Question about Trendware TEW-432BRP Wireless Router (TEW432BRP)
Trendnet TEW-432BRP Unable to set up on AOL broadband.Please HELP!
  • Allan King Jan 07, 2008
    Yes all the connections were made as you suggested. I'm on DSL. I believe I need help to properly configure router and DSL.
    When I do all the proper connections I get a message saying connection lost make sure cable coonected to computer. I'm totally lost.
    Scholar:
  • 135 Answers
What exactly is the problem? Are you using Cable or DSL internet? Did you connect the cable from the modem to the WAN port on the router and the computer to the LAN or 1 port on the router?
Posted on Jan 07, 2008
  • 1 more comment
  • Anonymous Jan 07, 2008
    Right now, if you use the dialer from the computer that's connected to the router, if everything has been connected correctly, you should be able to surf the web from that computer (but not necessarily from other computers). In order to set the router up properly you need to get the PPPoE information from your ISP (AOL, as you say) and configure the router (usually the router's address ishttp://192.168.1.1) with your user name, password and the other info you get from your ISP.
    If you could include a screenshot of the message (you can use the print screen key on your keyboard and then paste it into MS Paint) or list the exact message your computer gives you I might be able to help you better.
    Also, you might wanna consider trying to simply call AOL, they should be more familiar with the possible errors.
6ya staff
SOURCE:
I cannot find my pin number on my trendnet tew-432brp router
! In your browser write in 192.168.1.1. If theres an option for Configuration Pages, click on that. If it asks you for a username and password they're most likely to be
USERNAME: Admin
PASSWORD: Admin
Look for a system information setting. In that information there should be something about a WEP or a WPA key. It should tell you the key there.
Jan 07, 2011 | Trendware TRENDnet TEW-432BRP Cable/DSL...
How properly to connect TRENDnet TEW-432BRP to laptop
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Nov 26, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
How do I change the channel on my TRENDnet TEW-432BRP router?
To change the channel, you need to loginto the router management page and click on the WLAN tab.
You can find the channel information under the WLAN tab. Change the channel ( channel 1 , 6 , 11 ) are the non overlapping channels and mostly prefered.
Oct 31, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
Can't assess password to set up a new computer
Here is the PDF file that shows how to reset the router if the password is forgotten.
http://downloads.trendnet.com/TEW-432BRP/FAQ/FAQ_TEW-432BRP.pdf
Oct 14, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
No SOftware Driver for TEW-432BRP
What brand is your router? Check for the IP address of the router and default password (should be written on the back of the device). Then type the IP address into the web browser on your main desctop in the kitchen like that for example http://192.168.0.1 enter the default username and pasword and you are in the router's menu.
Set up wireless connection SSID is the name of your network that will apear when you search it, do not change any of the default settings exept the SSID , enable, and select password. Use the WPA2 and type in your desired password and press SAVE . Then go to your bedroom and try to find the wireless network you've just created. And connect. Good Luck
Jul 23, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
How to connect tew-432 brp to MT800 modem for a wireless connection
you can connect your Ethernet cable from tew-432brp to MT800.
if serial ethernet cable not work you can check with cross cable of ehetrnet also.
Mar 30, 2010 | Trendware TRENDnet TEW-432BRP 54Mbps...
Problem using Wa1003A and Tew 432 brp to share my internet
lan wires are the same. lan wires used to connect your computer to your modem can also be used to connect your Wa1003A adsl router and TEW 432 brp.
you just got some things mixed up.
1. you should set your Wa1003A adsl router to bridge mode. At this point, it will just be "pass through" device and will not be the one who will ask for IP adds from your ISP.
2. configure your TEW 432 brp with your pppoe username and password. Your TEW 432 brp will now ask the network for the IP address to that it can connect to your ISP.
3. leave your lan wires the same.
Apr 24, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
Wireless router dissconnects
Upgrade the firmwire you will find-it on www.trendnet.com
Mar 14, 2008 | Trendware TRENDnet TEW-432BRP Cable/DSL...
My TEW-432BRP doesn't work when loggin yahoo mail or microsoft update web!
what are the setting on the router and or pc and modem? Do you have any firewall or portforwarding turned on? Are you using DHCP?
Need more info...
Jan 13, 2008 | Trendware TEW-432BRP Wireless Router...
Trendware TEW-432BRP Wireless Router (TEW432BRP) Logo
112 people viewed this question
Top Trendware Computers & Internet Experts
Prashant M
Prashant M
Jeffrey Groves
Jeffrey Groves
Duncan Mutch
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
