Question about IBM ThinkPad T30 2366 Notebook
Powers up but never goes to boot up screen
My ibm T30 powers up but will not go to the boot up screen, i also have to press the power button multiple times sometimes before it turns on as well. pleas help thanks.
    Scholar:
  • 48 Answers
Be sure your hard drive is not dead. When you turn it on put your ear on the palmrest and listen for a small spin up noise. Then you should hear a light click sequence. If the hard drive is bad you wont hear that noise.Bad noise will be more unpleasant and repeatitive. You can go to your local computer store to get a new hard drive. An associate will help you find the right one based on model.
If it does spin and hum smoothly then hit F2 or Del at your first boot screen and go into the menu
It should have information on the home screen if it is a tabbed bios. otherwise go into standard cmos setup (or similar) find your hard drive, usually IDE Channel 0 and the brand of your hard drive should be listed there. If not the hard drive is probably faulty. If you do see your drive listed, you need to run a repair on the operating system.
Use your windows xp cd to boot from, you will need to go back into the BIOS and set cdrom to first boot device. Boot from the cdrom and wait until it gets to a blue welcome screen, at that moment press f2 and it will bring you to the recovery console. from there type chkdsk /r and let it scan your drive for errors. after your computer should boot. if not boot from the cd again, get back into the recovery console and type "fixboot" and "fixmbr" to repair boot sector information for your drive. if you get no results, go back into the cdrom boot and instead of pressing F2 at the blue screen press enter and follow on screen instructions. After you F8 through the license agreement, you will soon come to a
screen that lists the operating systems found, press R to
repair your OS. If your OS name is not listed there, you can either try a new installation from this point or attempt to register your operating system into your boot record manually and trying once more to boot from it. if the below method does not work you will have to boot from the windows cd and do a new install of windows. also, you will need any restore disks that came with the laptop.
You may also have a recovery system on your computer that is built in. refer to your user manual to find out how to activate that feature. It can also be a CD included that has all your drivers and software on it. Use your resources.
Posted on Jan 07, 2008
  • 89 Answers
Does it generate any error messages?
IBM Thinkpad T30 2366 won't boot after the IBM Thinkpad screen
you can go to the BIOS setting? if you can,look for "Boot Device Priority" or something like that,it's usually placed on Advanced settings. Set the first boot device as your harddisk,save the settings and restart your computer
Please let me know if it's working or not
Aug 28, 2012 | IBM ThinkPad T30 2366 Notebook
IBM thinkpad T30.The power button turned on then nothing boot up power LED light is on.
Remove battery and power for a minit, install it again, power up mains and try again. This helpe me here in Paraguay several times.
Saludos Wolfgang
Dec 11, 2009 | IBM ThinkPad T30 2366 Notebook
IBM Thinkpad T30 wont boot up
You have faulty RAM modules. Reseat your RAM modules, to make sure they make proper connection. If this doesn't work take them to your friendly computer shop and ask them to test them for you.
Apr 29, 2009 | Lenovo ThinkPad R51
T30 Intermittent Booting Problems - Depending on screen angle
It is issue with the screen cable connection. Replace it. or it is getting chaffed and causing issue in proper signal and power to the screen. It is hardware issue.
Apr 24, 2009 | IBM ThinkPad T30 2366 Notebook
IBM T30 2366-FBU, will not boot passed Logo screen
Press all of the function buttons one at a time until you get a response. Not all laptops use the same buttons for Bios and choosing the boot device.
Also, it won't boot from the CD-ROM because the bios boots from the Hard drive first by default. You can change this in the BIOS.
Please rate, Thanks!
Feb 27, 2009 | IBM ThinkPad T30 2366 Notebook
T30 motherboard problem
press f8 on boot up. select safe mode
Go start>run
type msconfig
hide all micosoft items in services and deselect the remoaining
Also deselect any "dghdfg" looking items from startup
Reboot
Install CCleaner & run
Dec 12, 2008 | IBM ThinkPad T30 2366 Notebook
T30, replaced fan, no boot, no beeps
Did you replace the fan because of a no start problem, or something else?
Aug 30, 2008 | IBM ThinkPad T30 2366 Notebook
T30 Power up problem
The c-mos won't cause this. The power button is integrated into the keyboard, and uses the same connector as the keyboard to get power to the system. In most cases, the board with the power button (which is part of the keyboard) is worn out. Occassionally the keyboard connector will work loose or get a little corrosion or dirt and not make a good contact, check and clean the connection. If the connection is good, then I'm afraid you will need to replace the keyboard in order to cure the problem.
Jul 15, 2008 | IBM ThinkPad T30 2366 Notebook
IBM Thinkpad T30
Try starting without the battery, and cheking the memory chips.
Jul 04, 2008 | IBM ThinkPad T30 2366 Notebook
Stopping at the BIOS Splash screen
Hi
Reseat all the RAM, CMOS battery and any PCI graphics cards and then try to boot the computer.
Also remove all the memory cards and then turn on the computer. If you dont get any beep sounds, then it is a problem with 1 or more RAM cards.
Then alternatively try with 1 RAM at a time in different slots and check if it is a problem with any of the RAM cards or the RAM slots.
Feb 26, 2008 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
212 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
