Question about Standard (CRT) Televisions
Analog Tuner Does Phillips Magnavox Model TS2746 C101 have a digital tuner?
  • 1694 Answers
SOURCE: Sharp 27G-S60 TV analog or digital?
Call 1-800-237-4277 1-800-BE SHARP
FAX 1-630-378-9981.................................................
Posted on Nov 20, 2007
  • 790 Answers
SOURCE: tv color picture sharpness is messed up
Is your Tv Blurd?
Posted on Nov 12, 2008
SOURCE: Sony FD Trinitron WEGA TV Model Number KD27FS170 digital tuner problem
I have the same TV and was unable to get the digital channels until today. I think you need to connect your antenna on the back of the TV to the ATSC jack. If you have had it connected to the VHF/UHF jack, it won't detect the digital signals. Once you have the antenna connected to the ATSC jack just Auto Program your TV and you'll find all the digital channels in your area. Good luck!
Posted on Dec 31, 2008
SOURCE: Is my Toshiba TV digital or analog?
if there is a label on the tv stating any of these words “Integrated Digital Tuner,” “Digital Tuner Built-In,” “Digital Receiver,” or “Digital Tuner,” “DTV,” “ATSC,” or “HDTV” then yes
if they say “Digital Monitor” or “HDTV Monitor,” or as “Digital Ready” or “HDTV Ready" then no
Posted on Jan 08, 2009
  • 346 Answers
SOURCE: phillips magnavox smart plus Model TP3284C101
if there is a DTV label on it , then it is digital .check the manual
digital would have the following : atsc ,hdtv ,digital tuner ,dtv
Posted on Jan 23, 2009
  • 4234 Answers
SOURCE: Hitachi 57G500A DTV & upcoming analog to digital changeover
To answer your direct question, yes it has a digital tuner. To answer your real question, NO it WILL NOT receive the new ATSC (digital) broadcast stations. The tuner itself is a digital one but works only for analog signals. The changeover in February will change the broadcast signals to a new digital format that will require a converter for your set to continue to function. Please note that the converter is only required if you receive your signal from rabbit ears or a rooftop antenna. If connected to cable or satelite, no change will be seen and no converter is needed.
To simplify:
Over air reception = need converter
Cable or satelite = no converter
Posted on Jan 28, 2009
0 characters
1 Points
RCA Guideplus gold gemstar analog or digital
Most of the RCA GuidePlus Gold gemstar TVs worked with analog TV signals (NTSC) only. The Guide+ information was only broadcast in NTSC signals and is no longer being provided. If you can check the date of manufacture of the TV, you can use the size to check if it had an ATSC tuner added if it was made for the US market. 37"+ TVs had to have a digital tuner in second half of 2005. 25" TVs needed to have the ATSC tuner after March, 2006. The next year all TVs had to have a digital tuner.
I hope this helps. Please add a comment with the model number of the TV, if you would like me to confirm the tuner information on your set.
(The RCA F31317 TV with Guide+ was manufactured in 2000 and thus only has a NTSC tuner.)
Dec 26, 2015 | RCA Standard (CRT) Televisions
Does a magnavox model 27ms4504/17 have a digital tuner? Manufactured September 2005
Hi, Sorry it does not. It has an NTSC tuner which is analog. It will work after the change if you have cable or satellite. Hope this helps!
Feb 05, 2009 | Philips Magnavox 27MS343S 27" TV
How do I know which converter box to buy?
here are the specs for the Magnavox TB100MW9
Product details Smart antenna ? No Closed Captions ? Yes CECB certified ? Yes Recorder ? No EPG ? Yes NTSC tuner ? No Analog cable tuner ? No QAM tuner No Component video inputs 0 S-video inputs 0 Composite video inputs 0 Digital audio input No digital audio inputs DVI outputs 0 HDMI output No Component video outputs 0 S-Video outputs 0 Composite video outputs 1 RF outputs 1 Digital audio output RCA output 480i Yes 480p No 720p No 1080i No 1080p No USB/USB2 No Ethernet No
Jan 04, 2009 | Standard (CRT) Televisions
Phillips magnavox smart plus Model TP3284C101
Jan 02, 2009 | Philips TP3284C 32" TV
Does the GE 35GT740 model have a digital tuner?
As far as I know, this set DOES NOT have the required tuner capability. Please note that the changeover only effects those using rabbit ears or a rooftop antenna. If you have cable or satelite, no change will be seen. The change over is from an analog broadcast signal to a digital one. Your set has a digital tuner that expects an analog input signal.
Hope this helps,
Dec 31, 2008 | GE 35GT740 35" TV
Does my tv have a digital tuner (RCA Model E13320, 2/2001)?
The digital tuner has nothing to do with the new signal you will be receiving in February of next year. The new video signal is a digital signal. The old video signal is analog. Your television receives the analog signal and converts it to what you see on television. You need a converter box to convert the new digital signal back to an analog signal your television can convert.
Nov 07, 2008 | Standard (CRT) Televisions
Magnavox TV
Salutation TrudyK,
Great question! First think to know is that if you are getting your programing from a cable or satellite provider a digital converter box would not be needed. These services are not being required to change their signals. If you use rabbit ears or an antenna a digital converter maybe required.
Looking at the specifications of your televisions they all appear to have analog tuners which would need digital converters to receive the new digital broadcasts.
Thankfully the FCC does have a program in place to offer coupons to assist in purchasing the new converter boxes.
For more information on the digital transition and coupon programs has a FAQS, wuizzes and tutorials available at
Go Ahead. Use Us.
Apr 22, 2008 | Standard (CRT) Televisions
Standard (CRT) Televisions Logo
37 people viewed this question
Top Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Standard (CRT) Television Expert? Answer questions, earn points and help others
