It sounds like there may be an issue with the balance of your washer. When a washer is out of balance, it can spin violently and cause the machine to reset. Here are a few things you can try:
Make sure the washer is level: Use a spirit level to check if the washer is level. If it is not, adjust the legs until it is.
Distribute the load evenly: Make sure the load inside the washer is distributed evenly. This will help to keep the washer balanced during the spin cycle.
Check for foreign objects: Make sure there are no foreign objects in the drum or the drum's seal, which may cause the washer to vibrate.
Check the suspension: Inspect the suspension system, which supports the drum and keeps it in balance. If the suspension is damaged or worn out, it will need to be replaced.
If the problem persists, it's best to contact the manufacturer or a professional technician for further assistance.
I had this problem with my front loader as well. It is probably the mounts or "level shocks" on the bottom of the unit under the tub. I have a Kenmore by Frigidaire and had to replace the "level shocks". I only paid about $43.00 and was not that hard to put on. Look under your machine and see if the shocks are connected to the tub. Check under the top panel also to see if that particular model has mounts up there too.
There are 2 shock absorbers/springs attached to the drum. If one of them breaks it will cause a loud banging noise when you wash heavy loads. This is an easy fix. The part is about $22.00 and it is accessed throught the front bottom panel.
Machine legs should be adjusted so that machine is level and standing on all four legs. The load in the machine should be evenly distributed. Utube has an excellent video on washing machine repair.
On something like this you will need to remove the washer wrap to
inspect the suspension springs & base assembly. Please see the link
provided for accessing the inside of the washer. Be sure the shipping
pins have been removed. The tub should float freely.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
