Removeable Disk Not Recognised
My XP system does not recognise new Sony Micro Vault 2.0gb.
I have UMSD tools 2.35 installed that works great with smaller 128mb removeable disk.
I have tried uninstall/reinstall with no success.
I would appreciate any help or advice.
Thks, Duncan
  • maha_kin2 Jul 20, 2008
    My scandisk is not recognized by the computers.
  • 167 Answers
1. click Start, point to Run, type diskmgmt.msc, and then click OK
2. If you see your drive listed without a letter, right click on it and assign it a new drive letter
if that doesn't do the trick.....
if you have any other computers laying around try it on those.
Connect to windows update and download/install all the updates you can.
Also, connect so sony's website and see if there are any drivers needed to make your system read it.
If all else fails check out their user forumns, help topics... post a topic on their forumns.... or just bring it back to the store where you got it with receipt and tell them you want a new one or a different brand
Posted on Jan 07, 2008
Compaq Mini 700EL hdd not recognised
If you are installing Windows XP then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Oct 08, 2012 | Computers & Internet
My flash doesnot open and get recognised by my please help me..
Hi . Just insert your flash in the USB slot . then go to control panel , there you'll find (add devices) icon . Click it and just follow the steps . and i'm sure that you'll solve the problem there .
good luck .
Jan 25, 2010 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
Removeable Disk Not Recognised. I have my USB labelled SONY USB 2.0 I GB. once I plug it on my computer never recognised. So am asking you to get better solutions, Regards, charles
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Nov 12, 2009 | Sony Electronics - Others
Not formatting
I had the same problem with my 1GB SONY MicroVault Clip flash drive. Hardware and the drive shows up on Vista, but it refuses to open or format it.
2) When the Micro Vault does not operate well, please download the format software from a "download" button and re-format the Micro Vault.
hope this helps guys!! :D
Apr 23, 2009 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
1GB Micro Vault Ultra Mini USB 2.0 Flash Drive not formatting
1. Download this tool:
2. Format
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Apr 14, 2009 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
Canon 450D is not being recognised by my computer (I run xp 32-bit). When I turn on the camera, windows comes up with a "install new hardware" option. I have installed the EOS utility etc. but still the...
Both the Canon XT 350D and the XTi 400D are recognized by any PC with XP windows operative system. It seems you have to check your USB port or USB cable used to connect your cameras to the PC. Sometimes, the PC does not recognize a specific device connected to an USB port. Yopu can get into the System -device manager screen, and uninstall the USB port, and run the utility to recognize changes in the device manager. This will install the USB port driver again, and if it is a software issue the reason of the problem, then it will be fixed.
Also, you can check your cameras and USB cable in a different PC so you can confirm if they both work has should be.
Mar 26, 2009 | Canon EOS 450D Digital Camera
Sony handycam discs cannot be recognised by PC
your DVD drive should support UDF . try to install this software it should give your system the ability to deal with this cd
{SwiftDisc.Burning.Wizard }
i advice you not to format the media from windows , use the tool in your camera
Jul 16, 2008 | Sony Handycam DCR-DVD201 DVD Camcorder
Sony 400gb Microvault
I have To This Deviced But I Think Its Fake I Face Also This Problem But I Am Happy To Solw U Just Plug Ur Pen Drive To Ur Pc And Run Windows Xp Proffesional Bootable Disk
Start Win Xp Setup And When U Go To Chose Hard Disk There Is Ur Removel Drive Display Delet Ur Pen Drive Partition And Creat New One And Give It To 31000 Mb Size And Make Partition FAT32 now Don press F3 And Exit Setup And Login To Ur Xp And Go TO Disk Manager Format Pen Drive New Partition U Have 31 GB Of Size That Work Correctly And Ur Unpartition Space That Show Pen Drive Is 100% Fake Just Only One Way To Use Ur Pen Drive Is This One Say Thanx If My Suggetion U Like...... Sorry For My Pour English........
Apr 09, 2008 | Computers & Internet
SanDisk 2GB Cruzer Micro: XP doesn't recognise it and asks for drivers
Try these drivers again: <Link>
Also, do a windows update, and download all of the optional updates as well.
Mar 16, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
726 people viewed this question
David Payne
David Payne
