Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Tv projection image going wrong,
The color/image cant be adjusted?! i change the convergence chip for a 150, plz, take a look on my screen http://img2.putfile.com/thumb/1/519205763.jpg thx alot for your help
j-f xjeff1@hotmail.com
  • premiumlude Jan 07, 2008
    yes, the 2chips. i will looking for the resistors. and change it if needed, thx for your help
  • Panasonic Master
  • 8,617 Answers
Did you replace both chips stk392-120 ? Also check the resistors near the heat sink for being open. They are light blue no bands. There are roughly 7 of them identical looking but some have different resistance values. These often go open when the convergence ICs go out. Hope this helps let me know what you find.
Posted on Jan 07, 2008
Sony 51" projection tv standby light blinks 6
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc
Dec 15, 2010 | Sony KP-51WS520 51" Rear Projection...
My tv is almost 6yrs old and all of a sudden the picture is blury almost showing double images. The color is also of at the top and bottom of the screen.
this is typic old projection tv, some tecnical ajust parameters have reset, so if you can adjust,this settings on service menu on tv, or ask for help on local repair store, to calibrate scren.
Nov 29, 2009 | Televison & Video
Picture blured
Your TV most likely has one or more possible problems.
  • Screen looks 3D
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 30, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Double image, blue adjusted, red won't adjust
  • Screen looks 3D
Apr 19, 2009 | Philips 51PP9910 51" Rear Projection HDTV
Hitachi TV, has red ghost lines outlining image on screen! Help!
  • Screen looks 3D
Apr 07, 2009 | Hitachi 43UWX10B 43" Rear Projection...
We own a Hitachi 51swx20b and is now experienc ing blurred projection or doubling of screen on only half of the set. Color is now wrong and magic focus does not cure problem, Help thank Phil
  • Screen looks 3D
Apr 02, 2009 | Hitachi 51SWX20B 51" Rear Projection...
Poor colour balance
  • Screen looks 3D
Mar 17, 2009 | Hitachi 46F500 46" Rear Projection...
Phillips 46pp93
  • Screen looks 3D
Dec 31, 2008 | Philips 46PP9302 46" Rear Projection...
5yr old philips rear projecter tv color bad 50inch
  • Screen looks 3D
Dec 01, 2008 | Philips 9P5034C 50" Rear Projection...
Dull colors with no red colors
  • Screen looks 3D
Sep 22, 2007 | Philips 55PP9401 55" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
