I cleaned the top of stove and now have eo and f2 errors; I used a damp washcloth and did spray cleaner on the control panel but not pressure cleaned or dumped water on it
I have a Magic Chef range.. it has a flat control surface and when I push the BAKE spot...nothing...
(More)
I have a Magic Chef range.. it has a flat control surface and when I push the BAKE spot...nothing happens...but it responds when I push clock or Broil. I thought it was the ignitor..so I bought a new one and replaced it..but the oven still won't work. Any ideas?
I have A problem With digatial read out going blankI know there is aproblem in the past I think it...
(More)
I have A problem With digatial read out going blankI know there is aproblem in the past I think it is the board under the touch pad comes back on if it cools back down and or you bump the top
Dear Sirs I have a kitchenaid electric range, model # KERC507HWH2 with serial # IML0821910. The top...
(More)
Dear Sirs I have a kitchenaid electric range, model # KERC507HWH2 with serial # IML0821910. The top burners all work, the light and control panel all work but the oven and broiler do not heat up when turned on. I have unplugged the oven and tryed to restart it and have made sure the key locks are off. I have read that the oven fuse is often the problem but how do I get to it? Do I need an ohm meter to test continuity of the various circuits. How do I fix my oven and broiler? or which circuits/switches/components do I test to find what is broken? Thank you for your time.
Afte a oven clean cicle I now get the code message F3 : E0. The oven does not work and after any...
(More)
Afte a oven clean cicle I now get the code message F3 : E0. The oven does not work and after any selection when I pres Start the F3 E0 code comes I'm abale to cancel the code by pressing "cancel" but it still will not work. Thank you for any help that you can provide.
We have a range with a dual burner which is stuck on high. Am I looking at a faulty element,...
(More)
We have a range with a dual burner which is stuck on high. Am I looking at a faulty element, receptacle, dial, etc?
