First connect your router to computer with ethernet cable. Then access it with following link. http://192.168.1.1 or http://192.168.0.1 type user as "admin" and password as "admin" or blank or "password" then you can see configuration page of router settings. Go
to wi fi or wireless menu then find WEP or WAP security code key it is
your password to connect wi fi network.If it is in * or # format then
add new code so you can connect it with new code. then save settings and restart router. Let me know if you need more assistance. Thanks.
My problem is that my wireless network is not detected by my pc using an TEW-624UB Wireless N USB...
(More)
My problem is that my wireless network is not detected by my pc using an TEW-624UB Wireless N USB Dongle, It does detect other SSID's in my area. My ssid is not set to hide. And I can connect to my wifi network via my ps3 and also 2 laptops which have built in wifi adapters. I have tried plugging the TEW-624UB usb adapter to the laptop and checking if it displays my wifi ssid. but it is the same. It displays evey other network in my vicinity except my own. I figured it might be a problem with the usb wifi adapter and have since tried it with a Dlink DWA-110, but with the same results both on my computer and laptop it detects other networks accept my own. Mind you my PS3 and the Laptops using their built in wifi adapters is able to connect to my home wifi without any problems. I am using WPA-WPA2 as security and most of the other settings as default. I've tried changin the channel from 1 to 11 without any results. also turing off the wifi security does nothing.
I cant get remote admin to work with my DIR 655. I have opened up port 8080, and tried to reroute...
(More)
I cant get remote admin to work with my DIR 655. I have opened up port 8080, and tried to reroute it through port forwarding and virtual servers. These feature are working with an FTP server and remote access to a video camera but not with the web interface to manage the router...
I have a DSL-320B modem set up in bridged Mode (running the latestfireware)attached to my DIR-655...
(More)
I have a DSL-320B modem set up in bridged Mode (running the latestfireware)attached to my DIR-655 router. I am attemptin to use the dynamic dns option to connect in, but am unable to remotely connect in. I have confirmed that the remote management is enabled. Is it possible to do with this set up?
lost all connectivity. 3 computer setup has worked for over a year. 1-Vista Ultimate 64 Bit hard...
(More)
lost all connectivity. 3 computer setup has worked for over a year. 1-Vista Ultimate 64 Bit hard wired, 1 Vista HP 64 Bit wireless, 1 XP SP2 32 bit wireless. Shut down one night, next night could not access internet through router on any computer. Can run cat 5 from any computer direct to Speedstream 5100 DSL modem and connect. Can not find related FAQ or related trouleshooting info on D-link website. Dead router or just need which reconfig? Thank you
my ipod touch cannot detect any wifi networks. I have a dlink dir-655 router. On the settings for...
(More)
my ipod touch cannot detect any wifi networks. I have a dlink dir-655 router. On the settings for the ipod, the wifi address is 00:22:41:60:75:0A. I am not sure what that means. I originally set up the touch in another city with another network and have moved 2 times since. I am confused why the ipod won't recognize any wifi network. Wifi is on, I have tried the restore network settings. ect. I am stuck, can someone help?
