular Solutions for Lexmark X6170 All-In-One
Questions and Unsolved Problems for Lexmark X6170 All-In-One
Do you recommend Lexmark X6170 All-In-One InkJet Printer?
Answer
Answer
my printer keeps saying color cartridge missing
Answer
Have a 2 year old HP m8330f AMD 9500 quad running Vista. Working fine until about 6 months ago. Then... (More)
Answer
mESSAGE: pRESS POWER & THEN CLEAR PAPER JAM- tHERE IS NO PAPER JAM-wILL not PRINT
Answer
shared x6170 on XP desktop and trying to print to it from wireless vista laptop. loaded vista driver... (More)
Answer
When I refill my lexmark 44xl cartridge the printer says there is no ink in the cartridge after it... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
