Question about Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher
Bottom drawer makes a weird noise
The bottom drawer i making a whinning noise and i don't hear water movement inside, also red light fr jet dry is always on.
    Sergeant:
  • 351 Answers
See if somthing stuck in rotor
Posted on Mar 02, 2008
Jfd2589kes
Locate and check the valve that feeds water to the icemaker.
Jul 04, 2017 | Refrigerators
My Fisher Paykel DD603I top draw whines when it is first turned
The lid seal on the top drawer is faulty and needs replacement. It might be cut or damaged and is obstructing the drawer from closing. THis also may have caused the flood switch to trip as water can leak if drawer is not sealed.
Nov 29, 2012 | Fisher and Paykel Dishwashers
Pool cleaner will vaccuum but no movement in pool. plenty of water pressure going thru back hose
Before doing anything, take the Jet Vac out of the pool and set it on the deck. Stand clear and turn it on. It should have enough water going through the blue jet to spray several feet and propel the jet vac on dry land.
What propels the Jet Vac is not the water going through the hose, but the water going through the little blue Jet under the Hose. You can unscrew this from the bottom of the shell and clean out any obstructions. Also, check the screen at the connection where the hose meets the wall. It is located in the white valve with the red button on it right at the pool wall. It will unscrew from the wall of the pool with the system off. Also make sure the booster pump is coming on.
Also, it may be stuck in reverse or neutral. If this is the case there will be jets of water shooting forward of the jet vac when it is on dry land.
Apr 15, 2011 | Pentair Jet Vac Venturi Shell Blue Jv2c
Dishwasher makes a whinning noise during the washing cycle. I have opened to check inside, and the dishwasher is ok for a few minutes, then it starts whinning again. The dishwasher is just over a year old,...
If wash quality is OK leave it. Pump will make whining noise due to its' ball/bush bearing problem.
Some times if the water inlet flow is not free in flow also results in noise.
Clean the inlet water filter and check the flow before re- connecting to the machine.
Aug 30, 2010 | Dishwashers
Jenn-Air JCB2059ES refrigerator makes weird noise
Sounds like the plastics are just rubbing from vibration. redistribute the contents of the drawer and see what that does. Good Luck.
Nov 21, 2009 | Refrigerators
F1 flashing on and off on both sections
F1 flashing means the flood switch is activated. This is located at the base of the housing under the bottom drawer. YOu will have to find if there is water collected at the base by extending out the bottom drawer. Make sure the power is turned off.
Use towels and hair dryer to dry base out. The terminals of the switch will have to dry out as well. Quicker way would be to get the bottom drawer out and fix it back after the drying operation.
Next you will have to find the source of the water collection. Cracked hoses, broken actuator link arm (that holds up the wires and hoses to allow the drawer to move in and out without getting entangled) or foaming inside the drawer due to use of incorrect detergent.
Good luck
Nov 16, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer stopped first with F1 and would not turn off. Now 2nd drawer is the same ,Had to turn off power to diswaher .
F1 means the flood switch is activated. This is located at the base of the housing under the bottom drawer. You will have to find if there is water collected at the base by extending out the bottom drawer. Make sure the power is turned off.
Good luck
Our Samsung HL-P4663W DLP is makes noise and shuts off
It is the color wheel, inside the light engine. The bearings get dirty and makes it harder for the wheel to spin causing that whin.
Jan 06, 2009 | Samsung DLP HL-P5663W 56" TV
Dishwasher error
The error was a flood fault, water was not draining from either of the drawere, I removed the bottom drawer, dried drip pan and used hairdryer to dry fault sensor, the dishwasher then reset itself and works fine.
Dec 31, 2008 | Fisher DS603W / DS603B / DS603I Dishwasher
Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher Logo
346 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
