Question about Canon imageCLASS D661 Digital Printer
No printing with Windows XP Media Center Edition, Version 2002, Service Pack 2
After plugging my USB connection from the printer (Canon ImageClass D661) to the Laptop docking station Plug and Play detects the printer and installs it.
Following the installation an error comes up that says:
Cannot configure parallel port.
If you are installing on an active port other than the parallel port, you can continue with the installation.
Continue installing?
Yes No
Of course I choose Yes since I had picked the USB001 virtual printing port during the installation. It does not ever print the test page despite stating that the printer is "Ready."
Right clicking the printer icon to choose "Properties" and then choosing the "Ports" tab and then trying to configure the checked port "USB001" it gives the error message:
An error occurred during port configuration. The operation is not supported.
What do I do to get this printer to print?
  • yanfhl05 Dec 15, 2008
    i have the same annoying problem.
  • Anonymous Jan 20, 2009
    I have the same problem with an imageclass d600 copier printer.
  • 35 Answers
Have you tried all USB ports? or installed the drivers?
Posted on Aug 19, 2008
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
I have a TSStcorp CD/DVDW TS-H552L in my HP Media Center PC, Windows XP version 2002 service pack 2. I need to know where I can get a new CD/DVDW. The one in my PC works, but will not open at times, and...
e-bay is your friend!
Just go to e-bay and enter the search for a cd/dvdrw and include the computer make and model. You'll be happy with the results.
var fctb_tool=null; function FCTB_Init_040198e985c3435a8319bc3b4305dfaa(t) { fctb_tool=t; start(fctb_tool); }
Nov 13, 2010 | Microsoft Windows XP Home Edition
Canon MF4370dn 4-in-1: scaner software installation problem
read the manual instruction.and call canon service center and get assistance from tech support.
May 13, 2010 | Canon ImageCLASS MF4370dn Laser All-in-One...
How to install usb
After you install Microsoft Windows XP Service Pack 2 on a computer that is running Microsoft Windows XP, the universal serial bus (USB) drivers do not appear to update. CAUSE After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers... loadTOCNode(1, 'cause'); After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers appear with the earlier version numbers, even though the files have been updated. uparrow.gifBack to the top RESOLUTION To resolve this problem, install Windows XP SP2, and then update the drivers for... loadTOCNode(1, 'resolution'); To resolve this problem, install Windows XP SP2, and then update the drivers for the USB devices that are connected to your computer. To update these drivers, follow these steps:
  1. Click Start, click Run, type devmgmt.msc, and then click OK.
  2. Double-click the type of device that you want to update.
  3. Double-click the specific device that you want to update.
  4. Click the Driver tab, and then click Update Driver.
  5. Follow the instructions in the Hardware Update Wizard.
  6. Repeat steps 2 through 5 for each USB device.
Note You can also install Windows XP SP2, and then disconnect and reconnect the USB devices that are connected to your computer. By doing this, you start the Plug and Play utility. The Plug and Play utility updates the version numbers for the drivers.
May 08, 2009 | Microsoft Windows XP Home Edition
Xbox 360-computer?
To connect the Xbox 360 console to this computer, you must be running Windows XP Service Pack 2, Update Rollup 2 for Windows XP Media Center Edition 2005, or Windows Vista.
To obtain your setup package or instructions for connecting your Xbox 360, select the version of Windows installed on this computer from the following list.
To determine the version of Windows XP Media Center Edition that you are running, follow these steps:
  1. Start Media Center.
  2. On the Settings menu, click General.
  3. Scroll down, and then click About Media Center.
  4. Click Software Version
    The version number of Media Center you are running is displayed.
To determine the version of Windows XP that you are running, follow these steps:
  1. On the Start menu, right-click My Computer, and then click Properties.
  2. On the General tab, under System, look for the version of Windows that you are running.
Oct 05, 2008 | Microsoft Xbox 360 Console
Which Service Pack is included with my Win XP Home Edition Version 2002?
Windows XP Home 2002 is Service Pack 1 only:
Buy a newer version.
Do not forget to rate the solution.
Many thanks.
Aug 29, 2008 | Microsoft Windows Xp Home Edition Sp2...
Xp audio driver for fujitsu amilo
Downloads results for AMILO La 1703 CLICK HERE FOR AUDIO DRIVER
CLICK HERE FOR SUPPORT PAGE AND ALL THE DRIVERS
VT8237A imbedded / VT1708A codec(HD ADeck's default setting changed)
Title: VT8237A imbedded / VT1708A codec(HD ADeck's default setting changed) Date: 04.10.2006 Size: 7,17 MB Version: 5.10.01.1080 Manufacturer: VIA Technologies Status: Released for AMILO La 1703 Language: all.gif Supports all languages Operating systems: [Supported] Windows XP
[UnSupported] Windows XP Media Center Edition (WHQL)
Minimize up.gif Use in the following products: minus.jpg AMILO La 1703
Jul 03, 2008 | Computers & Internet
My PC doesn't recognize my ZEN Vision:M
Make sure you get creative media player organizer 5 and what ever else you need.. You need to go here = http://us.creative.com/support/downloads...
PLEASE LEAVE A RATING !! THANK YOU !
Jun 09, 2008 | Creative Labs ZEN Vision:M Digital Media...
Hardware problem
Did you download the drivers straight from the manufactures website?
Mar 19, 2008 | Toshiba Satellite A135 Notebook
Canon imageCLASS D661 Digital Printer Logo
456 people viewed this question
old marine
old marine
