Canon PowerShot A620 Digital Camera
Problem for Canon PowerShot A620 Digital Camera
Canon A620 LCD shows "memory card locked" for each card I insert
By mbertrand on Nov 10, 2009
I have a Canon PowerShot A620. I've been using three different SD cards in it for some time with no problems. All of a sudden, I get a "memory card locked" on the camera's LCD for each card I put in. Cannot clear it using the camera set up menu nor by adjusting the lock mechanism on the card (each shows unlocked). Not sure what else to do. How do I get my camera to unlock the cards? I even removed the batteries and reinserted them thinking it may "reboot" and clear this problem, but it didn't.
Comments:
Nov 12, 2009
- I tried your recommendation, but it didn't work. I saw the switch you described,and tried to adjust it but was to scared to mess with it too much in fear I may damage it. I'm sure the switch is the problem, as you described. I may send it in to repair. Thanks for your suggestion. At least now, I understand why it is giving me the "card locked" message. Thanks again!
Nov 13, 2009
- I may attempt to repair it your way...one more time wehn I have a little more time to devote to it. If it ends up working, I'll certainly let you know.
Best Solution
posted on Nov 10, 2009
Very Helpful)
StephanSA
Rank: Guru  Canon Cameras & Camcorders  Expert
Rating: 93%, 184 votes
If you open you sd slot and look inside with a bright light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a pin or sowing needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Stephan
Comments:
Nov 11, 2009
- Did the advise solve your problem?
Nov 13, 2009
- It's a pleasure , pitty it didn't work.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" I've been baffled with why my camera is showing the sd card is locked. I'm anxious now to get home to try your solution! I'll bet that this will work! " - mbertrand
Popular Solutions for Canon PowerShot A620 Digital
Questions and Unsolved Problems for Canon PowerShot A620 Digital
Do you recommend Canon PowerShot A620 Digital Camera?
Answer
Answer
is it possible that the 2gb lexar is not compatible with the powershot A400?
Answer
My camera has a white speck of dirt underneath the first lens, and does interfere in pictures and... (More)
Answer
camera used in light rain, flash banged and quit, works otherwise is it possible to fix myself with... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Canon PowerShot A620 Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
