Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
Problem for Fisher and Paykel 24 in. DD603H W Built-in Dishwasher
F1 flood keeps going off all the time on the top
By theskogs on Nov 10, 2009
F1 flood keeps going off all the time on the top drawer and every other time on the bottom drawer. About 3 years old. No hose leaks that we can see, not flood switch any ideas?
Comments:
Nov 10, 2009
- to add to the top question........it seems worse when I use the delicate or fast cycles but does not flood as often (on top) does not flood on bottom when the heavy load is selected, hmmmmmmm
Solution #1
posted on Nov 16, 2009
Not Rated)
doglt
Rank: Guru
Rating: 90%, 193 votes
About 3 years either the lid seal is going bad or the actuators had a problem. These things prevent the seal from properly seal on the top of your tube then causing a leak to the bottom hosing of each drawer. If you pull out the tube you can see the bottom housing is wet. Based on what you described, I can see the bottom is on the top drawer. When it leaks so much, part of the leak is coming down to the lower one. The flood at the lower bottom housing is less then from the the upper one.
Was this helpful?
Yes
No
Popular Solutions for Fisher and Paykel 24 in.
Questions and Unsolved Problems for Fisher and Paykel 24 in.
Do you recommend Fisher and Paykel 24 in. DD603H W Built-in Dishwasher?
Answer
Answer
both draws flashed up Red F1, i got it outside and drained it out and ran a cycle through it, about... (More)
Answer
replace backflow preventer in both draws. where to get parts.
Answer
The dishwasher is making a horrible noise. Could it be the motor? Tried running both drawers and... (More)
Answer
F Paykel two drawer: first the top drawer would not close because of the plastic bracket in the back... (More)
Describe your Dishwashers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
in Newport, KY
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
