Question about Garmin StreetPilot i5 GPS Receiver
Garmin i5 All of a sudden my garmin stopped working I can't get it to turn on. I took it out of car from the lighter plug in tried changing the batteries inside the house and I still can't get it to turn on. I read the manual and no where does in indicate trouble shooting problems. Can I return it to the manufacturer. I have only had it for one year and 3months
  • 1 more comment
  • Damick1 Jan 29, 2008
    Same problem, works fine in car with cable connected, but not with new batteries, won't activate at all ??? Garmin support does not respond.
  • KIS1 Feb 07, 2008
    Lost power with two of these units. Power faded in and out with the second unit, now seems to be lost for good. Tried using the power cables in two different power sources in the car and then repeated the effort with the power cable from the first Garmin - still no power... Any suggestions?
  • UVaGooner May 08, 2008
    I got into my rental car today (I'm on vacation) and noticed my i5 was still on from yesterday - it never powered down (I left it plugged into the car). While keying in my next destination, the screen went blank. Thinking it was the batteries, I replaced them but it's still blank.
Resetting Your StreetPilot
If your StreetPilot freezes (stops responding to button presses), try turning it off and then on again. If this does not help, remove the batteries and then reinsert them. Disconnect from external power, if necessary.
Clearing all User Data
If resetting does not fix your problem, you may need to clear all user data from your StreetPilot.
• IMPORTANT: zf you clear all user data, you will delete all saved locations from My Favorites I and all settings in your StreetPilot. Be sure you want to clear all user data before proceeding.
To clear all user data, press and hold down all buttons in the following order: ciJ, Wheel, Power.
Continue holding down all buttons until you see a prompt, “Do you really want to erase all user data?”
Select
Yes.
Posted on Apr 07, 2008
6ya staff
SOURCE:
Garmin says low battery and now will not work in the car. Does this Garmin have a battery inside the unit that I have to replace?
There is a battery in the satnav but it's not user replaceable. It can only be replaced by returning it to Garmin. Before sending it away to replace the battery you could check the following;
  • Have you the satnav connected to the charger?
  • If it's connected to the charger is the cigarette lighter socket working. You can check by plugging in another device to see if it works
  • If the cigarette lighter socket is working and the battery of the satnav is not charging it's possible that the fuse in the plug, that goes into the cigarette lighter socket, is blown.
To change the fuse;
Unscrew the ring that's at the end of the plug and the plug comes apart. Be careful not to lose the silver coloured tip. When the plug comes apart you can take out the fuse and get a replacement at any car accessory shop or a shop that sells garmin satnavs.
If you have to return your satnav to garmin you can find their contact details at http://www.garmin.com/garmin/cms/home/support/supportcontact
May 23, 2011 | Garmin nuvi 255W GPS Receiver
I just took my Garmin 1200 out of the box and plugged it into the cigarette lighter in my car and it did not work...I have a blank screen...my car is 12 years old!
No power at all?
Check your lighter socket to see if it's getting power (plug lighter in and see if it gets hot). Check the power plug on the provided cable. It contacts a fuse that may either be missing or blown. And last, check the connection of the cable as it plugs in the rear of the Nuvi.
Mar 12, 2011 | Garmin nuvi 1200 Car GPS Receiver
MY GARMIN NUVI 650 NA SUDDENLY STOPPED WORKING. WHEN I TOUCH THE SCREEN NOTHING HAPPENS... (THIS MACHINE HAD BEEN WORKING SINCE 2007). PLEASE HELP
Is it charged? If you are using the cigarette lighter adapter plug, there is a fuse in the silver tip of plug...... unscrew it carefully..its spring loaded... check fuse
Oct 27, 2010 | Garmin Nuvi 660 GPS Receiver
I have a Garmin i5. I have used it for years but on a recent trip it just stopped working. By this, I mean it won't turn on. I tried switching batteries several times, and the reset described by holding...
try plugging it in to the usb port on your computer, then if it starts, install the batteries.
if you did not get a usb cord with your gps, pretty much any usb to mini usb cord will work.
bill
Oct 12, 2009 | Garmin StreetPilot i5 GPS Receiver
Garmin nuvi 255 won't turn on
Have you tried doing a hard reset,try using the reset button on the bottom of the gps under the serial label.Or try holding the turn off button for about 10 seconds,good luck.
Aug 31, 2009 | Garmin nuvi 255W GPS Receiver
Garmin screen is all i get, then it turns off
try changing the batteries or placing the device on charge and unplugging it, if both those don't work go to the support section on garmin's website www.garmin.com/support/
Aug 04, 2009 | Garmin nuvi 200W GPS Receiver
My Garmin Nuvi (200 I think) freezes..
My recomendation is to use the original accesory for cigarete lighter. I'll give you an example: when I connect my Nuvi 200 to any other USB cable (computer or home charger) its behaviour is like you said - it "says" that is connected to a computer and remains in stand by. But when I connect it to cigarette lighter (but note - the original one) the nuvi 200 recognize it as a car power source and works. The battery symbol disappear from screen and it works perfectly. When I turn off the engine or simply unplug the device from cigarette lighter (not from nuvi !) it recognizez that and ask me if I want tu turn it off on remains on on own battery. If I make no option the nuvi will turn off automatically after some seconds. So it recognize perfectly the car adapter and its behaviour is adapted to a car.
Oct 08, 2008 | Garmin Nuvi 350 Car GPS Receiver
Gps - street pilot i5 garmin
try this first-if the unit has batteries installed, remove them so unit runs on power cord only
Jun 01, 2008 | Garmin StreetPilot i5 GPS Receiver
My garmin i5 doesn't know where it is +
I would suggest that you return it to Garmin since it's still under warranty. My Garmin i5 will NOT operate on just batteries. This unit is also under warranty. Also, the suction cup mount fails to hold onto the windshield. I've been concerned about how many people seem to have problems with these units.
Aug 14, 2007 | Garmin StreetPilot i5 GPS Receiver
Garmin c330 street pilot
The lighter socket does it work. Because it to has a fuse. ck your car fuse box (mini fuse).
Oct 29, 2006 | Garmin nuvi 350 GPS Receiver
Garmin StreetPilot i5 GPS Receiver Logo
168 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Sheldon Dedek
Janelle Schoonover
Janelle Schoonover
Are you a Garmin GPS Expert? Answer questions, earn points and help others
